  • 论坛首页
  • Mean Well AC/DC ULP-150 Series U-Bracket Type LED Power Supplies from Kulon
Kulon  offers the new 150W AC/DC U-bracket type LED power supplies with active PFC function recently launched by Mean Well
Designed for street lighting applications, the ULP-150 series AC/DC LED power supplies feature constant voltage output design, 90~295VAC wide AC input range and built-in active PFC function.
Additionally, the AC/DC LED power supplies meet harmonic current as per EN61000-3-2 Class C (≥ 60% of load) and also have a power factor of >0.9 if loaded over 50%.
These power units are also equipped with 4KV surge immunity level (EN61000-4-5), helping them meet compliance requirements for street lighting applications. The AC/DC LED power supplies are perfectly suited for assembly inside the lamp head of LED streetlights.
Key features of AC/DC LED power supplies:
  • Up-to-date switching technology
  • Up to 93% efficiency; can be cooled by free air convection from -30ºC to +60ºC ambient temperature
  • Higher temperature of +70ºC can be achieved by adding a heat sink to the bottom of the unit
  • Semi-encapsulated PCB for basic moisture and dust protection
  • 3-year warranty
  • ±10% output voltage adjustment
  • Short circuit, overload, over voltage and over temperature protection
  • Designed to UL8750, EN61347-2-13 and related EMC norms (EN55015/EN61547)
  • Suitable for all kinds of LED lighting applications
全部回复(0)
