跪求锂电池过充、过放保护ic资料..???????????
我做单节锂电池充电,3.6V,请推荐过充、过放保护ic,并且给ic资料,本人不胜感激!!!!!!!!!!!1
全部回复(6)
VA7068-高精度锂电池保护IC
特点:
⊕Ideal protection circuit for one-cell Li-ion or Li-Polymer battery(单节锂离子或锂聚合物电池的理想保护电路)
⊕Little external elements(极少的外围元器件)
⊕High precision protection voltage threshold(over-charge/over-discharge)(高精度的保护电压(过充/过放)检测)
⊕Low power consumption under over discharge(过放电低功耗模式)
⊕Protection for battery short(电池的短路保护)
⊕Multi-type of detector voltage and time delay option(多种型号的检测电压和延迟时间)
⊕0V-charge allow/inhibit(可选择不同型号0V-电池充电允许/禁止)
⊕Ultra small SO23-5 or SOT23-6 package
应用:
⊕Protection circuit for charge and discharge of Li-ion or Li-polymer Battery(锂电池的充电、放电保护电路)
⊕High precision protector for cell phone battery and any other protector of Li-ion or Li-polymer battery(电话机电池或其它锂电池高精度保护器)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/32/1124784447.gif');}" onmousewheel="return imgzoom(this);">
http://www.micro-bridge.com/VA7068.asp
Micro Bridge Technology Co.,Ltd.
Tel: 86-755-83991588
特点:
应用:
@quasar_yluo
我是代理商,看看这颗行不:luoyongzx@126.com罗勇0755-26432377*803135102318051124856187.pdf
看看这个文件,目前的电池厂家设计用的比较多,我曾经测试过电池.1125048130.pdf
