cirrus logic库存 绝对优势!
CS5340 xinsiweixin@163.com
CS4334/35/38/39 信思位:13480936839
CS5343/44 xinsiweixin@163.com
CS4344/45/46/48 信思位:13480936839
CS4362A/82A xinsiweixin@163.com
CS4398 信思位:13480936839
CS42L51
CS42L52 xinsiweixin@163.com
CS43L21 信思位:13480936839
CS44L11 xinsiweixin@163.com
CS53L21 信思位:13480936839
CS8416
CS8421
CS3001/02/11/12 xinsiweixin@163.com
CS3003/04/13/14 信思位:13480936839
CS5451A
CS5460A xinsiweixin@163.com
CS5461A 信思位:13480936839
CS5462
CS5463
CS5464
CS5466 xinsiweixin@163.com
CS5467 信思位:13480936839
CS5012A/14/16
CS5101A/02A
CS5501/03
CS5504
CS5505/06/07/08
CS5509
CS5510/11/12/13 xinsiweixin@163.com
CS5525/26 信思位:13480936839
CS5529
CS5530
CS5531/32/33/34
CS5550
CS5560/61
CS5570/71
CS5580/81
CS3301A
CS3302A xinsiweixin@163.com
CS4373A 信思位:13480936839
CS5201
CS5203
CS5204
CS5205/07
CS5321/22 xinsiweixin@163.com
CS5371A/72A 信思位:13480936839
CS5373A xinsiweixin@163.com
CS5378 信思位:13480936839
全部回复(2)
d电源IC 联系方式:13480936839   xinsiweixin@163.com
Product Description 电话:13480936839   xinsiweixin@163.com
DAK-16A AC-DC adapter
Output: 5.5 V @ 2.75 W
LinkSwitch 电话:13480936839   xinsiweixin@163.com
Samples and Complete Documentation
DAK-21A DC-DC converter
Output: 5 V @ 30 W
DPA-Switch
DAK-34 AC-DC power supply
Output: 12 V @ 30 W
TOPSwitch-GX
DAK-54 AC-DC adapter
LinkSwitch
DAK-68A PoE DC-DC Converter - Class 0
Output: 3.3 V @ 6.6 W
DPA-Switch
DAK-71A DC-DC Converter
DPA-Switch
DAK-85 AC-DC Linear Charger Replacement
Output: 6V @ 2 W
LinkSwitch-LP
DAK-89 AC-DC Adapter
Output: 6.2 V @ 2 W
LinkSwitch-XT
RDK-91 AC-DC Adapter
Output: 12 V @ 12 W
TinySwitch-III
DAK-93 AC-DC peak mode power supply
Output: 30 V @ 32 W continuous, 89 W peak (50 ms)
PeakSwitch
DAK-86 PoE DC-DC Converter - Class selectable
DPA-Switch
RDK-83 1.75 W CV Cordless Phone Adapter
85-265 VAC Input,  7.3 V,  240 mA Output
LinkSwitch-LP
RDK-131 LED Halogen Bulb Retrofit Kit
85-265 VAC Input,  3 W Output
LinkSwitch-TN
RDK-115 Multiple Output DVD, Set-top box Power Supply
Universal Input Voltage, 85-265 VAC Input,  7.5 W Output  (13W Peak)
TinySwitch-PK
RDK-128 Variable Speed Motor Drive
90-265 VAC Input,  36 W Output  (72W PeaK)
PeakSwitch
RDK-142 LCD Monitor Power Supply
90-265 VAC Input, 12 V, 2 A and 5V, 2.2A Outputs
TOPSwitch-HX
RDK-138 Non-Isolated, Dual Output Buck / Buck-Derived Power Supply
Output: 5 V, 12 V @ 1.2 W
LinkSwitch-TN
RDK-160 Three Low Power Chargers
5 V, 1 A / 5V, 700 mA / 6V, 300 mA
LinkSwitch-II
DPA-Switch Family DC-DC Converter ICs
Part Number Description
DPA422PN 10 W (36-75 VDC input)
DPA422GN 10 W (36-75 VDC input)
DPA422GN-TL 10 W (36-75 VDC input)
DPA423PN 13 W (36-75 VDC input)
DPA423GN 13 W (36-75 VDC input)
DPA423GN-TL 13 W (36-75 VDC input)
DPA423R 18 W (36 - 75 VDC input)
DPA423R-TL 18 W (36 - 75 VDC input)
DPA423SN 18 W (36 - 75 VDC input)
DPA423SN-TL 18 W (36 - 75 VDC input)
DPA424PN 24 W (36-75 VDC input)
DPA424GN 24 W (36-75 VDC input)
DPA424GN-TL 24 W (36-75 VDC input)
DPA424R 35 W (36 - 75 VDC input)
DPA424R-TL 35 W (36 - 75 VDC input)
DPA424SN 35 W (36 - 75 VDC input)
DPA424SN-TL 35 W (36 - 75 VDC input)
DPA425PN 25.5 W (36-75 VDC input)
DPA425GN 25.5 W (36-75 VDC input)
DPA425GN-TL 25.5 W (36-75 VDC input)
DPA425R 70 W (36 - 75 VDC input)
DPA425R-TL 70 W (36 - 75 VDC input)
DPA425SN 70 W (36 - 75 VDC input)
DPA425SN-TL 70 W (36 - 75 VDC input)
DPA426R 100 W (36 - 75 VDC input)
DPA426R-TL 100 W (36 - 75 VDC input)
DPA426SN 100 W (36 - 75 VDC input)
DPA426SN-TL 100 W (36 - 75 VDC input)
* SMD-8 & S-PAK Tape and reel minimum/multiple - 1000 pcs.
