求太阳能路灯驱动电源,带可调功
50W太阳能路灯驱动电源,带可调功
有没有好的方案,推荐一下
全部回复(9)
有机会
50W,要用升压做是吧
我公司有你要的产品:http://www.jsgubang.com联系人:蔡先生电话13505257766
我这边有一颗升压电源,不知道是不是可以,你可以看看.要是可以的话,可以跟我联系.我可以提供DEMO给你测试,谢谢!FEATURES
- Input voltage:4.5V to 23V
- Output voltage:5 V to 68V
- Duty ratio:0% to 85% PWM control
- Oscillation frequency:500KHz.
- Enable and Thermal Shutdown function.
- Internal Current limit.
- Built-in N-channel MOSFET
- SOP-8L with Exposed pad Pb-Free package
@caoshun123448
我这边有一颗升压电源,不知道是不是可以,你可以看看.要是可以的话,可以跟我联系.我可以提供DEMO给你测试,谢谢!FEATURES-Inputvoltage:4.5Vto23V-Outputvoltage:5Vto68V-Dutyratio:0%to85%PWMcontrol-Oscillationfrequency:500KHz.-EnableandThermalShutdownfunction.-InternalCurrentlimit.-Built-inN-channelMOSFET-SOP-8LwithExposedpadPb-Freepackage
是什么芯片.能介绍一下吗?
我的电话是:13928493548
@cpluselectronics
是什么芯片.能介绍一下吗?我的电话是:13928493548
zheb8000
LM3423 LED驱动器的技术规格
这款最新推出的美国国家半导体LM3423芯片适用于高达75V的输入电压,可升降压应用,
可出高达18个1W串接 LED,
       VIN range from 4.5V to 75V
2% 1.25V Internal reference voltage
Current sense voltage adjustable from 50mV to 1.25V
High side current sensing
750mA peak MOSFET gate driver
Dimming MOSFET gate driver
Input under-voltage protection
Output over-voltage protection
LED ready flag
Low shutdown current, Iq < 1?A
Fast (50 KHz) PWM dimming input
Cycle-by-cycle current limit
Programmable running frequency
Fault timer pin
TSSOP-20 package
        Applications
LED Drivers
Constant Current Buck-Boost Regulator
Constant Current Boost Regulator
Constant Current Flyback Regulator
Constant Current SEPIC Converter
Thermo-Electric Cooler (Peltier) Driver
TEL:(0)13760313075;
Email:ZHEB8110@163.COM;
MSN:ZHEB8110@hotmail.com;500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/1367671248876380.gif');}" onmousewheel="return imgzoom(this);">
led-drive
PAM2842就可以了  需要就给我电话13428943627
zhseli
@allen880629
有机会50W,要用升压做是吧
根据以往各种各样LED路灯工程及相关行业人士介绍,LED路灯安装在道路上应用一段时间后就会出现灯不亮,或亮度下降等问题,广泛得到行业人士重视,首先出现LED路灯不能正常工作可能归到电源供电部分,第一转换效率低,散热能力差,温升也不断提升;第二制程生产方面采用杂牌元件;第三电源没有设计一些保护措施,如防雷等问题.
     其实路灯电源节能意味着:高效率意味着电源高可靠和长寿命,高效率带来元器件的低温升,元器件温度每降10度,可靠性和寿命增加一倍,电源的高效率有利于降低LED灯的工作温度及延缓光衰.
     我们专业供应大功率LED路灯、LED遂道灯恒流恒压驱动电源,效率高达95%,,功率因素高达0.99,产品新新推出更宽电压应用,90~305Vac,更适应各国使用,恒电压输出从12V~54V间6个不同的电压输出范围,恒流可应客户要求而设计,目前标准品从350mA~4000mA不等;产品防水标准IC67,提供了有源功率因数校正和完善的各项关键保护功能,如过压保护、过流保护、短路保护和过温保护,同时提供了防雷击浪涌保护功能防雷设计(IEC-61000-4-5 Class 4),这些产品完全符合国际领域所遵循的UL8750和 EN61347-1安规认证.电源耗电量仅为众多同类竞争产品的一半,因为电源功耗很低,所以电源元器件温度也相应降低,从而使产品的可靠性大幅度提升产品封装铝质外壳具有良好散热效果!目前产品恒流有EWC-30S\EWC-50S\EWC-100S更大功率后续会陆续推出;恒压产品有EUV-100S\EUV-120S\EUV-150S\EWV-200S\EUV-300S,详情敬请邮件或电话资询!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.comhttp://wpa.qq.com/pa?p=1:553969488:10');}" onmousewheel="return imgzoom(this);">QQ联系
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.comhttp://samsun.blog.dianyuan.com/photo/2008-08/f16c84c0eb13cc3104d6254bf492b8b7.gif');}" onmousewheel="return imgzoom(this);">
我这有做好的产品LED驱动:12v/24v输入,输出18v-40v自动适应,功率12v是最大50w,24v最大时100w,功率可以自由调整!
