上传一份完整的SPWM code in C,旨在提高国人的设计水平
* Filename: MAIN.C
* Author: Dave Karipides
* Company: APS, Inc.
* Date: 3-3-97
* Compiled Using MPLAB-C Rev 1.21
* Description: The main routine calls all the functions for generating
* an OPEN_LOOP or FEEDBACK sine wave of either 50 or 60 Hz.
* main()
* Description: The main routine initializes the registers and loops
* forever.  All control is handled in the TMR0 INT
* routine.
* Input Variables: NONE
* Output Variables: NONE
//#define OPEN_LOOP
#define FEEDBACK
//#define 50Hz
#define 60Hz
#pragma option v
#include <17c43.h>
#include
#include
#ifdef OPEN_LOOP
// This table yields Full VRMS input
unsigned char const pwmtab[32]={0,25,50,74,98,120,142,162,180,197,212,
225,235,244,250,254,255,254,250,244,235,
225,212,197,180,162,142,120,98,74,50,25};
#endif
#ifdef FEEDBACK
// This table yields slightly less than Full VRMS input
unsigned char const pwmtab[32]={0,20,40,60,79,97,114,131,145,159,171,
181,189,197,202,205,206,205,202,197,189,
181,171,159,145,131,114,97,79,60,40,20};
#endif
long read_ad(unsigned char); // Prototype for A/D converter function
unsigned char index; // Index into the sinewave reference table
unsigned char sign; // Flag used to unfold sinewave reference table
long reference; // Value of the sinewave refrence after unfolding
unsigned char reference_lo  @ reference; // V1.21 of Compiler does not type cast unsigned
// char to long so we will write to low byte separately
long out_volt; // Magnitude of the output voltage;
long y; // Variables used in compensation routine
long yold;
long x;
long xold;
long ad_value; // A/D Converter Value
void main(void)
CLRWDT();
PORTC = 0; // Zero out portc latches
DDRC = 0x22; // Set up Data direction register for C
DDRB = 0; // Set up Data direction register for B
PR1 = 0xFF; // Setup PR1 register (24.4Khz @ 25Mhz clk)
PW1DCL = 0; // Set low bits of PWM to 0
PW1DCH = 0; // Init PWM duty cycle to 0
T0STA = 0x20; // Configure Timer0 prescaler
INTSTA.T0IE = 1; // Enable Timer 0 interrupt
TCON1.TMR1CS = 0;
TCON1.T16 = 0;
TCON2.TMR1ON = 1; // Start timer 1 (PWM timer)
TCON2.PWM1ON = 1; // Turn on the PWM
CPUSTA.GLINTD = 0; // Unmask the interrupts
index = 0; // Initialize variables
sign = 0;
y = 0;
yold = 0;
x = 0;
xold = 0;
PORTC.0 = 1; // Enable the Inverter
while(1); // Loop forever, execute in INT Routine
#ifdef FEEDBACK
__TMR0() // Timer  interrupt
T0STA.T0CS = 0; // Stop timer
PORTB.7=1;
#ifdef 60Hz
TMR0L=0xA5;
TMR0H=0xF9; // Make Timer0 interrupt at 3.84KHz for 60Hz output
#endif
#ifdef 50Hz
TMR0L=0x5F; // Make Timer0 interrupt at 3.20KHz for 50Hz output
TMR0H=0xF8;
#endif
T0STA.T0CS = 1; // Start timer
CLRWDT();
reference = 0; // Clear Reference Value
reference_lo = pwmtab[index]; // Lookup the value of the sinewave reference
if (!index) // Toggle Sign Every Cycle Through table
sign = ~sign;
++index; // Increment index
if (index == 32) // If end of table, reset counter
index = 0;
if (sign) // If negative going wave
reference = ~reference; // V1.21 of Compiler negate (-ref) doesn't work for
reference = reference + 1;// ref<=0
ad_value = read_ad(0);
out_volt = ad_value - 512; // Read output voltage (512 counts=0 volts out)
// Form the expression y = yold + (0.09261 * (x + xold))
// Where yold, xold is the value of y, x from the previous sample
// x is the , formed by the difference between the output
// of the inverter and the reference signal.
