在protel 99se中,如何表示在整个铜皮上覆上焊锡,因为是要流经大电流的铜皮,所以要覆上焊锡,但是小弟找了半天也没有相关的操作,是不是要在电路板的旁边标注一下??
恳请大家给与指教!!谢谢大家了!!
寻求帮助(关于protel 99se)
全部回复(6)
@lj_healthy
怎么没有人回呢,自己顶一下了,
1.在options...中设定,勾选Top solder和Bottom solder;点击确定
2.假若要在顶层覆上焊锡,就把层切换到Top solder,依次点击Place-Polygon Plane...出现设置窗口.在Net Options中选择要上锡的网络,当设定:Track Width大于Grid Size时,上锡成整体即没有网格.500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/40/1144813795.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/40/1144814018.gif');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/40/1144814114.gif');}" onmousewheel="return imgzoom(this);">
@稻垣政昭
1.在options...中设定,勾选Topsolder和Bottomsolder;点击确定2.假若要在顶层覆上焊锡,就把层切换到Topsolder,依次点击Place-PolygonPlane...出现设置窗口.在NetOptions中选择要上锡的网络,当设定:TrackWidth大于GridSize时,上锡成整体即没有网格.[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/40/1144813795.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/40/1144814018.gif');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/40/1144814114.gif');}"onmousewheel="returnimgzoom(this);">
Solder mask layers 不是 阻焊层吗?
而 Paste Mask 才是 锡膏防护层呀 ,是不是给整反了呀?
还有我现在要覆上焊锡的地方就是一个个方形区域,是不是也可以直接在Paste Mask所在的层上直接用矩形工具给覆上去就可以了呢?
@稻垣政昭
我还想问一个问题,就是假如按照您上面所说的那样子加工出来的板子,厂商是直接给覆上焊锡呢,还是标识出来的那个地方不加阻焊剂直接是一个铜皮等着用户自己上焊锡呢?
