半桥(全桥)zcs软件动态跟踪完全谐振的可行性
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/237231259800159.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
动态跟踪完全谐振可以解决线圈电感量不准或变化带来的问题.原理是串联谐振在完全谐振状态下最大功率取决于谐振电容的容量(负载极轻和加热到居里点除外,另外讨论).用单片机i/o口输出igbt驱动信号,内部比较器作为电流信号检测.软件相位判断并逐周期调整.电流和驱动相位关系见图.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839924.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839940.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839952.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839962.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839977.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/79/237231247839988.gif');}" onmousewheel="return imgzoom(this);">
电流互感器有一定的相移,通过软件可以校正.
试验结果,用半桥10kw正常工作中通过带电增减谐振电容都能很好的跟踪.由于示波器没有脉冲时间触发功能没能捕捉到跟踪过程.肉眼根本看不出捕捉过程.对于现场制作线圈的场合汇方便很多.
全部回复(15)
100kw左右全桥串联逆变能否用一个变压器和两个半桥模块完成?
@wangjinchao
可以,但我一般不用变压器直接驱动.
@秋天的风
可以,但我一般不用变压器直接驱动.
变压器是输出变压器,不是栅极推动变压器.
@wangjinchao
高频的话变压器不好找啊.中频段当然没问题.
@秋天的风
对于功率铁氧体,100k以下频率还是适应的,倒是模块开关速率的提高使其损耗加大,尤其下降时间.
@wangjinchao
所以才要应用谐振呀
@秋天的风
所以才要应用谐振呀
谐振的目的是使其电路达到ZVS/ZCS,但用软件驱动感到不踏实,软件还是起到看护作用好.
gz.daheng
好!捕捉波型还好!没电流探头会有点相移的,只做参照,问题不大.
@gz.daheng
电流互感器相移是避免不了了,只能用软件补偿了.
oucchina
@秋天的风
可以通过相位超前来调整相位,比如用负压基准IC和比较器构成一个超前相位调整,再加一个滞后调整(相当于超前调整)就可以实现.
@oucchina
比用软件麻烦很多
zhouboak
@秋天的风
比用软件麻烦很多
顶一下
@oucchina
好早前看过一篇论文,
里面使用到了DSP进行控制,原理和你说的一样.
ayong168
你的图图似乎都跑容性区工作了?
@ayong168
你的图图似乎都跑容性区工作了?
几张图都看明白了吗?
