以下摘自UL1598
16.5.7 Impact conditioning
16.5.7.1 A sample of the water shield shall be mounted on the luminaire for impact conditioning. The
sample shall be subjected to a 4.1 J (3 ft·lb) impact from the steel sphere of Clause 19.21 from a vertical
distance of 775 mm (30.5 in) on any surface of the water shield that is exposed and that can be subjected
to an impact during its intended use.
1,Water shield 具体指的是什么?用作防雨和防触电保护的灯罩算不算是.
2,是不是所有的wet location luminaire都要做这个测试.
