用NCP1650的兄台们看过来,交流一下:)
交流一下:)
全部回复(16)
@cm710
升压电感的电感量对吗?还有限流电阻的值可以减小点试试
限流电阻我从2个0.1欧并到4个0.1欧并应该不会是它的问题.
升压电感感量从500uh变到1.3mh我没好好算过.而且不太清楚辅助绕组的砸比.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/17/1084843974.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/17/1084844026.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/17/1084843974.jpg?x-oss-process=image/format,webp)
![](http://u.dianyuan.com/bbs/u/17/1084844026.jpg?x-oss-process=image/format,webp)
@hehe
我开始也是用他给的那个东东.但是驱动就像一个尖峰,打不开.全部用他demo给出的东东,还是驱动打不开.我只想做250w.我全部的大于1u的电容都用电解,会不会是这个原因.升压电感我选了500u和1.3m,两种.砸比19:1.急ing
500uH差不多,好象是你的咂比有问题,19:1在400V时次级就有21V已经超过了NCP1650的VCC上限了.所以你在低压是能启动而高压不行(NCP1650过压保护了)
NCP1650 Design Parts List
NCP1650 Design Aid
Provided by ON Semiconductor
For a system with the following specifications:
Pomax = 250 watts
Vinmax = 265 Vrms
Vinmin = 85 Vrms
fLINE = 50 Hz
fSwitch = 100 kHz
Vout = 400 volts
h = 0.9
L = 500 uH
The following parts are required2: Cout1 = 100 uF
acscale = 0.010 divider ratio C2 = 0.1 uF
RShunt = 0.03 ohms C3 = 10 nF
R3 = 1,500 ohms C4 = 1 nF
R7 = 600 ohms C7 = 47 uF
R8 = 10,000 ohms C8 = 22 uF
R9 = 68,000 ohms C9 = 3.3 uF
R10 = 10,000 ohms C11 = 1.0 nF
R13 = 100 kOhms CT = 470 pF
Notes:
1. Ripple current calculations for input and output capacitors are plotted on sheet 3a.
2. These component values are a recommended starting point, however, ON Semiconductor does not
guarantee that the circuit will meet all specifications. Normal troubleshooting and adjustments
may be necessary.
3. Additional components will be needed if implementation of an EMI filter is necessary.
我试着算了一下,你看看和你的结果一样吗?注意电感的峰值电流>4A
NCP1650 Design Aid
Pomax = 250 watts
Vinmax = 265 Vrms
Vinmin = 85 Vrms
fLINE = 50 Hz
fSwitch = 100 kHz
Vout = 400 volts
h = 0.9
L = 500 uH
Notes:
may be necessary.
@武士
500uH差不多,好象是你的咂比有问题,19:1在400V时次级就有21V已经超过了NCP1650的VCC上限了.所以你在低压是能启动而高压不行(NCP1650过压保护了)NCP1650DesignPartsListNCP1650DesignAidProvidedbyONSemiconductorForasystemwiththefollowingspecifications:Pomax=250wattsVinmax=265VrmsVinmin=85VrmsfLINE=50HzfSwitch=100kHzVout=400voltsh=0.9L=500uHThefollowingpartsarerequired2:Cout1=100uFacscale=0.010dividerratioC2 =0.1uFRShunt=0.03ohmsC3 =10nFR3=1,500ohmsC4 =1nFR7=600ohmsC7 =47uFR8=10,000ohmsC8 =22uFR9=68,000ohmsC9 =3.3uFR10=10,000ohmsC11=1.0nFR13=100kOhmsCT=470pFNotes:1.Ripplecurrentcalculationsforinputandoutputcapacitorsareplottedonsheet3a.2.Thesecomponentvaluesarearecommendedstartingpoint,however,ONSemiconductordoesnotguaranteethatthecircuitwillmeetallspecifications.Normaltroubleshootingandadjustmentsmaybenecessary.3.AdditionalcomponentswillbeneededifimplementationofanEMIfilterisnecessary.我试着算了一下,你看看和你的结果一样吗?注意电感的峰值电流>4A
应该不会呀,我量了我的vcc,在14v左右,辅助绕组过100u得电容,应该不会在vcc上被掐死才对.对了,你的电容是电解的么?我只得是22u电容.
我把我的布线传上来,请狠狠的批
我把我的布线传上来,请狠狠的批
@武士
Onsemi有NCP1650的设计软件,我基本上是用这个软件选择参数.电感是个重要的参数.好象在高压时容易开机.你说的陷死是什么意思?你设计要求的输出功率是多少?电感好象太小
请问你说的这个软件在哪里可以下载,可以给个地址吗?能否发我的邮箱:nwu88@163.com,或者加我QQ:64811814,感谢!
