1602液晶显示
小弟现在准备学习液晶显示技术,用的是51单片机,哪位大哥有液晶显示技术的初级教程吗?
多谢!!
全部回复(14)
/*SMC1602A(16*2)模拟口线接线方式
连接线图:
       |LCM-----51   | LCM-----51   | LCM------51      |
       |DB0-----P0.0 | DB4-----P0.4 | RW-------P2.1    |
       |DB1-----P0.1 | DB5-----P0.5 | RS-------P2.0    |
       |DB2-----P0.2 | DB6-----P0.6 | E--------P2.2    |
       |DB3-----P0.3 | DB7-----P0.7 | VLCD接1K电阻到GND|
#include
sbit LCM_RW=P2^1; //定义引脚
sbit LCM_RS=P2^0;
sbit LCM_E=P2^2;
#define LCM_Data P0
#define Busy    0x80 //用于检测LCM状态字中的Busy标识
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
//unsigned char code uctech[] = {"uctech"};
//unsigned char code net[] = {"uctech.icpcn.com"};
void main(void)
Delay400Ms(); //启动等待,等LCM讲入工作状态
LCMInit(); //LCM初始化
Delay5Ms(); //延时片刻(可不要)
//DisplayListChar(0, 0, "9.63_8.24");
DisplayListChar(0, 1, "123.456");
  DisplayOneChar(7,0,0x44);
  DisplayOneChar(8,0,0x46);
//DisplayOneChar(8,0,0x20);
  DisplayOneChar(9,0,0x43);
//ReadDataLCM();//测试用句无意义
while(1);
/* 写数据                                   */
/*     输入:RS=1,RW=0,E=1,D0~D7=数据,E=高脉冲     输出:无   */
ReadStatusLCM(); //检测忙
LCM_Data=WDLCM;
LCM_RS=1;
LCM_RW=0;
LCM_E=0; //若晶振速度太高可以在这后加小的延时
LCM_E=0; //延时
LCM_E=1;
/* 写指令                                   */
/*     输入:RS=0,RW=0,E=1,D0~D7=指令码,E=高脉冲     输出:无  */
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCM(); //根据需要检测忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
/* 读数据                                   */
/*     输入:RS=1,RW=1,E=1      输出:D0~D7=数据                 */
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
/*读状态 :输入:RS=0,RW=1,E=1     输出:D0~D7 状态字   */
/*   状态字说明                                        */
/*   D0~D6 当前数据地址指针的数值                      */
/*   D7  读写操作使能       1:禁止   0:允许          */
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //检测忙信号
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCM(0x08,1); //关闭显示
WriteCommandLCM(0x01,1); //显示清屏
WriteCommandLCM(0x06,1); // 显示光标移动设置
WriteCommandLCM(0x0C,1); // 显示开及光标设置
//按指定位置显示一个字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; // 算出指令码
WriteCommandLCM(X, 0); //这里不检测忙信号,发送地址码
WriteDataLCM(DData);
//按指定位置显示一串字符
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x20) //若到达字串尾则退出
   if (X <= 0xF) //X坐标应小于0xF
     DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符
     ListLength++;
     X++;
//5ms延时
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延时
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
@清风斜影
/*SMC1602A(16*2)模拟口线接线方式连接线图:      ---------------------------------------------------      |LCM-----51  |LCM-----51  |LCM------51      |      --------------------------------------------------|      |DB0-----P0.0|DB4-----P0.4|RW-------P2.1    |      |DB1-----P0.1|DB5-----P0.5|RS-------P2.0    |      |DB2-----P0.2|DB6-----P0.6|E--------P2.2    |      |DB3-----P0.3|DB7-----P0.7|VLCD接1K电阻到GND|      ---------------------------------------------------=============================================================*/#includesbitLCM_RW=P2^1;//定义引脚sbitLCM_RS=P2^0;sbitLCM_E=P2^2;#defineLCM_DataP0#defineBusy    0x80//用于检测LCM状态字中的Busy标识voidWriteDataLCM(unsignedcharWDLCM);voidWriteCommandLCM(unsignedcharWCLCM,BuysC);unsignedcharReadDataLCM(void);unsignedcharReadStatusLCM(void);voidLCMInit(void);voidDisplayOneChar(unsignedcharX,unsignedcharY,unsignedcharDData);voidDisplayListChar(unsignedcharX,unsignedcharY,unsignedcharcode*DData);voidDelay5Ms(void);voidDelay400Ms(void);//unsignedcharcodeuctech[]={"uctech"};//unsignedcharcodenet[]={"uctech.icpcn.com"};voidmain(void){Delay400Ms();//启动等待,等LCM讲入工作状态LCMInit();//LCM初始化Delay5Ms();//延时片刻(可不要)//DisplayListChar(0,0,"9.63_8.24");DisplayListChar(0,1,"123.456");  DisplayOneChar(7,0,0x44);  DisplayOneChar(8,0,0x46);//DisplayOneChar(8,0,0x20);  DisplayOneChar(9,0,0x43);//ReadDataLCM();//测试用句无意义while(1);}/*----------------------------------------------------------------*//*写数据                                  *//*    输入:RS=1,RW=0,E=1,D0~D7=数据,E=高脉冲    输出:无  *//*----------------------------------------------------------------*/voidWriteDataLCM(unsignedcharWDLCM){ReadStatusLCM();//检测忙LCM_Data=WDLCM;LCM_RS=1;LCM_RW=0;LCM_E=0;//若晶振速度太高可以在这后加小的延时LCM_E=0;//延时LCM_E=1;}/*----------------------------------------------------------------*//*写指令                                  *//*    输入:RS=0,RW=0,E=1,D0~D7=指令码,E=高脉冲    输出:无  *//*----------------------------------------------------------------*/voidWriteCommandLCM(unsignedcharWCLCM,BuysC)//BuysC为0时忽略忙检测{if(BuysC)ReadStatusLCM();//根据需要检测忙LCM_Data=WCLCM;LCM_RS=0;LCM_RW=0;LCM_E=0;LCM_E=0;LCM_E=1;}/*----------------------------------------------------------------*//*读数据                                  *//*    输入:RS=1,RW=1,E=1      输出:D0~D7=数据                *//*----------------------------------------------------------------*/unsignedcharReadDataLCM(void){LCM_RS=1;LCM_RW=1;LCM_E=0;LCM_E=0;LCM_E=1;return(LCM_Data);}/*==========================*//*读状态:输入:RS=0,RW=1,E=1    输出:D0~D7状态字  *//*  状态字说明                                        *//*  D0~D6当前数据地址指针的数值                      *//*  D7  读写操作使能      1:禁止  0:允许          *//*==========================*/unsignedcharReadStatusLCM(void){LCM_Data=0xFF;LCM_RS=0;LCM_RW=1;LCM_E=0;LCM_E=0;LCM_E=1;while(LCM_Data&Busy);//检测忙信号return(LCM_Data);}voidLCMInit(void)//LCM初始化{LCM_Data=0;WriteCommandLCM(0x38,0);//三次显示模式设置,不检测忙信号Delay5Ms();WriteCommandLCM(0x38,0);Delay5Ms();WriteCommandLCM(0x38,0);Delay5Ms();WriteCommandLCM(0x38,1);//显示模式设置,开始要求每次检测忙信号WriteCommandLCM(0x08,1);//关闭显示WriteCommandLCM(0x01,1);//显示清屏WriteCommandLCM(0x06,1);//显示光标移动设置WriteCommandLCM(0x0C,1);//显示开及光标设置}//按指定位置显示一个字符voidDisplayOneChar(unsignedcharX,unsignedcharY,unsignedcharDData){Y&=0x1;X&=0xF;//限制X不能大于15,Y不能大于1if(Y)X|=0x40;//当要显示第二行时地址码+0x40;X|=0x80;//算出指令码WriteCommandLCM(X,0);//这里不检测忙信号,发送地址码WriteDataLCM(DData);}//按指定位置显示一串字符voidDisplayListChar(unsignedcharX,unsignedcharY,unsignedcharcode*DData){unsignedcharListLength;  ListLength=0;Y&=0x1;X&=0xF;//限制X不能大于15,Y不能大于1while(DData[ListLength]>0x20)//若到达字串尾则退出  {  if(X
大哥,我只会汇编啊,这个C我看不懂.有没有汇编的啊??
zhljb
@清风斜影
好像大家都很喜欢用软件延时啊?但是在实时操作系统里这样是不现实的,为什么不利用定时器做一个内部时钟源,再来做延时?一般软件延时只能用在系统初始化的时候吧?
niquanwei
@huangxlstar
汇编的1602驱动程序如下:
1152322528.asm
@zhljb
多谢大家的支持!!请问有谁有这方面的教程吗?
zlm943213
@zhljb
我做单片机有几年,看了你的发言,我还是不明白你的意思,在程序里有延时的,如何用定时器来替代?能说具体点吗?我非常想知道,谢谢!
zhljb
@zlm943213
我的意思是说,用软件延时意味着不能执行其他非中断的操作,如果这期间需要控制其他操作怎么办?用中断吗?用定时器就不会有这个问题,使用循环扫描查看可能需要执行的操作(内部计时也是操作list中的一个),象这种需要延时的操作在执行条件中加入时间限制就可以了.
不知道我说清楚了没有?定时器是用来产生内部计时的时基的.譬如说这个程序,要产生10ms的延时,用定时器作一个1ms的定时中断,每次中断相应变量加1,在程序执行时判断到变量值到10才允许继续,否则回到主循环等待下次扫描.
