Urgent EMI problem
Urgent EMI problem
Please help me to fix the EMI problem. The picture is attached. Thanks!
MIL-STD-461D
2446441256417243.doc
全部回复(2)
hlp330
tell us more detail,such as schematic,transfomer...
cmecme
@hlp330
tellusmoredetail,suchasschematic,transfomer...
Thanks for the response and I can not tell you too much details. But here is the Vicor HAM has been used with an EMI filter. If possible to give me the suggestion about the low frequency noise at 10KHz range. Thanks again!
【 DigiKey DIY原创大赛】自平衡莱罗三角形(一)-无钢网焊接
地瓜patch
地瓜patch
【 DigiKey DIY原创大赛】+ 电压电流在线监控器
wenaochina
【 DigiKey DIY原创大赛】基于树莓派的 Modbus网关
pomin
【 DigiKey DIY原创大赛】888全彩光立方
fzwwj95
