![](http://hiphotos.baidu.com/sumasemi/pic/item/f82ddf24c020963d35a80f27.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://hiphotos.baidu.com/sumasemi/pic/item/a4e21a614ab994828cb10d27.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
GLOBAL SUPPLIER of TOTAL SYSTEMS SOLUTIONS
AMETEK Aerospace & Defense is a leading manufacturer of highly engineered and cost effective engine sensor suites, aircraft data management systems, cooling and ventilating systems, environmental control systems, and a variety of sub-assemblies to military and aerospace customers.
Markets
Business Jets: Very Light to Intercontinental
Regional Aircraft: Turboprop and Regional Jets
Large Commercial Transport
"UAV" Helicopter and Trainers
Ocean Vessels: Commercial and Military
Military Vehicles: Tracked and Wheeled
Helicopters: Business and Military
Space: Launch Vehicle, Shuttle Craft and Satellite
Military: Transport and Fighter/Bomber
Products
Airframe Sensors: Fatigue, Angle of Attack, Position, Proximity, Pressure, Accelerometers, Temperature
Air Movement: Fans and Blowers, Electric Heaters
Data Acquisition: Multi Input Analog/Discrete, Data Bus Concentration, Engine/Airframe Sensors Interface
Engine Sensors: Temperature, Pressure, Flame, Speed, Mass Fuel Flow, Lube Oil Level, Accelerometer, Switches, Electrical Harness
Fluid Level Systems: Fuel, Hydraulic, Engine Oil, Water, Waste, Reservoirs
Heat Exchangers: Pre-coolers, Condenser/Evaporator, Liquid/Liquid, Liquid/Air
NBC Systems: Carbon Filter, Regenerative
Power Control & Distribution: Solid State Power Control, Controllers, Relays, Circuit Breakers, Power Distribution Units
Thermal Systems: Vapor Cycle, Custom Cooling Assemblies, Engine Cooling Systems
Indicators and Displays: Engine and Airframe Monitoring, Standby Engine Indicators, Retrofit Applications
![](http://hiphotos.baidu.com/sumasemi/pic/item/95628d12cb45c37edc540127.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
![](http://hiphotos.baidu.com/sumasemi/pic/item/51874f2259459c1393580727.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
Rotron
1/2 PROPIMAX 2 |
The Propimax 2 is Rotron’s most axially compact tubeaxial fan and is equipped with an aerodynamic venturi configured case. These high speed fans achieve minimum (“½”) size with a shortened venturi configuration utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient 2-blade propeller, with no further space sacrificed for the AC induction drive motor. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
AXIMAX 1 |
The Aximax 1 fan, like other vaneaxial fans, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. These high speed fans achieve maximum performance and minimum size with the unique inverted AC induction motor.Our Brushless DC driven configurations take advantage of a inverted permanent magnet motor, and either internal or external drive electronics. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
AXIMAX 2 |
The Aximax 2 fan, like other vaneaxial fans, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. These high speed fans achieve maximum performance and minimum size with the unique inverted AC induction motor. Our Brushless DC driven fans have electronics circuitry mounted in a disk attached to the case hub or in an external module to handle higher power requirements. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
AXIMAX 3 |
The Aximax 3 fan, like other vaneaxial fans, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. These high speed fans achieve maximum performance and minimum size with the unique inverted AC induction motor. Our Brushless DC driven fans have electronics circuitry mounted internally or in an external module to handle higher power requirements. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
AXIMAX 4 |
The Aximax 4 fan, like other vaneaxial fans, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. This fan series achieves the highest static pressures in the Aximax line due to customized aerodynamics and a robust AC induction motor. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
Airflow Switch |
The Rotron Model 2C Airflow Switch is actuated by air velocity rather than air pressure. It is designed for easy mounting on the outside of an air duct with a small light weight stainless steel vane protruding through a hole in the duct into the airstream. The switch can be used as interlock for on off purposes or as a marginal safety device where the electrical contacts are operated at a predetermined minimum flow air. The switch is designed for commercial applications but has been used satisfactorily on certain military projects. Its acceptability on military projects is left to the evaluation of the purchaser. Operates reliably in ambient temperatures of 35ºC to +85ºC. |
Centraxial Blowers |