其实我说的只在需要同时进行多种操作时才有用,涉及到任务调度的问题.我是在RTOS介绍中看到的.你可以找本RTOS的书看看,相信你以前一定看过不少吧?不知道你们是怎样完成实时任务调度的?可以介绍一下吗?
谢谢!
zlm943213
@zhljb
我的意思是说,用软件延时意味着不能执行其他非中断的操作,如果这期间需要控制其他操作怎么办?用中断吗?用定时器就不会有这个问题,使用循环扫描查看可能需要执行的操作(内部计时也是操作list中的一个),象这种需要延时的操作在执行条件中加入时间限制就可以了.不知道我说清楚了没有?定时器是用来产生内部计时的时基的.譬如说这个程序,要产生10ms的延时,用定时器作一个1ms的定时中断,每次中断相应变量加1,在程序执行时判断到变量值到10才允许继续,否则回到主循环等待下次扫描.其实我说的只在需要同时进行多种操作时才有用,涉及到任务调度的问题.我是在RTOS介绍中看到的.你可以找本RTOS的书看看,相信你以前一定看过不少吧?不知道你们是怎样完成实时任务调度的?可以介绍一下吗?谢谢!
我知道你所说的,平常写程序基本上也是这么写的,一般不使用延时,但是有的时候还非使用不可,比如DS1820读写操作时(这个例子可能不怎么恰当),需要等待的时间较长,毕竟延时很耗时间,这样的程序有办法使用定时器吗?或使用其它好办法?我很想知道答案,希望大家共同探讨.
zhljb
@zlm943213
我没有用过DS1820,不清楚具体情况怎么样,但是我想的话,一般对片外元件进行读写都需要延时,但是实际上延时不是为了延时而延时,只是在等待片外元件进入到可操作状态,一般当它可以进行操作的时候,都会有相应的状态标志,所以在扫描任务时检测一下应该就可以了.重申一下,我不知道DS1820是什么东东,如果说得离谱,请勿见笑.
我想了解一下DS1820的一些资料,还有你们现在用DS1820是怎样完成延时的,用软件延时吗?请指教.
zlm943213
@zhljb
我没有用过DS1820,不清楚具体情况怎么样,但是我想的话,一般对片外元件进行读写都需要延时,但是实际上延时不是为了延时而延时,只是在等待片外元件进入到可操作状态,一般当它可以进行操作的时候,都会有相应的状态标志,所以在扫描任务时检测一下应该就可以了.重申一下,我不知道DS1820是什么东东,如果说得离谱,请勿见笑.我想了解一下DS1820的一些资料,还有你们现在用DS1820是怎样完成延时的,用软件延时吗?请指教.
DS1820是单总线温度感应器,我是用软件延时对DS1820操作.
比如:DS1820读温度子程序如下
  read_ds1820()
  set_com();
  set_read_com();
  delay_ms(500);
  read_temp();
read_temp()
{unsigned char i,data_temp;
data_io=0
delay_ms(2) ;
for(i=0;i<8;i++)
   data_temp=data_io;
   data_temp<<=1;
以上的delay_ms(2)和delay_ms(500)能用定时T0延时吗?我个人认为还是用软件延时较好.你认为呢?
zhljb
@zlm943213
DS1820是单总线温度感应器,我是用软件延时对DS1820操作.比如:DS1820读温度子程序如下  read_ds1820(){  set_com();  set_read_com();  delay_ms(500);  read_temp();}read_temp(){unsignedchari,data_temp;data_io=0delay_ms(2);for(i=0;i
还是没搞清楚你加入延时的目的,是为了等待温度扫描结束,还是说采样频率只需要约2K就够了?从程序中看DS1820应该是按位送出采样温度的数值,那么你是怎么保证每次开始读的数据是一个完整的字节的第0位?还有需要问一下的是,你这个程序是不是只需要完成定时扫描温度这一项任务?如果没有别的任务,只需要读出温度再转送出去,我认为是没有问题的.
hougollen
@zhljb
我赞同你的观点,但是如果始终不够怎么办,难道需要外部时钟吗?可这样又增加了成本和体积.我觉得看你用在什么场合,如果不是对实时性要求很高的场合我觉得软件延时对于初学者来说是不错的,毕竟简单.
zhljb
@hougollen
完全同意你的意见.需要考虑用途和成本压力.对于学习来说,软件延时确实好用.
zlm943213
@zhljb
zlm943213回:
  DS1820读写操作不只这么简单,我只不过简单的写一点.因为DS1820是单总线,所以读写操作必须有时间等待(CPU等DS1820或DS1820等CPU),最长的大约1MS,我想表达的就是有没有办法使用定时查询的办法来对DS1820进行操作,而不要用死等待.
