![](http://u.dianyuan.com/bbs/u/83/3317061258778197.gif)
单硅后级的电路仿真
电路模型:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258778197.gif');}" onmousewheel="return imgzoom(this);">
全部回复(90)
触发脉冲:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258778253.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258778253.gif)
@wangguangjun81
触发脉冲:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258778253.gif');}"onmousewheel="returnimgzoom(this);">
输出波形(负载100欧,输入电压600V,LC回路为1.5mH*5UF):
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258778362.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258778362.gif)
@wangguangjun81
输出波形(负载100欧,输入电压600V,LC回路为1.5mH*5UF):[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258778362.gif');}"onmousewheel="returnimgzoom(this);">
其他条件不变,关断电容为2UF的后级输出波形
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258778673.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258778673.gif)
@wangguangjun81
其他条件不变,关断电容为2UF的后级输出波形[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258778673.gif');}"onmousewheel="returnimgzoom(this);">
其他条件不变,关断电容为10UF的后级输出波形:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258778828.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258778828.gif)
@wangguangjun81
其他条件不变,关断电容为10UF的后级输出波形:[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258778828.gif');}"onmousewheel="returnimgzoom(this);">
其他条件不变,关断电容为10UF时,关断电容和负载上的波形(下半部为电容上的波形,上半部为负载上的波形):
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258783225.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258783246.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258783225.gif)
![](http://u.dianyuan.com/bbs/u/83/3317061258783246.gif)
@无衣
**此帖已被管理员删除**
传不上去
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258784335.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258784335.gif)
@wangguangjun81
其他条件不变,关断电容为10UF时,关断电容和负载上的波形(下半部为电容上的波形,上半部为负载上的波形):[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258783225.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258783246.gif');}"onmousewheel="returnimgzoom(this);">
很好,已经把电容的波形反回来了,(原来的电容的波形是反的)
@wangguangjun81
传不上去[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/3317061258784335.gif');}"onmousewheel="returnimgzoom(this);">
你把电感加大到50mh以后,负载接20欧姆,用5UF电感再模拟一下让我们看看波形怎么样?
@wang640909
仿真波形如下:
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258787252.gif');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3317061258787276.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/83/3317061258787252.gif)
![](http://u.dianyuan.com/bbs/u/83/3317061258787276.gif)
@wang640909
模拟证明我发的帖子"前人设计的单硅和从单硅分析给予的启示"一贴的论断符合计算结果!!!!!!!!!!!!!!!!看来没有任何问题!!!!!!!!!!!!前人的分析是错误的!!!!!!!!!!!!!
这是我的分析部分全文,
图中电容开始反向放电时假设参数如图:ik为关闭前的维持电流,im为为电感回路的最大峰值电流,总电流要满足下面的条件 :iO=ik+iL------(1)
其中iL此时有: im=iL---------(2)
有下面条件制约: 1/2*C*U2 =1/2*L*i2 --------------(3)
此时 U=E
i=Im -------------(4)
(1) 式变形关闭条件: im<:iO-ik --------------------(5)
(3)和(4)式得: im=(√C/L)*E ------------(6)
iO=E/RO -------------------(7)
ik大功率可控硅一般为几十mA和总电流以及电容最大电流相比可以忽略不计,以利简化计算不影响结果分析.
上面两式合并为: (√C/L)*E< E/RO 化简得:
RO<√L/C ----------------(8)
可见是否关断与电源电压无关,只与电感,电容,负载有关
捕鱼理论告诉我们:脉宽同样功率下最高效脉宽范围为(1---3)ms,常规选取一般电容最大取5UF最小取2UF,脉宽3ms计算,由下面公式计算: T=2∏√L*C-------(9)
有L大约有(50---125)mh范围 ;
如果取1ms,电容(2---5)UF,上面公式计算有:L大约(6---14)mh,
将条件带入(8)式计算: 第一种情况RO关闭条件取值范围:
3ms下(5—2)UF小于 100欧和250欧
1ms下(5--2)UF小于 33欧和80欧
上面是功率足够,电压稳定供电前提下不稳定转换的边界条件,如果有功率不足造成波形畸变电压波动时会有一定的出入,
考虑到实际情况再减小应该关闭.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/3525911258789172.gif');}" onmousewheel="return imgzoom(this);">
此时 U=E
考虑到实际情况再减小应该关闭.
![](http://u.dianyuan.com/bbs/u/83/3525911258789172.gif)
@wang640909
这是我的分析部分全文, 图中电容开始反向放电时假设参数如图:ik为关闭前的维持电流,im为为电感回路的最大峰值电流,总电流要满足下面的条件 :iO=ik+iL------(1)其中iL此时有: im=iL---------(2)有下面条件制约: 1/2*C*U2=1/2*L*i2--------------(3)此时 U=E i=Im -------------(4)(1)式变形关闭条件:im
请看16贴和我上面的文章还有15贴楼主朋友的回复一切就已经证实了有电压而不能关闭的原因是电流关闭而不是电压关闭,电流关闭在前,电压在后而到,并且这个关闭条件只与三个条件有关L,C.R,与供电电压无关的结论!!!!
