Electronic Features 电参数特征
Input Line Voltage 输入线电压 |
0V to 420V AC 3 Phase |
Normal Line Voltage 额定工作线电压 |
350V AC to 410V AC 3 Phase |
Frequency range频率范围 |
50Hz/60Hz±5% |
Input Power 输入功率 |
35KW |
Maximum line current 满载输入线电流 |
55A Max at 100% load condition |
Minimum line current 最小输入线电流 |
10A Min at 1% load condition |
Efficiency (full load) 效率 |
97% Minimum. 99% Maximum. |
Standby Power Loss 待机功耗 |
≤3W Max at 380V AC line voltage |
Input cables 输入电缆线 |
10m2 |
Leakage Current 漏电流 |
Less than 2mA |
Inrush line current(cold start) 浪涌电流 |
300A typ peak, 380V AC line; |
Isolation 相线机壳 |
DC500V 30MΩ min |
Input Fuse 输入保险 |
T100A/660V AC |
Operating temperature range工作温度 |
-40℃ to + 40℃ |
Storage temperature range 存储温度 |
-60℃ to + 80℃ |
