输入: AC85V-265V 50Hz
输出三组: 1、 DC +90V 0.35A
2、 DC +5V 0.2A
3、 DC -90V 0.35A
单端反激拓扑,磁心用EFD30,采用Top227控制,工作频率100KHz
变压器参数:
PRI:70T/0.45mm(分內外35+35T繞線)
SEC1(+90V):50T/0.36mm
sec2(-90v):50T/0.36mm
sec3(5v):3T/0.25mm
Bias(12v):7T/0.25mm.......TL431+光耦
LP=355uH
GAP約1.80mm
现在出现了带负载就不断重起的情况,不知是什么原因,请PI工程师帮忙分析!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164353511.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
带负载时D极的波形!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164354171.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
空载时D极的波形.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164354554.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
空载时D极的波形.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164354748.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
空载时S极的波形.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164354850.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
空载时D极的波形.
请教PI工程师:开关电源带负载为何重起?
全部回复(22)
@powerint_lnk
波行不正常,看看你的原理图,PCB图.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164379405.gif');}" onmousewheel="return imgzoom(this);">
@powerint_lnk
波行不正常,看看你的原理图,PCB图.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/47/1164414916.gif');}" onmousewheel="return imgzoom(this);">
@powerint_emi
D极波形是Vds波形吗!Vds波形就不是这样的,我现在问你几个问题:问题1:空载输出正常吗?问题2:加载详细情况?问题3:软启动有没有加?
回答PI工程师的问题:
我根据哪天一个PI工程师的建议,把主稳压移到了+90V上,用PC817+88.7V的稳压管,其余的没取反馈!
1:空载的时候5V输出测量有7.2V左右(这个没多大的问题,我用78L05稳压就可以了),+90V的输出为99V,-90V的输出有132V,应该说都不正常!
2:5V输出加载时,输出5.2V,基本正常(没用7805),90V能加到2000欧的负载(由于没有电子负载仪,用大功率水泥电阻做的负载),输出电压在96V左右.-90V情况和90V差不多,只是输出电压在100V左右!全部加负载的时候,正负90V两端加2000欧也会出现输出电压跳,只有每边加3000欧的时候,输出才会稳定!(我用的是老式的20MHz示波器,600V 1*10探头 )
3:由于我最新的方案里去掉了TL431,所以软启动电容也去掉了,不过在输入端加了一个NTC做保护和软启动!
麻烦帮忙分析一下!
麻烦帮忙分析一下!
@powerint_top
看你漏极电压测试的波形不对啊.是仪器有问题还是你测量错误.空载电压对的话,一路一路加负载,先加5v的.然后再加90v的.要保证90v输出的整流管反向恢复时间足够快.另外,如果有电流探头,最好监测一下漏极电流的波形.再检查一下变压器极性有没有绕错.
我用的是老式的20MHz示波器,600V 1*10探头,测量时我就是用探头接TOP227的D极,地线悬空!不知有没错?条件不好,没有电流探头!
输出整流管用的是高效整流管HER208,加负载的情况我在上面14帖介绍了.
至于变压器的极性,我认为应该没错!上面有我的原理图和PCB图,为了保险起见,麻烦你到上面的图纸里帮我核对一下!
谢谢!
谢谢!
@powerint_top
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/48/1164979424.jpg');}" onmousewheel="return imgzoom(this);">
我测量AC220V电源的输入端其中一个是正常的正弦波,另一个就是这个波形!
两边的波峰和波谷都有一个向下凹进去的脉冲
输出电压跳的时候就是这个凹进去的波形往里面拉得太厉害,从而使D极有那个尖峰的!
我不知道是怎么回事?能否帮忙分析?
我不知道是怎么回事?能否帮忙分析?
@心中有冰
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/48/1164979424.jpg');}"onmousewheel="returnimgzoom(this);">我测量AC220V电源的输入端其中一个是正常的正弦波,另一个就是这个波形!两边的波峰和波谷都有一个向下凹进去的脉冲输出电压跳的时候就是这个凹进去的波形往里面拉得太厉害,从而使D极有那个尖峰的!我不知道是怎么回事?能否帮忙分析?
实在是怪事?!
@心中有冰
检查一下你次级的滤波电容规格是否正确,容量够不够大.是否受损.
@心中有冰
关注中...
