500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/30/1117764118.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
Nominal value Min Max Unit Conditions
INPUT
static
Input voltage, high voltage type 200-240 207 264 V
Input voltage, low voltage type 100-120 90 132 V
Input current, high voltage type 0.65 A
Input current, low voltage type 1.3 A
Mains frequency, both types 50-60 47 63 Hz
Power consumption 75 84 W @full load, max value @ 75% efficiency
OUTPUT
static
Output voltage 10.5 10 11 V @full load
Output current at full load 6 A @full load
Electrical isolation to primary SELV
Output power at short circuit 30 W @short cut output. Adaptor should not be damaged.
dynamic
Ripple at full load 450 mVp-p @full load, 0.1uF/47uF output capacitance @ 20Mhz, 25°C, 230V
Total output regulation -5 +5 %
Load characteristics See paragraph B2
Output voltage during pulsed load 8V See paragraph B2
Turn-on delay 2 sec
GENERAL
Efficiency 75 % @nom. input voltage and full load
Hold-up time 5 msec @nom. input voltage and full load
一个SMPS(附图),各位大虾来分析一下它的原理!
全部回复(26)
@caidong321
再发一张图[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/30/1117764457.jpg');}"onmousewheel="returnimgzoom(this);">
要抄这块板子,好做吗
@caidong321
老大﹐你在那里搞到帝聞的電源啊﹗﹗﹗﹗
@caidong321
**此帖已被管理员删除**
@zzd88
是POWERPCB的档案,我可以打开啊
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/63/1547561206665487.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/63/1547561206665606.gif');}" onmousewheel="return imgzoom(this);">
