ICEL的薄膜电容器资料谁有啊,谢谢.看英文不是很懂
the fitting of capacitors on PCBs and their arrangements in equipments lay-outs with touching bodies or body faces in contact one with the other must be absolutely avoided, expecially if capacitors are positioned in rows ,one above the other.
这句话看的我有点晕啊,我的理解和现实中不对啊,请大家帮忙下啊.谢谢
全部回复(6)
Two factors weigh heavily against the effectiveness of scientific research in industry. One is the general atmosphere of secrecy in which it is carried out, the other the lack of freedom of the individual research worker.
   In so far as any inquiry is a secret one, it naturally limits all those engaged in carrying it out from effective contact with their fellow scientists either in other countries or in universities, or even, oftherenough, in other departments of the same firm. The degree of secrecy naturally varies considerably Some of the bigger firms are engaged in researches which are of such general and fundamental nature that it is a positive advantage to them not to keep them secret. Yet a great many processes depending on such research are sought for with complete secrecy until the stage at which patents can be taken out.
@青春之歌
Twofactorsweighheavilyagainsttheeffectivenessofscientificresearchinindustry.Oneisthegeneralatmosphereofsecrecyinwhichitiscarriedout,theotherthelackoffreedomoftheindividualresearchworker.  Insofarasanyinquiryisasecretone,itnaturallylimitsallthoseengagedincarryingitoutfromeffectivecontactwiththeirfellowscientistseitherinothercountriesorinuniversities,oreven,oftherenough,inotherdepartmentsofthesamefirm.ThedegreeofsecrecynaturallyvariesconsiderablySomeofthebiggerfirmsareengagedinresearcheswhichareofsuchgeneralandfundamentalnaturethatitisapositiveadvantagetothemnottokeepthemsecret.Yetagreatmanyprocessesdependingonsuchresearcharesoughtforwithcompletesecrecyuntilthestageatwhichpatentscanbetakenout.
Dizzy...
@星星彩虹
Dizzy...
hi
在PCB上安装电容器及在设备布线时,电容体相接触及对接是要决对避免的--尤其是在电容器成行排列时,一个电容器放于另一电容器上方(的情形).
davidliu
thefittingofcapacitorsonPCBsandtheirarrangementsinequipmentslay-outswithtouchingbodiesorbodyfacesincontactonewiththeothermustbeabsolutelyavoided,expeciallyifcapacitorsarepositionedinrows,oneabovetheother.在PCB上安装电容器及在设备布线时,电容体相接触及对接是要决对避免的--尤其是在电容器成行排列时,一个电容器放于另一电容器上方(的情形).
QQ: 541419833
MSN: liudavid@live.cn
MAIL: david--liu@126.com
翻译得不错..
