F28027在CCS中的ADC模块的程序在调试时改不了寄存器的值,这是为什么呢??应该已经使能ADC模块了的。
附源程序:
#include "DSP28x_Project.h"
interrupt void tim0_isr(void);
interrupt void ADC_convered(void);
Uint16 ADCINA0_Voltage_sum = 0;
Uint16 ADCINA1_Voltage_sum = 0;
Uint16 ADCINA2_Voltage_sum = 0;
Uint16 ADCINA0_Voltage = 0;
Uint16 ADCINA1_Voltage = 0;
Uint16 ADCINA2_Voltage = 0;
char convered_count = 0;
void main(void)
InitSysCtrl();
InitGpio();
DINT;
InitPieCtrl();
IER = 0x0000; IFR = 0x0000;
InitPieVectTable();
InitAdc();
EALLOW;
AdcRegs.ADCSAMPLEMODE.bit.SIMULEN0 = 0; //SOC0、SOC1单一采样
AdcRegs.ADCSAMPLEMODE.bit.SIMULEN2 = 0; //SOC2、SOC3单一采样
AdcRegs.ADCSOC0CTL.bit.CHSEL=0; //SOC通道选择
AdcRegs.ADCSOC1CTL.bit.CHSEL=1;
AdcRegs.ADCSOC2CTL.bit.CHSEL=2;
AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; //采样时间
AdcRegs.ADCSOC1CTL.bit.ACQPS = 6;
AdcRegs.ADCSOC2CTL.bit.ACQPS = 6;
AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 1; //soc触发选择,TIM0
AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //结果存入寄存器才产生中断
PieVectTable.ADCINT1 = &ADC_convered;
AdcRegs.INTSEL1N2.bit.INT1SEL = 2; //中断线1选择soc2
AdcRegs.INTSEL1N2.bit.INT1CONT = 0;
AdcRegs.INTSEL1N2.bit.INT1E = 1; //中断使能
PieCtrlRegs.PIEIER1.bit.INTx1 = 1; //使能int1.1 EDIS;
/****************设置定时器,用以触发ADC*****************/
CpuTimer0Regs.TPR.bit.TDDR = 59;
CpuTimer0Regs.TPRH.bit.TDDRH = 0; //对输入时钟60分频,60M/60=1M
CpuTimer0Regs.PRD.all = 500000;//定时0.5s
CpuTimer0Regs.TCR.bit.TRB = 1; //reload
CpuTimer0Regs.TCR.bit.TIE = 1; //使能中断
CpuTimer0Regs.TCR.bit.TSS = 0; //开始计数
EALLOW; PieVectTable.TINT0 = &tim0_isr;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1; //使能PIE
PieCtrlRegs.PIEIER1.bit.INTx7 = 1; //使能int1.7
IER |= 0x0001;//使能GROUP1
EINT;
EDIS;
{ //LED_toggle(LED2);
ADCINA0_Voltage_sum += AdcResult.ADCRESULT0;
ADCINA1_Voltage_sum += AdcResult.ADCRESULT1;
ADCINA2_Voltage_sum += AdcResult.ADCRESULT2;
AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
convered_count++;
/*********转换16次,取平均值*********/
if(convered_count > 15)
{ ADCINA0_Voltage = ADCINA0_Voltage_sum >> 4;//相当于除以16
ADCINA1_Voltage = ADCINA1_Voltage_sum >> 4;
ADCINA2_Voltage = ADCINA2_Voltage_sum >> 4;
convered_count = 0; }
{ PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; }
// No more.
