OSRAM汽车HID解剥图和工作波形图
这是我以前做汽车HID时,解剥OSRAM的HID的一些资料,共大家参考500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117429308.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(49)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117429574.jpg');}" onmousewheel="return imgzoom(this);">
jqx021
全桥驱动用什末型号IC?
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/29/1117429574.jpg');}"onmousewheel="returnimgzoom(this);">
高压触发脉冲
1117429626.tif
高压触发脉冲
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117429772.jpg');}" onmousewheel="return imgzoom(this);">
高压触发脉冲
1117429831.tif
高压触发脉冲[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/29/1117429772.jpg');}"onmousewheel="returnimgzoom(this);">
贴错了!  :(
高压触发脉冲
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117430121.jpg');}" onmousewheel="return imgzoom(this);">
冷灯启动电压包络500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117430267.jpg');}" onmousewheel="return imgzoom(this);">
冷灯启动电流包络
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117430415.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117430499.jpg');}" onmousewheel="return imgzoom(this);">
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/29/1117430499.jpg');}"onmousewheel="returnimgzoom(this);">
冷灯启动瞬间灯电压前沿
冷灯启动瞬间灯电流前沿
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117430596.jpg');}" onmousewheel="return imgzoom(this);">
@jqx021
全桥驱动用什末型号IC?
它的全桥推动用的是分立件,没用IC,恒功率控制由PIC单片机来完成,至于它为什么不用IC的推动,我没做进一步的研究,也没解剥它的电路.
柳西塔
HE HE我最近每天要修我们生产过程中的问题HID,修得我心惊肉跳的.开机的时候要祈祷放电管不要发出可怕的声音.
dotcom
我放一个另一角度的图[不是我的,也是以前在本论坛下载的,多谢上传的兄弟(忘了是谁上传的啦) :) ]
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/29/1117462968.jpg');}" onmousewheel="return imgzoom(this);">
dotcom
请教ahid兄:
全桥mosfet的型号是什么?
能给出分离元件的全桥推动电路吗?
hid农民
@柳西塔
HEHE我最近每天要修我们生产过程中的问题HID,修得我心惊肉跳的.开机的时候要祈祷放电管不要发出可怕的声音.
我的安定器也会出现2次激发的声音,特别是开关速度超过1秒内10几次的话
hid农民
@dotcom
请教ahid兄:全桥mosfet的型号是什么?能给出分离元件的全桥推动电路吗?
估计是IRF740S的
hidtech
能否告知全桥用的MOS管的型号?
柳西塔
@hid农民
如果开关速度这么快的话,估计放电管也要改进的.要用开关放电管,不能用气体放电管.
hid农民
@柳西塔
已经使用lily的开关管了,他们说是开关管的哦,呵呵,可是还是没有改善:(你的联系方式来一个
@hidtech
能否告知全桥用的MOS管的型号?
2sk1507
@dotcom
2sk1507
lily
@hid农民
是吗? 别的客户没有说这样的情况哟, 能告诉我详细情况吗?
lily
@hid农民
你用EPCOS的会不会有这样的情况呢???
dotcom
@老化中的镇流器
2sk1507
2SK1507是全塑封的,看图片却是TO-220AB封装的,奇怪?
2SK1507-01MR.pdf
@dotcom
2SK1507是全塑封的,看图片却是TO-220AB封装的,奇怪?2SK1507-01MR.pdf
抱歉,搞错了.应该是840或者740之类的.
hid农民
@lily
是吗?别的客户没有说这样的情况哟,能告诉我详细情况吗?
不用着急啦,我是说每秒十几次的连续开关,才会有这个问题.如果每秒间隔启动,没有问题的.
hid农民
2005-05-31 22:28
@老化中的镇流器
嘿嘿,看来你也会错.其实一般就是用840,740,因为我也没有去拆Osram的.不过Hella有用740的,偶们也是.
lily
2005-05-31 22:40
@hid农民
如果是我的管子有问题,我要改进才行呀,如果不是我的管子的问题你也要查出是什么原因呀,这样才能解决问题的.
