程序小白
认证:优质创作者
所在专题目录 查看专题
RT-Thread驱动之路:stm32设备驱动开发之uart中断处理④
RT-Thread驱动之路:stm32设备驱动开发之浅析注册机制⑤
RT-Thread驱动之路:stm32设备驱动开发之SPI原理①
RT-Thread驱动之路:stm32设备驱动开发之SPI对象创建②
RT-Thread驱动之路:stm32设备驱动开发之SPI总线操作方法③
RT-Thread驱动之路:stm32设备驱动开发之HWTIMER开发①
作者动态 更多
基于TM1638驱动8位数码管设计分享
02-24 11:26
RT-Thread驱动之路: Studio创建FAL分区⑤
01-02 08:30
RT-Thread驱动之路: Studio 挂载通用SPI flash④
2024-12-23 13:41
RT-Thread驱动之路: Studio初始化SPI总线③
2024-12-17 09:05
RT-Thread驱动之路:Studio修改时钟篇②
2024-12-16 07:54
      有了SPI总线设备对象,还需要实现总线的操作方法,操作方法的函数指针定义已经在SPI总线设备框架中给出了:
 * SPI operators
struct rt_spi_ops
    rt_err_t (*configure)(struct rt_spi_device *device, struct rt_spi_configuration *configuration);
    rt_uint32_t (*xfer)(struct rt_spi_device *device, struct rt_spi_message *message);
      configure:有两个输入参数,其作用就是根据configuration配置参数配置SPI总线设备的传输数据宽度、时钟极性、时钟相位和总线速率等参数,最后调用HAL库初始化SPI总线。其stm32的实现代码如下:
 * SPI configuration structure
    rt_uint8_t mode;
    rt_uint8_t data_width;
    rt_uint16_t reserved;
    rt_uint32_t max_hz;
static rt_err_t spi_configure(struct rt_spi_device *device,
    RT_ASSERT(device != RT_NULL);
    RT_ASSERT(configuration != RT_NULL);
    struct stm32_spi *spi_drv =  rt_container_of(device->bus, struct stm32_spi, spi_bus);
    spi_drv->cfg = configuration;
    return stm32_spi_init(spi_drv, configuration);
static rt_err_t stm32_spi_init(struct stm32_spi *spi_drv, struct rt_spi_configuration *cfg)
    RT_ASSERT(spi_drv != RT_NULL);
    RT_ASSERT(cfg != RT_NULL);
    SPI_HandleTypeDef *spi_handle = &spi_drv->handle;
    if (cfg->mode & RT_SPI_SLAVE)
        spi_handle->Init.Mode = SPI_MODE_SLAVE;
    else
        spi_handle->Init.Mode = SPI_MODE_MASTER;
    if (cfg->mode & RT_SPI_3WIRE)
        spi_handle->Init.Direction = SPI_DIRECTION_1LINE;
    else
        spi_handle->Init.Direction = SPI_DIRECTION_2LINES;
    if (cfg->data_width == 8)
        spi_handle->Init.DataSize = SPI_DATASIZE_8BIT;
        spi_handle->TxXferSize = 8;
        spi_handle->RxXferSize = 8;
    else if (cfg->data_width == 16)
        spi_handle->Init.DataSize = SPI_DATASIZE_16BIT;
    else
        return RT_EIO;
    if (cfg->mode & RT_SPI_CPHA)
        spi_handle->Init.CLKPhase = SPI_PHASE_2EDGE;
    else
        spi_handle->Init.CLKPhase = SPI_PHASE_1EDGE;
    if (cfg->mode & RT_SPI_CPOL)
        spi_handle->Init.CLKPolarity = SPI_POLARITY_HIGH;
    else
        spi_handle->Init.CLKPolarity = SPI_POLARITY_LOW;
    if (cfg->mode & RT_SPI_NO_CS)
        spi_handle->Init.NSS = SPI_NSS_HARD_OUTPUT;
    else
        spi_handle->Init.NSS = SPI_NSS_SOFT;
    if (HAL_SPI_Init(spi_handle) != HAL_OK)
        return RT_EIO;
      当你需要更换MCU的时候,你就需要重写上述的驱动部分代码了。接下来看下xfer:用于传输数据,通过xger方法对SPI总线的控制来完成一条message的传输,这里的传输肯能是双向的 也可能是单向的,也就是所谓的单双工,最终都是通过stm32的hal库来实现,直接看代码:
static rt_uint32_t spixfer(struct rt_spi_device *device, struct rt_spi_message *message)
    HAL_StatusTypeDef state;
    rt_size_t message_length, already_send_length;
    rt_uint16_t send_length;
    rt_uint8_t *recv_buf;
    const rt_uint8_t *send_buf;
    RT_ASSERT(device->bus != RT_NULL);
    RT_ASSERT(device->bus->parent.user_data != RT_NULL);
    RT_ASSERT(message != RT_NULL);
    struct stm32_hw_spi_cs *cs = device->parent.user_data;
    if (message->cs_take && !(device->config.mode & RT_SPI_NO_CS))
