参赛类型:开关电源
摘要:
传统的AC/DC变换采用二极管全桥整流,输出端直接接大容量电容滤波器,造成交流电源输入电流中含有大量谐波。谐波电流对电网有严重的危害,不仅会使电网电压发生畸变,也会浪费大量的电能。随着电源绿色化概念的提出,功率因数校正得到了广泛应用。所谓功率因数校正,就是指从电路上采取措施,使交流电源输入电流实现正弦化,并与输入电压保持同相。
该系统采用TI公司专用APFC整流控制芯片UCC28019作为控制核心,构成电压外环和电流内环的双闭环控制,构建了功率因数校正(APFC)高功率因数整流电源。其中,电流内环作用是使网侧交流输入电流跟踪电网电压的波形和相位;电压外环为输出电压控制环,外环电压调节器的输出控制内环电流调节器的增益,使输出直流电压稳定。系统采用MSP430F149单片机进行监控,完成输出电压的可调及相关测量参数显示功能,以及其它外围器件实现系统功率因数、输出电压、电流的实时测量、人机交互、输出过流保护等功能。
关键词:APFC,UCC28019,过流保护,功率因数,绿色电源
Abstract:
Traditional AC / DC full-bridge rectifier diode transform the output bulk capacitor filter directly connected, causing the AC input current contains a large number of harmonics. Harmonic current of the power of serious harm, not only the power grid voltage distortion will also waste a lot of power。 With the introduction of the concept of green power, power factor correction has been widely used. The so-called power factor correction, is that from the circuit to take measures to achieve sinusoidal AC input current technology, and with the input voltage to maintain the same phase。
Our work is a high power fator commutated power with function of Active Power Factor Correction。 The special APFC commutated control PFC chip UCC28019 is the core of this system,and the regulation is accomplished loops: The inner current loop shapes the AC input current to match waveform phase of the sinusoidal AC input voltage;The outer voltage loop regulates the output DC voltage which determines the internal gain parameters for maintaining a steady steady-state output DC voltage。The MCU MSP430F149 is designed to realize adjustable output voltage and show the sensed param parameters。eters Our system also has functions unctions Over Over-current Protection, Human Human-computer Interaction,the real time sense of output voltage、current and the power factor by using A MSP430F149 and its external MSP430F149 components。
Keyword:PFC,UCC28019,Over-currentProtection,Power Factor,Green Power
1.方案设计
1.1 总体方案设计
根据题目要求,隔离变压器输出工频电压有效值为18±3V,经桥式整流滤波后得到直流电压约为18~26V,要求输出电压范围在26~40V之间稳定可调,主电路采用BOOST电路,校正控制部分采用PFC芯片UCC28019由此可得,低压工频电先经过一个EMI网络,再进行全桥整流,通过有源功率因数校正器,使得功率因数得校正,输出电压得到稳定。单片机采样系统输入电流、电压,实现功率因数的检测;通过霍尔和电阻采样网络分别采集输出电流信号和电压信号送到单片机,实现输出电流、电压的检测。本系统要求设计为输出电压可调,并由十字型键盘设定输出值,然后通过改变电压环反馈的指令电平来改变输出直流电压。本系统中采用DA给定指令电平来控制输出直流电压。在系统调试过程中发现此方案完全可靠,并且稳定精确,完全可以实现电压的稳定可调输出。单片机在检测到输出电流超过2.5A时,发出指令电平对UCC28019进封锁并通过继电器断开主电路,当电路重新启动后检测到输出电流正常时,电路恢复完成过流保护。液晶用来显示被检测量的值和一些关键参数,辅助系统调试。
1.2 TI芯片的选择
1.2.1 APFC主控芯片的选择
鉴于设计要求,为了有效的减小高次谐波,提高系统的功率因数,本设计采用TI公司新开发的专用APFC芯片UCC28019,UCC28019是美国TI公司最新的有源功率因数校正(PFC)芯片。该芯片采用平均电流模式对功率因数进行校正,适用于宽范围通用交流输入,输出为100W至2kW的功率因数变换器。该芯片的开关频率固定(65kHz),具有峰值电流限制、软过流保护、开环检测、输入掉电保护、输出过压/欠压保护等众多系统保护功能。
1) UCC28019的引脚功能
UCC28019的引脚排列如图l所示。
各引脚功能为:
GND脚——地;
ICOMP脚——电流环路补偿,跨导电流放大器的输出端;
ISENSE脚——电感电流检测;
VINS脚——交流输入电压检测;
VCOMP脚——电压环路补偿,跨导电压误差放大器的输出端;
VSENSE脚——输出电压检测;
VCC脚——电源输入端;
GATE脚——栅极驱动输出端;
2)UCC28019内部结构和保护功能
UCC28019内部结构图如图2所示:
(1)软启动(ss)
(2)VCC脚欠压锁定(UVLO)
(3)输入掉电保护(IBOP)
(4)输出过压保护(ovP)/输出欠压保护(uw )
(5)开环保护/待机模式(OLP/Standby)
(6)过流保护
3)UCC28019的工作原理
图3所示的电路方框图简单地描述了采用UCC28019作为控制芯片的有源功率因数校正的工作原理。栅极驱动信号有电流放大器的输出信号和电压误差放大器的输出信号经脉冲宽度比较器调制而成。当系统处于稳态时,有:
由电压误差放大器和芯片内部参考电压的差值决定,均可以控制输入电流的幅值,且二者的乘积满足一定关系。当系统处于准稳态时,输出电压为定值,
也为定值,故有控制环路强迫电感电流随输入电压波形以保持升压调节。又因为 为正弦波,因此,电感平均电流同样为正弦波。
1.2.2 TLC372的选择
鉴于题目要求及本电路的特点,为了计算方便,测量功率因数可以通过测量输入电流和输入电压的相位差(设为i),再取cosi,即为功率因数。输入电流、电压信号经波形转换器得到方波信号,单片机可以通过检测两方波信号的上升沿的时间差,从而得到输入电流和输入电压的相位差j。本设计中比较器采用TI 公司生产的TLC372作为波形转换器的核心.TLC372工作电压范围广,功耗低,高输入阻抗,响应速度快,驱能力强。在实际应用中,该芯片完全满足题目要求,我们真正体会到了它优良的性能。
1.3控制方案分析及实现方案
主电路的输出直流电压信号Vo和基准电压Vr比较后,送入电压误差放大器VEA,得到VCOMP引脚电压该电压决定了GMI网络的增益和PWM比较器的参考三角波的斜率。输入电流经采样电阻转化为电压信号,电压信号经放大器放大送入GMI网络以实现输入平均电流的采样,得到的信号与三角波进行比较得到特定占空比的PWM波。特定占空比的PWM波保持输出电压稳定。
UCC28019的控制框图如图1:
