pls note the following requirement for the LED power supplies.
General specification
- switch mode operation
- small size
- high efficiency
- constant current output
- low output ripple and noise (below 40 mVpp)
- input and output connection on terminal blocks
- two paralleled output terminal blocks for the models starting from 1,5A
- output voltage adjustable by trimmer potentiometer between 11 – 14V
- required output currents: 0,5A; 1A; 1,5A; 2A; 3A
需带外壳,有认证
