IEEE 文章大家看
Power electronic circuit topology1122209138.pdf
全部回复(31)
A comparison of high-power DC-DC soft-switched converter topologies1122209266.pdf
@ouyangyuye
Acomparisonofhigh-powerDC-DCsoft-switchedconvertertopologies1122209266.pdf
A comprehensive analysis of current-mode control for DCM buck-boost converters1122209344.pdf
@ouyangyuye
Acomprehensiveanalysisofcurrent-modecontrolforDCMbuck-boostconverters1122209344.pdf
A family of high power density bus converters1122209537.pdf
@ouyangyuye
Afamilyofhighpowerdensitybusconverters1122209537.pdf
A family of PWM plus phase-shift bidirectional DC-DC converters1122209616.pdf
@ouyangyuye
AfamilyofPWMplusphase-shiftbidirectionalDC-DCconverters1122209616.pdf
Zero-voltage-switching (ZVS) two-stage approaches with output current sharing for 48 V input DC-DC converter1122209831.pdf
@ouyangyuye
Zero-voltage-switching(ZVS)two-stageapproacheswithoutputcurrentsharingfor48VinputDC-DCconverter1122209831.pdf
A boost DC-AC converter——analysis, design, and experimentation1122209973.pdf
A DC-AC converter using a voltage equational type switched-capacitor transformer1122210022.pdf
A novel modulation method for DC-AC matrix converters under distorted DC supply voltage1122210088.pdf
@ouyangyuye
AboostDC-ACconverter——analysis,design,andexperimentation1122209973.pdfADC-ACconverterusingavoltageequationaltypeswitched-capacitortransformer1122210022.pdfAnovelmodulationmethodforDC-ACmatrixconvertersunderdistortedDCsupplyvoltage1122210088.pdf
A constant frequency variable power regulated ZVS-PWM load resonant inverter for induction-heating appliance1122210252.pdf
ZVS frequency analysis of a current-fed resonant converter1122210321.pdf
@ouyangyuye
AconstantfrequencyvariablepowerregulatedZVS-PWMloadresonantinverterforinduction-heatingappliance1122210252.pdfZVSfrequencyanalysisofacurrent-fedresonantconverter1122210321.pdf
A new flyback converter with primary side detection and peak current mode control1122210811.pdf
Analysis and design of a forward-flyback converter employing two transformers1122210869.pdf
Waveform dependent switching losses in flyback transformer foil windings1122210948.pdf
楼主能不能帮我下两篇文章:
1. ieeexplore.ieee.org/iel3/ 4996/13714/00631397.pdf
“STUDY AND DESIGN OF HIGH VOLTAGE FLYBACK TRANSFORMER FOR TV AND MONITOR ”
Jin-Yue Chen', Shou-Qian Ding', Guang-Yun Zhu2
2. http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/2943/28690/01286624.pdf
3.Østergaard, Leo ; Rudnicki, Marek ; Bak-Jensen, Birgitte . “A Simple Two-winding Model of the Diode Split Transformer.”
I: MiS '98 : International Symposium on Micromachines
and Servo Drives, Malbork, Poland. s. Vol. 1, pp. 154-161.
多谢先!!!
多谢先!!!
@nestling
楼主能不能帮我下两篇文章:1.ieeexplore.ieee.org/iel3/4996/13714/00631397.pdf“STUDYANDDESIGNOFHIGHVOLTAGEFLYBACKTRANSFORMERFORTVANDMONITOR”Jin-YueChen',Shou-QianDing',Guang-YunZhu22.http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/2943/28690/01286624.pdf3.Østergaard,Leo;Rudnicki,Marek;Bak-Jensen,Birgitte.“ASimpleTwo-windingModeloftheDiodeSplitTransformer.”I:MiS'98:InternationalSymposiumonMicromachinesandServoDrives,Malbork,Poland.s.Vol.1,pp.154-161. 多谢先!!!
STUDY AND DESIGN OF HIGH VOLTAGE FLYBACK TRANSFORMER FOR TV AND MONITOR 1122472988.pdf
@abing
请问一个问题:为何叫IEEE文章大家不要笑我哦,我的确不知,还望各位告诉我!
为何没人回答我的问题--------------------------------------------------------------------------------------------------------------------------------------为何没人回答我的问题------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------为何没人回答我的问题--------------------------------------------------------------------------------为何没人回答我的问题------------------------------------------为何没人回答我的问题