**  TO-263 Tape and reel minimum/multiple - 750 pcs.
LinkSwitch-TN Family (Very Low Power Off-line Power Supply ICs)
LNK302PN 63 mA (MDCM) 80 mA (CCM)
LNK302GN 63 mA (MDCM) 80 mA (CCM)
LNK302GN-TL 63 mA (MDCM) 80 mA (CCM)
LNK302DN 63 mA (MDCM) 80 mA (CCM)
LNK302DN-TL 63 mA (MDCM) 80 mA (CCM)
LNK304PN 120 mA (MDCM) 170 mA (CCM)
LNK304GN 120 mA (MDCM) 170 mA (CCM)
LNK304GN-TL 120 mA (MDCM) 170 mA (CCM)
LNK304DN 120 mA (MDCM) 170 mA (CCM)
LNK304DN-TL 120 mA (MDCM) 170 mA (CCM)
LNK305PN 175 mA (MDCM) 280 mA (CCM)
LNK305GN 175 mA (MDCM) 280 mA (CCM)
LNK305GN-TL 175 mA (MDCM) 280 mA (CCM)
LNK305DN 175 mA (MDCM) 280 mA (CCM)
LNK305DN-TL 175 mA (MDCM) 280 mA (CCM)
LNK306PN 225 mA (MDCM) 360 mA (CCM)
LNK306GN 225 mA (MDCM) 360 mA (CCM)
LNK306GN-TL 225 mA (MDCM) 360 mA (CCM)
LNK306DN 225 mA (MDCM) 360 mA (CCM)
LNK306DN-TL 225 mA (MDCM) 360 mA (CCM)
* SMD-8 Tape and reel minimum/multiple - 1000 pcs.
