我的电源为何不能带负载?
我用3842做了一款48V转12V的DC电源,一带负载电压只有9V,请问哪些方面会引起?知道的朋友帮帮我呀!
全部回复(5)
你的反馈太弱了.加大反馈的电流.个人意见的. 因为我也是初学的.
就是帮你定.你试试吧.
roye
取样电流电阻太大
@roye
取样电流电阻太大
同上
ning79
这个问题可多了,先检查一下有没有联错,比如连焊之类的.还有变压器有没有问题,整流管有没有倒,再就是反馈!!!
can you show your schematic?
It can be one of the following reasons:
1. The PWM driving circuit is not able to drive the transformer when on load.
2. output was connected with chips which was somewhere short.
3. Feedback control, the resistance value must be correct.
