IGBT发热,怎么办
50Hz正弦波逆变器,开关频率20k,死区3u,在开关切换的时候,总是有个短路电流流过两管子,电流峰值80~100A,持续时间200u.请教高手怎么解决,谢谢
IGBT发热,怎么办
全部回复(12)
@wolong
IncreasethedeadtimeIncreasethedeattimeto5uandcheckiftheshortcircuitcurrentgoesaway.Ifso,itmightbeyourFETs/IGBTsnottotallyoff.Andalso,doublecheckthePWMpulsesequencebetweentopandbottomswitch.
怀疑二极管的恢复问题
我有点怀疑是续流二极管反向恢复带来的,我测到在正负对称的时候,就不会有电流.而在不对称的时候,二极管还处于续流状态,对方IGBT导通的时候肯定出现.但不知怎样解决.
@shilin
怀疑二极管的恢复问题我有点怀疑是续流二极管反向恢复带来的,我测到在正负对称的时候,就不会有电流.而在不对称的时候,二极管还处于续流状态,对方IGBT导通的时候肯定出现.但不知怎样解决.
UF DIODE?
Check the datasheet of the diode you are using, is it UF diode if you can't use schottkey?
It's difficult to know what really happened without seeing the schematics and the waveforms. But you can definitely check the current on the diodes and IGBTs, find out what happened.
