我开发了DC12 DC20V/4A升压模块(图),找合作开发销售的投资商
俺的非隔离型电源模块!升压输出20V/4A,不用变压器!!!输入为DC9-18V,输出DC20V/4A,效率90%.请大家指正!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162814529.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
带笔记本的照片
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162962955.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162962987.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
系统正在启动
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963046.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
看清楚了!!!电池可是拿掉了的,技术人员绝对不能打诳语!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963128.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
已进入系统!!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1162963162.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(42)
pi-power
顶!!!
nc965
@pi-power
顶!!!
汽车电瓶在发动时一般有15、6伏,应该可以直接带笔记本了吧,你试试
@nc965
汽车电瓶在发动时电压在9V左右,起动后为13.8V
pi-power
@人在天涯
这不是应用于汽车的!!
shaphone
我开发的一个项目有点类似,输入10-16.8v,输出19v,3.5A,能不能合作一下,
pi-power
@shaphone
可以合作啊
怎么合作?发邮件说吧
tujiaren1980@126.com
pi-power
@pi-power
可以合作啊怎么合作?发邮件说吧tujiaren1980@126.com
顶!!!!顶!!!!顶!!!!顶!!!!
zb3674204
@pi-power
各位:我是一名开关电源开发工程师,目前在深圳,可以为各位兼职开发各种开关电源,及技术服务.TEL:13424288341.
nc965
@zb3674204
兼职开发? 呵呵, 厉害
pi-power
pi-power
@pi-power
顶得好啊 顶得妙啊
大家顶啊!!
pi-power
@pi-power
顶得好啊顶得妙啊大家顶啊!!
大家都有很成熟的产品???
拿出来看看,都学习学习嘛!!!
pi-power
@pi-power
大家都有很成熟的产品???拿出来看看,都学习学习嘛!!!
我可以给大家批量做这款模块,价格相当低!!
pi-power
@pi-power
pi-power
新的模块方案:
DC12V TO 5V/20A方案样板  体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164807544.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 5V/10A方案样板  体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164807861.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 12V/3A 7V/3A方案样板  体积:58*50*14 半砖左右
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164808002.gif');}" onmousewheel="return imgzoom(this);">
DC12V TO 24V/6A方案样板 体积:50*30*14
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164808090.gif');}" onmousewheel="return imgzoom(this);">
请大家关注!!
pi-power
@pi-power
新的模块方案:DC12VTO5V/20A方案样板  体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164807544.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO5V/10A方案样板  体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164807861.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO12V/3A7V/3A方案样板  体积:58*50*14半砖左右[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164808002.gif');}"onmousewheel="returnimgzoom(this);">DC12VTO24V/6A方案样板体积:50*30*14[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/47/1164808090.gif');}"onmousewheel="returnimgzoom(this);">请大家关注!!
请大家关注!!
pi-power
@pi-power
大家看看实际的样板
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165338298.jpg');}" onmousewheel="return imgzoom(this);">
左边是30*50MM 的DCDC模块
参数为 DC7-18V输入 16V/3A输出 纹波50mV
左边是33*77MM 的DCDC模块
参数为 DC7-18V输入 16V/3A+5V/3A输出 纹波50mV
pi-power
@pi-power
大家看看实际的样板[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165338298.jpg');}"onmousewheel="returnimgzoom(this);">左边是30*50MM的DCDC模块参数为DC7-18V输入16V/3A输出纹波50mV左边是33*77MM的DCDC模块参数为DC7-18V输入16V/3A+5V/3A输出纹波50mV
30*50MM 的DCDC模块
DC7-18V输入 5V/10A输出 纹波30mV
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165488152.gif');}" onmousewheel="return imgzoom(this);">
powerhui
@pi-power
30*50MM的DCDC模块DC7-18V输入5V/10A输出纹波30mV[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165488152.gif');}"onmousewheel="returnimgzoom(this);">
充笔记本的移动电源我早就做出来了,已经量产
你个人做,还是给公司做,我们可以探讨,
E-MAIL:LIAOJIHUI@126.COM
pi-power
@powerhui
充笔记本的移动电源我早就做出来了,已经量产你个人做,还是给公司做,我们可以探讨,E-MAIL:LIAOJIHUI@126.COM
请大家关注!!
pi-power
@pi-power
请大家关注!!
30*50MM 的DCDC模块
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165765675.jpg');}" onmousewheel="return imgzoom(this);">
@pi-power
30*50MM的DCDC模块DC7-18V输入5V/10A输出纹波30mV[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165765675.jpg');}"onmousewheel="returnimgzoom(this);">
其实这种DC-DC电源很多厂都会做?不要在这里吹,没人理你.????????????????????????????????????????????????????????????????????????
pi-power
@hezaofen2008
是啊
我不是吹
我是让大家来指导一下!
你不要有什么心里包袱!!
pi-power
@pi-power
是啊我不是吹我是让大家来指导一下!你不要有什么心里包袱!!
DC12TO5V/3A 效率95% 体积20X26X7.5MM
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1165938988.jpg');}" onmousewheel="return imgzoom(this);">
pi-power
@pi-power
DC12TO5V/3A效率95%体积20X26X7.5MM[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1165938988.jpg');}"onmousewheel="returnimgzoom(this);">
请大家关注!!
pi-power
@pi-power
请大家关注!!
顶!!顶!!
pi-power
@pi-power
顶!!顶!!
车载的 5V/4A 电源 带线
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1167027128.jpg');}" onmousewheel="return imgzoom(this);">
pi-power
12V4A样板(输入电压7-36V,效率90%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551489.jpg');}" onmousewheel="return imgzoom(this);">
3.3V/3A样板(输入电压9-16V,效率92%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551525.jpg');}" onmousewheel="return imgzoom(this);">
16V/3A+5V/3A样板 带ITPS功能和单片机电源管理  非常适合于车载!!(输入电压7-16V,效率91%)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/49/1169551603.jpg');}" onmousewheel="return imgzoom(this);">
请大家提意见!!
hammer
2007-01-24 22:03
@pi-power
12V4A样板(输入电压7-36V,效率90%)[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/49/1169551489.jpg');}"onmousewheel="returnimgzoom(this);">3.3V/3A样板(输入电压9-16V,效率92%)[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/49/1169551525.jpg');}"onmousewheel="returnimgzoom(this);">16V/3A+5V/3A样板带ITPS功能和单片机电源管理  非常适合于车载!!(输入电压7-16V,效率91%)[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/49/1169551603.jpg');}"onmousewheel="returnimgzoom(this);">请大家提意见!!
SB!
pi-power
2007-02-02 23:25
@pi-power
双路输出模块
IN:9-36V
OUT1:12V/3A(Vp-p 35mv)  OUT2:7V/3A(Vp-p 35mv)
体积:54*58*10mm  两块板结构.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/50/1170429735.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/50/1170429778.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/50/1170429797.jpg');}" onmousewheel="return imgzoom(this);">