x = out_volt - reference;
y = ((x + xold) * 24);
y = y / 256;
y = y + yold;
if (y >= 0)
PORTC.2 = 0; // Set positive going cycle
} else
PORTC.2 = 1; // Set negative going cycle
y = ~y;
y = y + 1;
if (y > 255)
y = 255; // Limit y
PW1DCH = y; // Update duty cycle
xold = x; // Store previous sample's state
yold = y;
PORTB.7=0;
#endif
#ifdef OPEN_LOOP
// The inverter runs in an open loop mode with OPEN_LOOP defined.
#ifdef 60Hz
TMR0L=0xA5;
TMR0H=0xF9; //Make Timer0 interrupt at 3.84KHz for 60Hz output
#endif
#ifdef 50Hz
TMR0L=0x5F; //Make Timer0 interrupt at 3.20KHz for 50Hz output
TMR0H=0xF8;
#endif
T0STA.T0CS=1; //Start timer
CLRWDT();
PW1DCH = pwmtab[index];
if (!index)
PORTC.0 = 0; // Gate Drive off
PORTC.2 = ~PORTC.2; // Flip Pos/Neg bit
PORTC.0 = 1; // Gate Drive on
++index;
if (index == 32)
index = 0;
PORTC.3 = ~PORTC.3; // Toggle bit to test freq.
#endif
long read_ad(unsigned char channel)
long result;
PORTC.6 = 1; // Write bit high
PORTC.7 = 1; // Read bit high
PORTC.4 = 1; // Chip select high
DDRD = 0; // Make PORTD an output
PORTD = 0x04; // Single ended mode signed 10 bit chan 0 Right justified
PORTC.4 = 0; // Select chip
PORTC.6 = 0; // latch command word int A/D
PORTC.6 = 1; // Start conversion
PORTC.4 = 1; // Deselect chip
while (PORTC.5); // Wait for conversion to complete
DDRD = 0xFF; // Make PORTD an input
PORTC.7 = 0; // Read high byte
*( ((unsigned char*)&result) + 1) = PORTD;
PORTC.7 = 1;
PORTC.4 = 1;
PORTC.4 = 0;
PORTC.7 = 0; // Read low byte
*( ((unsigned char*)&result) ) = PORTD;
PORTC.7 = 1;
PORTC.4 = 1; // Reset chip select lines
return (result); // Return data
全部回复(259)
zack
转帖海魄兄的话:
各位朋友,我以前在交友\同僚转帖过一个网友讲的故事,希望在这里再次提起,希望能给我们启发,在以前的北美洲,送牛奶的把灌满牛奶的奶瓶放到到每家订牛奶的客户家的收牛奶的地方以后,经常会有两种鸟来偷食,其中一种是红嘴鸟,一种是麻雀.后来送牛奶的人就想了个办法,把灌满牛奶的瓶口用锡箔包上,这样就不会被鸟偷食了.可是过了几年以后,麻雀就用嘴把锡箔弄破了继续偷吃牛奶.而红嘴鸟至今还无法偷吃到牛奶.为什么麻雀可以而红嘴鸟不可以呢?有关研究人员对这个现象进行了研究,结论是,因为麻雀是群居,偶尔有一只发现了可以有新的办法吃到牛奶就会告诉其它麻雀,而红嘴鸟却不是,每个个体都是单独行动.我希望我们在国内从事UPS的技术人员能够从这个小的故事得到启发,来到这里的每位朋友不论资历高底,希望大家能真正的从技术角度出发,共同交流共同学习,共同促进,那样才能缩短我们和国外的技术差距.
这份源代码希望大家提出看法,我的设计基本上源自此处.
I hope the inverter field R&Ds in our country can get help from this code  and become more and more experience and skills in MCU software design.
I hope our engineers would have more and more creativity,not just except copy there is olny copy!
zack
想必有人知道这份代码的出处可是为什么在论坛这么久,就看不到有人帖出呢?好晕啊!
而,对于那些只会叫给代码一份,图纸一份的朋友,你们有没有真正地做到努力去提高自己的技术水平呢?