        HAL_GPIO_WritePin(cs->GPIOx, cs->GPIO_Pin, GPIO_PIN_RESET);
    while (message_length)
        /* calculate the start address */
        already_send_length = message->length - send_length - message_length;
        send_buf = (rt_uint8_t *)message->send_buf + already_send_length;
        recv_buf = (rt_uint8_t *)message->recv_buf + already_send_length;
        /* start once data exchange in DMA mode */
        if (message->send_buf && message->recv_buf)
            if ((spi_drv->spi_dma_flag & SPI_USING_TX_DMA_FLAG) && (spi_drv->spi_dma_flag & SPI_USING_RX_DMA_FLAG))
                state = HAL_SPI_TransmitReceive_DMA(spi_handle, (uint8_t *)send_buf, (uint8_t *)recv_buf, send_length);
            else
                state = HAL_SPI_TransmitReceive(spi_handle, (uint8_t *)send_buf, (uint8_t *)recv_buf, send_length, 1000);
        else if (message->send_buf)
            if (spi_drv->spi_dma_flag & SPI_USING_TX_DMA_FLAG)
                state = HAL_SPI_Transmit_DMA(spi_handle, (uint8_t *)send_buf, send_length);
            else
                state = HAL_SPI_Transmit(spi_handle, (uint8_t *)send_buf, send_length, 1000);
            if (message->cs_release && (device->config.mode & RT_SPI_3WIRE))
                /* release the CS by disable SPI when using 3 wires SPI */
                __HAL_SPI_DISABLE(spi_handle);
        else
            memset((uint8_t *)recv_buf, 0xff, send_length);
            if (spi_drv->spi_dma_flag & SPI_USING_RX_DMA_FLAG)
                state = HAL_SPI_Receive_DMA(spi_handle, (uint8_t *)recv_buf, send_length);
            else
                /* clear the old error flag */
                __HAL_SPI_CLEAR_OVRFLAG(spi_handle);
                state = HAL_SPI_Receive(spi_handle, (uint8_t *)recv_buf, send_length, 1000);
        if (state != HAL_OK)
            LOG_I("spi transfer error : %d", state);
            message->length = 0;
            spi_handle->State = HAL_SPI_STATE_READY;
        else
            LOG_D("%s transfer done", spi_drv->config->bus_name);
        while (HAL_SPI_GetState(spi_handle) != HAL_SPI_STATE_READY);
    if (message->cs_release && !(device->config.mode & RT_SPI_NO_CS))
        HAL_GPIO_WritePin(cs->GPIOx, cs->GPIO_Pin, GPIO_PIN_SET);
    return message->length;
      这里删减了一些不影响函数主要功能的代码,主要体现函数的功能,根据message中recv_buf和send_buf判断是全双工还是半双工发送接收数据,调用hal库函数完成数据的传输,最后释放cs引脚。 最后就是完成SPI总线设备注册到操作系统中,需要定义rt_spi_ops来完成初始化时注册借口中的ops参数:
static const struct rt_spi_ops stm_spi_ops =
    .configure = spi_configure,
    .xfer = spixfer,
static int rt_hw_spi_bus_init(void)
    rt_err_t result;
    for (int i = 0; i < sizeof(spi_config) / sizeof(spi_config[0]); i++)
        spi_bus_obj[i].config = &spi_config[i];
        spi_bus_obj[i].spi_bus.parent.user_data = &spi_config[i];
        spi_bus_obj[i].handle.Instance = spi_config[i].Instance;
        result = rt_spi_bus_register(&spi_bus_obj[i].spi_bus, spi_config[i].bus_name, &stm_spi_ops);
        RT_ASSERT(result == RT_EOK);
        LOG_D("%s bus init done", spi_config[i].bus_name);
    return result;
          到这里就是关于SPI驱动部分的核心代码讲解完毕了,当然还有attach、DMA、SPI_IRQHandler部分源码没有详细的罗列,这一部分就交给对驱动感兴趣的小伙伴去源码里探索吧。
赞 5
收藏 6
关注 147
  • chaochao1545 01-02 08:41
    对我很有帮助