Centrimil centraxial blowers have an impeller that, unlike the centrifugal blower, achieves a substantial portion of conversion of velocity energy to pressure energy within the impeller itself. It is operated with a scroll so air enters axially and exits tangentially, making a 90 degree turn. Models are available with 50/60 and 400 Hz AC or brushless DC motors. Centrimil centraxial wheel blowers develop high pressure and volume performance at low rotational speeds than vaneaxial fans for quieter cooling of tightly packaged electronic equipment under severe environmental conditions in airborne, ground based, and shipboard applications. |
Centrifugal Blowers |
Rotron centrifugal blowers are compact, sturdy, and relatively light in weight. They are designed for high performance while providig a long, maintenance-free life. Most models are available for either clockwise or counterclockwise rotation, and in either simplex or duplex types. Models are available with 50/60 or 400 Hz AC motors. Centrifugal blowers develop high pressure-to-volume performance at low rotational speeds for quiet cooling of tightly packaged electronic equipment under severe environmental conditions in airborne, ground based, and shipboard applications. Simplex blowers have 1 squirrel cage impeller wheel while Duplex blowers have 2 squirrel cage impeller wheels mounted on a common shaft - both are available for either clockwise or counterclockwise rotation. Duplex blowers simplify ductwork and allow greater volume performance in tight locations. As with all squirrel cage blowers, air enters axially and exits tangentially, making a 90 degree turn. |
Fan Heaters/Military Vehicle |
To provide a simple solution suitable for retrofit or incorporation into the original environmental control system, AMETEK Airscrew offers a range of fan heaters suitable for military vehicles. These fan heaters are capable of a wide range of heat outputs and supply sufficient air velocity and pressure to feed duct work and discharge louvres. Their high-pressure capability also makes them suitable for spot heating in addition to conventional ducted systems. Additional applications include demistting of windows and sighting systems. Options and alternatives include special noise attenuation, solid state relay controls, inlet guards and EMC protection. |
HF, HFV & HFG |
HF model 8” diameter propeller fans allow for high airflows at low static pressures with low motor-winding temperature rise. Models are available with airflow in either axial direction and with 50/60 and 400 Hz AC or brushless DC motors |
Inverted Blowers |
Trimline inverted blowers are compact, sturdy, and relatively light in weight. Inverted blowers have the unique Rotron inverted drive motor located inside the squirrel cage wheel. This results in unusual compactness and excellent motor cooling. Models are available in in a variety of Brushless DC and AC (50/60 or 400Hz) voltages. Trimlines are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based and shipboard applications. They are well suited for applications when it is desirable to have air exit tangentially from a thin blower package and high pressure to volume ratio performance is required. |
JFG & JFGV |
The Premairprop model 10” diameter propeller fans has been developed to deliver more airflow at a higher velocity than the other products in its class. Models are available with airflow in either axial direction and with 50/60 and 400 Hz AC motors. The fan is operable at ambient temperatures of -55C to 70C and will meet all of the necessary requirements of military specification MIL-B-23071. In addition, Rotron can supply Navy standard vibration mounts, 11M15, which can be connected to the device and meet the requirements of MIL-STD-740, enabling the device to reduce structure borne noise. The Premairprop is recommended for ground, radar systems and shipboard applications, but like other Propeller fans they provide flushing cooling air through large enclosures such as radio cabinets, instrument panels, and communication equipment shelters. |
Low Speed Warning Detector (LSWD) |
The Low Speed Warning Detector (LSWD) utilizes a programmable frequency switch capable of turning “on” or “off” a load such as a LED, audible alarm, back-up fan, etc., at a predetermined motor RPM. If fan speed falls below the preset value, the back-up or warning device is activated. Once fan speed exceeds the preset value, it is de-activated. The RPM value is preset at the factory to 33% of the nominal speed of the motor but can be set to any RPM desired. The preset value has a tolerance of ± 25%. |
MAGNUM |