而,有写真正有水平的老师们,一些技术没什么好保留的,在国外那些都已经很落后了.
hwhpcb
@zack
想必有人知道这份代码的出处可是为什么在论坛这么久,就看不到有人帖出呢?好晕啊!而,对于那些只会叫给代码一份,图纸一份的朋友,你们有没有真正地做到努力去提高自己的技术水平呢?而,有写真正有水平的老师们,一些技术没什么好保留的,在国外那些都已经很落后了.
顶!
@zack
严重同意!顶!UP!
@zack
看到这些,我想起一个不沾边的事实,中国的足球为什么老踢不好,恐怕就是缺乏团队意识,我们搞技术的国人似乎也是如此,宁愿把东西窝霉也不愿意拿出来,我觉得可以建立一个真正大家把自己的资源共享出来以提高大家水平的板块.
zack
这是一份查表法输出SPWM的程序!是完整的,希望对大家有帮助!
lcwell
@zack
ding  国人要自强啊,团结就是力量
@zack
转帖海魄兄的话:各位朋友,我以前在交友\同僚转帖过一个网友讲的故事,希望在这里再次提起,希望能给我们启发,在以前的北美洲,送牛奶的把灌满牛奶的奶瓶放到到每家订牛奶的客户家的收牛奶的地方以后,经常会有两种鸟来偷食,其中一种是红嘴鸟,一种是麻雀.后来送牛奶的人就想了个办法,把灌满牛奶的瓶口用锡箔包上,这样就不会被鸟偷食了.可是过了几年以后,麻雀就用嘴把锡箔弄破了继续偷吃牛奶.而红嘴鸟至今还无法偷吃到牛奶.为什么麻雀可以而红嘴鸟不可以呢?有关研究人员对这个现象进行了研究,结论是,因为麻雀是群居,偶尔有一只发现了可以有新的办法吃到牛奶就会告诉其它麻雀,而红嘴鸟却不是,每个个体都是单独行动.我希望我们在国内从事UPS的技术人员能够从这个小的故事得到启发,来到这里的每位朋友不论资历高底,希望大家能真正的从技术角度出发,共同交流共同学习,共同促进,那样才能缩短我们和国外的技术差距.这份源代码希望大家提出看法,我的设计基本上源自此处.IhopetheinverterfieldR&Dsinourcountrycangethelpfromthiscode  andbecomemoreandmoreexperienceandskillsinMCUsoftwaredesign.Ihopeourengineerswouldhavemoreandmorecreativity,notjustexceptcopythereisolnycopy!
怎么我一点也看不懂的.指教一下好吗?
zack
@liyuanlinups
怎么我一点也看不懂的.指教一下好吗?
你有什么地方不明白的,请提出问题...
zack
纵观整个论谈,我觉得这份资料是最有价值的,最有实际意义的.
版主加精哦.
1146653668.pdf
wybpower
谢谢!这是三相的马,用在DSP中可不可以
wybpower
@zack
纵观整个论谈,我觉得这份资料是最有价值的,最有实际意义的.版主加精哦.1146653668.pdf
为啥下载不了
zack
@wybpower
为啥下载不了
zack
@wybpower
为啥下载不了
???为什么我上传了不能下载?
zack
@zack
zack
@wybpower
为啥下载不了
我试过了,可以下!
无私奉贤,非常实用的技术资料!
zack
@wybpower
当然可以!移植!关键是算法的思路
zack
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147332360.jpg');}" onmousewheel="return imgzoom(this);">
输出波形图片
zack
@zack
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/41/1147332360.jpg');}"onmousewheel="returnimgzoom(this);">输出波形图片
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147332588.jpg');}" onmousewheel="return imgzoom(this);">
zack
@zack
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/41/1147332588.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147332940.jpg');}" onmousewheel="return imgzoom(this);">
zack
@zack
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/41/1147332940.jpg');}"onmousewheel="returnimgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147333040.jpg');}" onmousewheel="return imgzoom(this);">
采用上述主代码做的EPS产品,感性电动机负载功率配比1:1
zack
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147333268.jpg');}" onmousewheel="return imgzoom(this);">
2KW容量,空载电流达0.48A
zack
这份代码可是带PID矫正的哦.
