有人可以告訴我,orcad10.0如何裝呢?
全部回复(2)
powerusr
Start with creating the CDS_LICENSE_FILE environment variable with as value 5280@yourhostname .
Open/Edit our license.dat and update the "flexhostname" field to reflect your real net machine hostname.
Then, launch setup and choose choose "Setup licensing", point to our license.dat and press "Next" several time.
Ignore the license parsing nagbox which is a nice fake one, and answer yes when prompted to install products.
At the "Control File Location" dialog, just clear up the text box (BLANK) and then press next.
Now you have to choose products to install and finally press next several times
After a reboot you will be done, enjoy this sweet cd
note: Unison ULtra includes the whole OrCAD base level products. If you wish to have the real full bundle
      you may select this as products :
OrCAD Capture CIS
OrCAD Capture CIS Option
PSpice A/D
PSpice OPtimizer
PSpice Advanced Analysis
OrCAD Layout Plus
SPECCTRA 6U for OrCAD
If you want to use specctra in autoplacer mode you need to get psd+psd license, we on purpose did not include specctra  autoplacer because it is not supposed to be enabled within OrCAD
shichu
@powerusr
StartwithcreatingtheCDS_LICENSE_FILEenvironmentvariablewithasvalue5280@yourhostname.Open/Editourlicense.datandupdatethe"flexhostname"fieldtoreflectyourrealnetmachinehostname.Then,launchsetupandchoosechoose"Setuplicensing",pointtoourlicense.datandpress"Next"severaltime.Ignorethelicenseparsingnagboxwhichisanicefakeone,andansweryeswhenpromptedtoinstallproducts.Atthe"ControlFileLocation"dialog,justclearupthetextbox(BLANK)andthenpressnext.NowyouhavetochooseproductstoinstallandfinallypressnextseveraltimesAfterarebootyouwillbedone,enjoythissweetcdnote:UnisonULtraincludesthewholeOrCADbaselevelproducts.Ifyouwishtohavetherealfullbundle      youmayselectthisasproducts:OrCADCaptureCISOrCADCaptureCISOptionPSpiceA/DPSpiceOPtimizerPSpiceAdvancedAnalysisOrCADLayoutPlusSPECCTRA6UforOrCADIfyouwanttousespecctrainautoplacermodeyouneedtogetpsd+psdlicense,weonpurposedidnotincludespecctra  autoplacerbecauseitisnotsupposedtobeenabledwithinOrCAD
我用的就是这个版本的,以前可以的,可现在重新装的后PSPICE用不了了,不知怎么回事,提示Cann't link the simulation server....大概意思,即不太清楚了。。。哪位有应对高招?谢过了先。
