Orcad9.1安装失败,高手请进!
本人在市场上买了盒ORCAD9。1版,打开里面有一光碟一A盘,A盘打不开,光碟里的文件为图中1
全部回复(14)
@miller31202
请问最好了一个图上要填什么啊!!我就在那里停下来了,过不去那个画面!
INSTALL NOTES:
1. unzip
2. use our installer (or unpack manually)
3. run exe
4. when u r asked for serial... use the following:
App Serial
Capture A
CaptureCIS B
LayoutStd E
LayoutPlus F
LayoutEngEd G
PSpice H
PSpiceAD I
PSpiceADBasics J
PSpiceOptimizer K
For full products u need only B,F,I,K. These includes the other ones.
After that you will asked for a authorization-code.
Write in any number but only 1 line.
******* DO NOT INSTALL DOCUMENT OPTION *******
After the installation run the patcher PDXOrCADcrk.exe in install dir.
1. unzip
3. run exe
App Serial
Capture A
CaptureCIS B
LayoutStd E
LayoutPlus F
LayoutEngEd G
PSpice H
PSpiceAD I
PSpiceADBasics J
PSpiceOptimizer K
@miller31202
YES[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/32/1125316454.jpg');}"onmousewheel="returnimgzoom(this);">
看来我们两昨天是一个时间安装的了,我是按着里面的一个安装说明做的,也没有碰到你的这种现象。:(
@rayruby
INSTALLNOTES:~~~~~~~~~~~~~~1.unzip2.useourinstaller(orunpackmanually)3.runexe4.whenuraskedforserial...usethefollowing: App Serial ---------------------------------- Capture A CaptureCIS B LayoutStd E LayoutPlus F LayoutEngEd G PSpice H PSpiceAD I PSpiceADBasics J PSpiceOptimizer KForfullproductsuneedonlyB,F,I,K.Theseincludestheotherones.Afterthatyouwillaskedforaauthorization-code.Writeinanynumberbutonly1line. ******* DONOTINSTALLDOCUMENTOPTION*******AftertheinstallationrunthepatcherPDXOrCADcrk.exeininstalldir.
顶一下.求ORCAD9.1的安装方法..
@miller31202
NEXT[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/32/1125316324.jpg');}"onmousewheel="returnimgzoom(this);">
这个是什么原因哦,我安装这个时也是同样的错误,然后就是仿真不了