在那个.rar文件里有具体原理的设计介绍和电路原理图.
大家要认真学习,有问题尽管问.
xikun
@zack
当然可以!移植!关键是算法的思路
你好,请问如果用80c196mc产生svpwm,程序的步骤是不是跟产生spwm差不多??请问您有没有这方面的程序??可以给我参考一下吗?
我是大学本科应届生,现在做毕业设计
题目是:用80c196mc产生svpwm的变频调速系统
ipm驱动模块是用三菱的ps21255,希望能收到您的指导
我的qq:48067844
email:s_xkchen@stu.edu.cn
谢谢!
xikun
@zack
这份代码可是带PID矫正的哦.在那个.rar文件里有具体原理的设计介绍和电路原理图.大家要认真学习,有问题尽管问.
我是大学本科应届生,现在做毕业设计
我的qq:48067844
谢谢!
zack
@xikun
你好,请问如果用80c196mc产生svpwm,程序的步骤是不是跟产生spwm差不多??请问您有没有这方面的程序??可以给我参考一下吗?我是大学本科应届生,现在做毕业设计题目是:用80c196mc产生svpwm的变频调速系统ipm驱动模块是用三菱的ps21255,希望能收到您的指导我的qq:48067844email:s_xkchen@stu.edu.cn谢谢!
80c196mc已经是过时的产品了.现在的电机专用MCU 如 MOTOROLA MR系列,PIC 的dsPIC30F系列,TI的的DSP等等功能不知道强多少而且开发方便.现在学校里都是老的教材,学学基本原理还可以,要跟得上新一点点的技术就不行了.现在大学就这样,没办法,还是要靠自己啊.!
给你一份资料看看,我想很有帮助哦.
1147370266.pdf
zack
@zack
80c196mc已经是过时的产品了.现在的电机专用MCU如MOTOROLAMR系列,PIC的dsPIC30F系列,TI的的DSP等等功能不知道强多少而且开发方便.现在学校里都是老的教材,学学基本原理还可以,要跟得上新一点点的技术就不行了.现在大学就这样,没办法,还是要靠自己啊.!给你一份资料看看,我想很有帮助哦.1147370266.pdf
这份资料也有中文版的,我想看英语对你将来的发展有好处.
毕业的论文现在就是形式了,我看呢,你把这份资料翻成中文的你就可以毕业了.呵呵.
zack
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1147370742.jpg');}" onmousewheel="return imgzoom(this);">
这是我公司做的两台EPS样机,都已经过严格测试,性能价格相对与同类产品都有优势,更重要的是我们有独立的开发创新能力,可以随时不断地对产品系统优化升级!
目前,公司很小,但我们这里汇集了一批优秀尽业的软硬件工程师、结构工程师等等年轻人.我们希望与一些大公司合作电源项目的生产和研发,我们公司负责产品的研发、生产、管理.母公司只负责品牌和销售,我们双方互惠互利达到共赢的发展目的.欢迎实地考察.
有意想的请与我联系:QQ :27579653
zack
2006-05-12 02:19
@zack
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/41/1147370742.jpg');}"onmousewheel="returnimgzoom(this);">这是我公司做的两台EPS样机,都已经过严格测试,性能价格相对与同类产品都有优势,更重要的是我们有独立的开发创新能力,可以随时不断地对产品系统优化升级!目前,公司很小,但我们这里汇集了一批优秀尽业的软硬件工程师、结构工程师等等年轻人.我们希望与一些大公司合作电源项目的生产和研发,我们公司负责产品的研发、生产、管理.母公司只负责品牌和销售,我们双方互惠互利达到共赢的发展目的.欢迎实地考察.有意想的请与我联系:QQ:27579653
邮箱:zackzhangzzh@126.com
对了,我在浙江温州柳市,欢迎联系.
xikun
2006-05-12 12:31
@zack
谢谢您了,怎么下载不了?
没办法,老师指定要用80c196mc的,本来我也是想用dsp的,可是最后还是要按老师的要求做.
