高功率因数高效率隔离恒流驱动芯片 | ||||||||
型号 | 最大功率 | 控制方式 | 典型效率 | 调光 | 功率管 | 线性调整率 | 负载调整率 | 批量一致性 |
BP3309 | 30W | BCM,临界导通模式 | 90% @ 18W | N/A | 外置 | ±2% | ±2% | ±3% |
BP3308 | 30W | BCM,临界导通模式 | 80% @ 7W | 可控硅 | 外置 | ±3% | ±3% | ±5% |
高效率非隔离恒流驱动芯片 | ||||||||
型号 | 最大电流 | 控制方式 | 典型效率 | 调光 | 功率管 | 线性调整率 | 负载调整率 | 批量一致性 |
BP2808 | 500mA | CCM,固定关断时间 | 92% @ 18W | PWM/模拟 | 外置 | ±1% | N/A | ±5% |
BP2802 | 120mA | CCM,固定关断时间 | 90% @ 5W | N/A | 内置 | ±3% | N/A | ±5% |
BP2808B | 500mA | BCM,临界导通模式 | 92% @ 18W | PWM/模拟 | 外置 | ±1% | ±1% | ±3% |
BP2818 | 500mA | BCM,临界导通模式 | 85% @ 9W | 可控硅 | 外置 | ±3% | ±1% | ±5% |
BP2812 | 135mA | BCM,临界导通模式 | 90% @ 5W | N/A | 内置 | ±1% | ±1% | ±3% |
BP2822 | 250mA | BCM,临界导通模式 | 93% @ 18W | N/A | 内置 | ±1% | ±1% | ±3% |
高精度高效率隔离恒流驱动芯片 | ||||||||
BP3105 | 30W | DCM,断续导通模式 | 83% @ 7W | N/A | 外置 | ±2% | ±2% | ±2% |
BP3102 | 5W | DCM,断续导通模式 | 78% @ 3W | N/A | 内置 | ±3% | ±3% | ±3% |
BP3122 | 5W | DCM,断续导通模式 | 78% @ 3W | N/A | 内置 | ±3% | ±3% | ±3% |
BP3108 | 30W | DCM,断续导通模式 | 80% @ 7W | 可控硅 | 外置 | ±3% | ±3% | ±5% |
高功率因数高效率非隔离恒流驱动芯片 | ||||||||
BP2309 | 500mA | BCM,临界导通模式 | 93% @ 18W | N/A | 外置 | ±2% | ±2% | ±3% |
线性非隔离恒流驱动芯片 | ||||||||
BP5108 | 10W | 恒流源控制 | 90% @ 7W | 可控硅 | 外置 | N/A | N/A | ±3% |
低压恒流驱动芯片 | ||||||||
BP1360 | 400mA | CCM,连续导通模式 | 93% @ 3W | PWM/模拟 | 内置 | ±3% | ±3% | ±3% |
BP1361 | 650mA | CCM,连续导通模式 | 93% @ 4W | PWM/模拟 | 内置 | ±3% | ±3% | ±3% |
BP1601 | 400mA | CCM,连续导通模式 | 90% @ 6W | PWM/模拟 | 内置 | ±3% | ±3% | ±3% |
有需要相应DEMO资料的朋友请加QQ:1790746424
