请教有关“battery package”的问题!
Still there was no Polyswitch built in. - NOW build in Polyswitch
2) Also the charging electronic is not built in.
The whole item needs to shut down before the electronic of the battery.
For that you need an additional protection for the Direct Charger, additional to the protection of the built in battery.
Otherwise the battery of the direct charger will be defective after several times of use.
全部回复(3)
goldant
电池不太懂,但正好看到polyswitch的e文解释
A PolySwitch is a Polymer form of Positive temperature coefficient resistor (PPTC) which acts as a self repairing fuse
austen
仍然没有内置PPTC(自恢复保险丝,正温度系数保险丝),现在请增加内置PPTC.
2)充电器也没有,整个项目在(电子电池??)前要关闭,所以你需要对充电器附加一个保护,对内置电池附加一个保护.
否则在几次使用后电池将有缺陷
hiramwang
@austen
仍然没有内置PPTC(自恢复保险丝,正温度系数保险丝),现在请增加内置PPTC.2)充电器也没有,整个项目在(电子电池??)前要关闭,所以你需要对充电器附加一个保护,对内置电池附加一个保护.否则在几次使用后电池将有缺陷
谢谢,
