请问ORCAD9.2怎么安装
在安装过程中出现了两个选项:standalone licensing及network licensing,请问我应该选哪个,不管我选哪一个,后面安装过程中均会出现enter the key code for the products you have purchased in the edit box below:随后我敲入B,F,I,K进入下一个步骤要我输入enter the authorization codes,但是授权号在哪里,我找遍了都找不到.
请问ORCAD9.2怎么安装
全部回复(8)
@xxy1990
安装方法你在安装时要选customer类型,然后在去掉document选项.安装后要运行pdxorcad.exe,选择你安装的目录,执行即可.
出现的消息如下
----- starting fixed patches -----
File D:\Program Files\Orcad\Layout_Plus\CAPTURE\CAPTURE.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\MODELED.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\PSPICE.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\SIMMGR.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\STMED.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\OPTIMIZE.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\LAYOUT\LSESSION.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\LAYOUT_PLUS\LSESSION.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\LAYOUT_ENG_ED\LSESSION.EXE skipped/not found
File D:\Program Files\Orcad\Layout_Plus\CAPTURE\DDLINKX.DLL skipped/not found
File D:\Program Files\Orcad\Layout_Plus\PSPICE\PSP_ENG.DLL skipped/not found
11 File(s) skipped/not found
Fixed Patch finished - No files found!
0 File(s) handled 0 Patches(0 new)
@hualong
出现的消息如下-----startingfixedpatches-----FileD:\ProgramFiles\Orcad\Layout_Plus\CAPTURE\CAPTURE.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\MODELED.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\PSPICE.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\SIMMGR.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\STMED.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\OPTIMIZE.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\LAYOUT\LSESSION.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\LAYOUT_PLUS\LSESSION.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\LAYOUT_ENG_ED\LSESSION.EXEskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\CAPTURE\DDLINKX.DLLskipped/notfoundFileD:\ProgramFiles\Orcad\Layout_Plus\PSPICE\PSP_ENG.DLLskipped/notfound11File(s)skipped/notfoundFixedPatchfinished-Nofilesfound!0File(s)handled 0Patches(0new)
使路径与安装路径一样就没有这信息了.试试看吧