The new Magnum™ 170 series of tubeaxial fans from AMETEK Rotron offers the highest proven performance to size ratio in a commercial grade fan, delivering twice the static pressure of similarly sized fans. The lightweight, compact fans are ideally suited for electronic cooling in servers, routers, electronics and telecom racks. The 48VDC high-performance Magnum 170 weights only 2.4 lbs. (988 grams) but delivers 365 CFM free delivery. It has an operating voltage range of 36 to 75VDC and is UL, CSA and TUV certified. It also features solid-state circuitry, electronic commutation, locked rotor shut down protection, low-speed warning shut down, automatic restart and optional fan performance (speed) sensor. The I2C version of the Magnum 170 weighs only 2.1 lbs. (952 grams) and delivers an airflow of 512 CFM free delivery. The I2C version offers microprocessor controlled circuitry with an isolated 2-wire I2C/SMBus digital interface. It features closed-loop speed control over its entire operating voltage range and nine-user selectable addresses along with locked rotor shut down protection and fuse protection for safety. |
MF & MFV |
MF model 5.5” diameter propeller fans allow for high airflows at low static pressures with low motor-winding temperature rise. Models are available with airflow in either axial direction and with 50/60 and 400 Hz AC or brushless DC motors. Propeller fans are recommended for flushing cooling air through large enclosures such as radio cabinets, instrument panels, and communication equipment shelters. |
MIL-80 |
The MIL 80, like other compact tubeaxial fans, is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient propeller, with no further space sacrificed for the AC induction drive motor or the brushless DC motor with internal drive electronics. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
MIL-901 |
The AC MIL 901 is designed to meet the high shock requirements of MIL-S-901. Like other compact tubeaxial fans, it is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted bearing system construction the axial length of the fan is limited to the minimum measurement required by the highly efficient propeller, with no further space sacrificed for the AC induction drive motor. The MIL 901 brushless DC motor version is capable of speeds in excess of 6,000 RPM. Like other compact tubeaxial fans, it is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted bearing system construction the axial length of the fan is limited to the minimum measurement required by the highly efficient propeller, with no further space sacrificed for the brushless DC motor and internal drive electronics. MIL 901 fans are designed for use in electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications. The AC drivern option is specifically designed to withstand U.S. Navy MIL-S-901 shock levels and provide quiet operation where packaging allows air to move freely. The Brushless DC driven fan is also suitable for certain non-military applications due to its ability to operate at speeds in excess of 6000 RPM. |
MIL-901T |
The MIL 901T (1.5 in. thin) is designed to meet the high shock requirements of MIL-S-901. Like other compact tubeaxial fans, it is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted bearing system construction the axial length of the fan is limited to the minimum measurement required by the highly efficient propeller, with no further space sacrificed for the AC induction drive motor. MIL 901 fans are designed for use in electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications. It is specifically designed to withstand U.S. Navy MIL-S-901 shock levels and provide quiet operation where packaging allows air to move freely. |
MINIMAX |
The Minimax fan, like other vaneaxial fans, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. These high speed fans achieve maximum performance and minimum size with the unique inverted AC induction motor. The Minimax is noted for the excellent reliability of its miniature bearing system. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
Maxiax 3.00 - 13.80 |
MAXIAX® fans provide relatively high flows against high impedance in a compact axial flow package. They operate at high rotational speeds, typically with 400 Hz motors or internal ECDC brushless motors. MAXIAX fans are extremely efficient and highly customizable, allowing for precise airflow design. MAXIAX® fans are typically utilized to cool airborne radar and other devices with high power transmitters. They are also employed as evaporator/condenser fans in environmental controls systems and to duct air to various aircraft avionics bays, cockpit displays and cabin compartments, MAXIAX fans are also used extensively in general aviation aircraft, military vehicles and shelters and shipboard applications. |
Model R Type 201 Radial |
