orcad 10.5 仿真变压器问题
ERROR -- Subcircuit TWA used by X_U1 is undefined
请各位大侠帮忙啊
全部回复(3)
pspice
**** 02/14/06 09:58:54 ******* PSpice 10.5.0 (Jan 2005) ******* ID# 2089878865
** Profile: "SCHEMATIC1-12V"  [ D:\ORCADEXERCISE、pspicefiles\schematic1\12v.sim ]
****     CIRCUIT DESCRIPTION
** Creating circuit file "12V.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\OrCAD\OrCAD_10.5\tools\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.OP
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source BEIJING12V
C_C5         0 N02754  1u
R_R6         0 N123010  0.2
V_V2         N05358 0
+PULSE 0V 12V 0 20n 20n 3.3u 1.32u
V_V1         N01118 0 48Vdc
X_D3         N15082 0 N02159 MBR20050CT
R_R2         0 N02754  61
M_M1         N04794 N05314 N123010 N123010 IRF740
R_R3         N05358 N05314  100
L_L1         N02159 N02754  55uH
C_C1         N013650 N17868  2n
C_C4         N02754 0  22u
C_C2         N04794 N013650  2n
R_R5         N10880 N02159  510
X_U1         N17868 N04794 N15082 0 TWA PARAMS:  NP=14 RSP=0.0132677 NS1=9
+  RSS1=0.00879993 GAP=0
R_R4         N01118 N17868  0.1
C_C3         0 N10880  330p
**** RESUMING 12V.cir ****
.END
orcad10.5 的解决办法如下:但是我试过多次都未解决???
Subcircuit used by is undefined
Copyright© 1985-2005 Cadence Design Systems, Inc.
The identified subcircuit is not defined in either the circuit file or any of the referenced libraries.
Solution
1 Check for correct spelling of the model name.
2 If necessary, add the name of the library in which it can be found.
pspice
@pspice
****02/14/0609:58:54*******PSpice10.5.0(Jan2005)*******ID#2089878865**Profile:"SCHEMATIC1-12V"  [D:\ORCADEXERCISE、pspicefiles\schematic1\12v.sim]****    CIRCUITDESCRIPTION********************************************************************************Creatingcircuitfile"12V.cir"**WARNING:THISAUTOMATICALLYGENERATEDFILEMAYBEOVERWRITTENBYSUBSEQUENTSIMULATIONS*Libraries:*ProfileLibraries:*LocalLibraries:*From[PSPICENETLIST]sectionofC:\OrCAD\OrCAD_10.5\tools\PSpice\PSpice.inifile:.lib"nom.lib"*Analysisdirectives:.OP.PROBEV(alias(*))I(alias(*))W(alias(*))D(alias(*))NOISE(alias(*)).INC"..\SCHEMATIC1.net"****INCLUDINGSCHEMATIC1.net*****sourceBEIJING12VC_C5        0N02754  1u  R_R6        0N123010  0.2  V_V2        N053580  +PULSE0V12V020n20n3.3u1.32uV_V1        N01118048VdcX_D3        N150820N02159MBR20050CTR_R2        0N02754  61  M_M1        N04794N05314N123010N123010IRF740R_R3        N05358N05314  100  L_L1        N02159N02754  55uH  C_C1        N013650N17868  2n  C_C4        N027540  22u  C_C2        N04794N013650  2n  R_R5        N10880N02159  510  X_U1        N17868N04794N150820TWAPARAMS:  NP=14RSP=0.0132677NS1=9+  RSS1=0.00879993GAP=0R_R4        N01118N17868  0.1  C_C3        0N10880  330p  ****RESUMING12V.cir****.ENDERROR--SubcircuitTWAusedbyX_U1isundefinedorcad10.5的解决办法如下:但是我试过多次都未解决???SubcircuitusedbyisundefinedCopyright©1985-2005CadenceDesignSystems,Inc.Theidentifiedsubcircuitisnotdefinedineitherthecircuitfileoranyofthereferencedlibraries.Solution1Checkforcorrectspellingofthemodelname.2Ifnecessary,addthenameofthelibraryinwhichitcanbefound.Copyright©1985-2005CadenceDesignSystems,Inc.
问题解决,原来没有添加库文件
@pspice
问题解决,原来没有添加库文件
库文件要添加在哪个文件夹下面呢?
