寻三层绝缘线规格
求一份三层绝缘线的规格,就是线径。铜线和外径的规格,方便计算设计变压器。谢谢!
全部回复(6)
A standard type wire in TEX-E series, is made up of a conductor and three insulation layers of modified polyester and thermal resistant resin. This was designed and developed to aid solderability and eliminating the need for stripping. |
Nominal conductor diameter (mm) |
Tolerance (mm) |
Typical overall diameter (mm) |
Maximum overall diameter (mm) |
Maximum conductor resistance ( ![]() |
Unit Weight (kg/km) |
0.20
±0.008
0.400
0.417
607.6
0.398
0.21
±0.008
0.410
0.427
549.0
0.431
0.22
±0.008
0.420
0.437
498.4
0.465
0.23
±0.008
0.430
0.447
454.5
0.500
0.24
±0.008
0.440
0.457
416.2
0.537
0.25
±0.008
0.450
0.467
382.5
0.575
0.26
±0.010
0.460
0.477
358.4
0.616
0.27
±0.010
0.470
0.487
331.4
0.656
0.28
±0.010
0.480
0.497
307.3
0.697
0.29
±0.010
0.490
0.507
285.7
0.742
0.30
±0.010
0.500
0.520
262.9
0.786
0.32
±0.010
0.520
0.540
230.3
0.882
0.35
±0.010
0.550
0.570
191.2
1.033
0.37
±0.010
0.570
0.590
170.6
1.143
0.40
±0.010
0.600
0.625
145.3
1.316
0.45
±0.010
0.650
0.675
114.2
1.633
0.50
±0.010
0.700
0.725
91.43
1.985
0.55
±0.020
0.750
0.775
78.15
2.371
0.60
±0.020
0.800
0.825
65.26
2.793
0.65
±0.020
0.850
0.875
55.31
3.249
0.70
±0.020
0.900
0.925
47.47
3.741
0.75
±0.020
0.950
0.975
41.19
4.267
0.80
±0.020
1.000
1.030
36.08
4.829
0.85
±0.020
1.050
1.080
31.87
5.425
0.90
±0.020
1.100
1.130
28.35
6.056
0.95
±0.020
1.150
1.180
25.38
6.721
1.00
±0.030
1.200
1.230
23.33
7.422
(Reference Values) |
Note: All the above values are shown just for reference and may differ slightly from batch to batch. |