Model R simplex radial blade blowers (2") are compact, sturdy, and relatively light in weight, designed for development of high static pressures. Simplex blowers have a single impeller wheel and are available for either clockwise or counterclockwise rotation. As with all radial blade blowers, air enters axially and exits tangentially, making a 90 degree turn. Models are available with 50/60 or 400 Hz AC or brushless DC motors. Radial blade blowers produce a higher pressure-to-volume ratio at higher speeds than is obtainable from the centrifugal blower. it particularly suitable for cooling tightly packaged airborne electronic equipment and ventilating NBC protection system filters and particle separators. |
Model R Type 3501 Radial |
Model R simplex radial blade blowers (3.5") are compact, sturdy, and relatively light in weight, designed for development of high static pressures. Simplex blowers have a single impeller wheel and are available for either clockwise or counterclockwise rotation. As with all radial blade blowers, air enters axially and exits tangentially, making a 90 degree turn. Models are available with 50/60 or 400 Hz AC or brushless DC motors. Radial blade blowers produce a higher pressure-to-volume ratio at higher speeds than is obtainable from the centrifugal blower. it particularly suitable for cooling tightly packaged airborne electronic equipment and ventilating NBC protection system filters and particle separators. |
Model R Type 4501 Radial |
Model R simplex radial blade blowers (4.5") are compact, sturdy, and relatively light in weight, designed for development of high static pressures. Simplex blowers have a single impeller wheel and are available for either clockwise or counterclockwise rotation. As with all radial blade blowers, air enters axially and exits tangentially, making a 90 degree turn. Models are available with 50/60 or 400 Hz AC or brushless DC motors Radial blade blowers produce a higher pressure-to-volume ratio at higher speeds than is obtainable from the centrifugal blower. it particularly suitable for cooling tightly packaged airborne electronic equipment and ventilating NBC protection system filters and particle separators. |
NANOS II |
The Nanos II fan, our smallest vaneaxial, has both aerodynamic impeller blades and stationary guide vanes to enhance static pressure efficiency. These high speed fans achieve maximum performance and minimum size with the unique inverted AC induction motor. The Nanos II fan is noted for its one inch cube size. Aximax vaneaxial fans are designed for use in tightly packaged airborne "black-boxes" where sizes and weight must be held to an absolute minimum, where reliability is critical, and where high heat loads must be dissipated with cooling air. |
NF, NFV & NFG |
NF model 6.5” diameter propeller fans allow for high airflows at low static pressures with low motor-winding temperature rise. Models are available with airflow in either axial direction and with 50/60 and 400 Hz AC or brushless DC motors Propeller fans are recommended for flushing cooling air through large enclosures such as radio cabinets, instrument panels, and communication equipment shelters. |
PROPIMAX 2 |
The Propimax 2 is Rotron’s most axially compact tubeaxial fan and is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient 2-blade propeller, with no further space sacrificed for the AC induction drive motor or the Brushless DC drive electronics which are internally mounted unless high power requirements demand an external mounting configuration. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
PROPIMAX 3 |
The Propimax 3B is one of the most axially compact tubeaxial fans and is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient 4-blade propeller, with no further space sacrificed for the AC induction drive motor or the Brushless DC motor. DC drive electronics may be internal or external depending on the power requirements. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
SAUCER |
The Saucer fan, like other compact tubeaxial fans, is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient 3-blade propeller, with no further space sacrificed for the AC induction drive motor or the brushless DC motor and internal drive electronics. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
SPARTAN |
The Spartan, like other compact tubeaxial fans, is equipped with an aerodynamic venturi configured case. Utilizing the unique Rotron inverted motor construction the axial length of the fan is limited to the minimum measurement required by the highly efficient propeller, with no further space sacrificed for the AC induction drive motor or the brushless DC motor with internal drive electronics. Tubeaxial fans are compact and quiet designs for cooling electronic enclosures under severe environmental conditions in airborne, ground based, and shipboard applications where air can move freely with low static pressure. |
联系我们
办公地址:北京市海淀区永丰中路58号
电话: +86-10-89655255
传真: +86-10-51601221/52781449
Email: info@sumasemi.com
邮编:100094
门市地址:北京市海淀区中关村大街28-1号中海园电子市场BB-035
电话: +86-10-51601221
Email: hp.ma@sumasemi.com
邮编: 100086
