![](http://u.dianyuan.com/bbs/u/46/1161219373.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
长: 80mm
宽: 40mm
高: 22mm
产品编号输入电压范围输出电压电流外壳WATT 防护开发状况
XX-XXX-1A 恒压恒流可调节AC DC MIN-MAX MIN-MAX LOAD CASE DEVELOP
DD-36-340-1A ● ● 8.5-16V 12-36V 340mA ± 2.5% ABS 12w IP68 OK
DD-36-100-1A ● ● 8.5-16V 12-36V 100 ±8mA ABS 3.6W IP68 OK
DD-24-700-1A ● ● 8.5-16V 12-24V 700mA ± 2.5% ABS 18w IP68 OK
DD-24-340-1A ● ● 8.5-16V 12-24V 340mA ± 2.5% ABS 8.5w IP68 OK
DD-12-11-1A ● ● 15-30V 12V 0.85A max ABS 10w IP68 OK
DD-12-700-1D ● ● 15-30V 2.5-12V 700mA ± 2.5% ABS 8.5w IP68 OK
DD-12-340-1D ● ● 15-30V 1.0-12V 340mA ± 2.5% ABS 4w IP68 OK
DD-12-100-1D ● ● 15-30V 1.0-12V 100 ± 8mA ABS 1.2w IP68 OK
DD-3.3-07-1A ● ● 8-30V 3.3V 2.0A max ABS 7w IP68 OK
LED灯具电源:XXXXX-3A糸列
![](http://u.dianyuan.com/bbs/u/46/1161219412.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
长: 80mm
宽: 40mm
高: 22mm
XX-XXX-3A 恒压恒流可调节AC DC MIN-MAX MIN-MAX LOAD CASE
CC-12-340-3A ● ● 90-264V 2.5-12V 340mA ± 2.5% ABS 4w IP68 OK
CC-12-700-3A ● ● 90-264V 2.5-12V 700mA ± 2.5% ABS 8.5w IP68 OK
CC-24-340-3A ● ● 90-264V 2.5-24V 340mA ± 2.5% ABS 8.5w IP68 OK
LED灯具电源:XXXXX-4A糸列
![](http://u.dianyuan.com/bbs/u/46/1161219439.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
长: 98mm
宽: 35mm
高: 27mm
CC-XX-XXX-4A 恒压恒流可调节AC DC MIN-MAX MIN-MAX LOAD CASE max
CC-36-340-4A ● ● 90-264V 12-36V 340mA ± 2.5% ABS 12w IP68 OK
CC-36-100-4A ● ● 90-264V 8-36V 100 ±8mA ABS 3.6w IP68 OK
CC-24-340-4A ● ● 90-264V 2.5-24V 340mA ± 2.5% ABS 8.5w IP68 OK
CC-12-700-4A ● ● 90-264V 2.5-12V 700mA ± 2.5% ABS 8.5w IP68 OK