*** SO-8 Tape and reel minimum/multiple - 2500 pcs.
LinkSwitch-HF Family (Very Low Power Off-line Power Supply ICs)
x LNK353PN 3 W (85-265 VAC) 4 W (230 VAC)
x LNK353GN 3 W (85-265 VAC) 4 W (230 VAC)
x LNK353GN-TL 3 W (85-265 VAC) 4 W (230 VAC)
x LNK354PN 4.5 W (85-265 VAC) 5 W (230 VAC)
x LNK354GN 4.5 W (85-265 VAC) 5 W (230 VAC)
x LNK354GN-TL 4.5 W (85-265 VAC) 5 W (230 VAC)
LinkSwitch-XT Family (Very Low Power Off-Line Power Supply ICs)
LNK362PN 2.6 W (85-265 VAC) 2.8 W (230 VAC)
LNK362GN 2.6 W (85-265 VAC) 2.8 W (230 VAC)
LNK362GN-TL 2.6 W (85-265 VAC) 2.8 W (230 VAC)
LNK362DN 2.6 W (85-265 VAC) 2.8 W (230 VAC)
LNK362DN-TL 2.6 W (85-265 VAC) 2.8 W (230 VAC)
LNK363PN 4.7 W (85-265 VAC) 7.5 W (230 VAC)
LNK363GN 4.7 W (85-265 VAC) 7.5 W (230 VAC)
LNK363GN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC)
LNK363DN 4.7 W (85-265 VAC) 7.5 W (230 VAC)
LNK363DN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC)
LNK364PN 6 W (85-265 VAC) 9 W (230 VAC)
LNK364GN 6 W (85-265 VAC) 9 W (230 VAC)
LNK364GN-TL 6 W (85-265 VAC) 9 W (230 VAC)
LNK364DN 6 W (85-265 VAC) 9 W (230 VAC)
LNK364DN-TL 6 W (85-265 VAC) 9 W (230 VAC)
LinkSwitch Family (Very Low Power Off-line Power Supply ICs)
y LNK500PN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK500GN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK500GN-TL 3 W (85-265 VAC) 4 W (230 VAC)
y LNK501PN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK501GN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK501GN-TL 3 W (85-265 VAC) 4 W (230 VAC)
y LNK520PN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK520GN 3 W (85-265 VAC) 4 W (230 VAC)
y LNK520GN-TL 3 W (85-265 VAC) 4 W (230 VAC)
LinkSwitch-LP Family (Very Low Power Off-Line Power Supply ICs)
LNK562PN 1.9 W (85-265 VAC) 1.9 W (230 VAC)
LNK562GN 1.9 W (85-265 VAC) 1.9 W (230 VAC)
LNK562GN-TL 1.9 W (85-265 VAC) 1.9 W (230 VAC)
LNK562DN 1.9 W (85-265 VAC) 1.9 W (230 VAC)
LNK562DN-TL 1.9 W (85-265 VAC) 1.9 W (230 VAC)
LNK563PN 2.5 W (85-265 VAC) 2.5 W (230 VAC)
LNK563GN 2.5 W (85-265 VAC) 2.5 W (230 VAC)
LNK563GN-TL 2.5 W (85-265 VAC) 2.5 W (230 VAC)
LNK563DN 2.5 W (85-265 VAC) 2.5 W (230 VAC)
LNK563DN-TL 2.5 W (85-265 VAC) 2.5 W (230 VAC)
LNK564PN 3 W (85-265 VAC) 3 W (230 VAC)
LNK564GN 3 W (85-265 VAC) 3 W (230 VAC)
LNK564GN-TL 3 W (85-265 VAC) 3 W (230 VAC)
LNK564DN 3 W (85-265 VAC) 3 W (230 VAC)
LNK564DN-TL 3 W (85-265 VAC) 3 W (230 VAC)
LinkSwitch-II Family (Very Low Power Off-Line Power Supply ICs)
n LNK603PG 2.5 W (85-265 VAC)
n LNK603DG 2.5 W (85-265 VAC)
n LNK603DG-TL 2.5 W (85-265 VAC)
n LNK613PG 2.5 W (85-265 VAC)
n LNK613DG 2.5 W (85-265 VAC)
n LNK613DG-TL 2.5 W (85-265 VAC)
n LNK604PG 3.5 W (85-265 VAC)
n LNK604DG 3.5 W (85-265 VAC)
n LNK604DG-TL 3.5 W (85-265 VAC)
n LNK614PG 3.5 W (85-265 VAC)
n LNK614DG 3.5 W (85-265 VAC)
n LNK614DG-TL 3.5 W (85-265 VAC)
n LNK605PG 4.5 W (85-265 VAC)
n LNK605DG 4.5 W (85-265 VAC)
n LNK605DG-TL 4.5 W (85-265 VAC)
n LNK615PG 4.5 W (85-265 VAC)
n LNK615DG 4.5 W (85-265 VAC)
n LNK615DG-TL 4.5 W (85-265 VAC)
n LNK606PG 5.5 W (85-265 VAC)
n LNK606GG 5.5 W (85-265 VAC)
n LNK606GG-TL 5.5 W (85-265 VAC)
n LNK616PG 5.5 W (85-265 VAC)
n LNK616GG 5.5 W (85-265 VAC)
n LNK616GG-TL 5.5 W (85-265 VAC)
PeakSwitch Family (Enhanced, Energy Efficient, Peak Power Off-Line Power Supply ICs)
PKS603PN 9 W/25 W Pk (85-265 VAC) 13 W/32 W Pk (230 VAC)
PKS604FN 23 W/44 W Pk (85-265 VAC) 35 W/56 W Pk (230 VAC)
PKS604PN 16 W/44 W Pk (85-265 VAC) 23 W/56 W Pk (230 VAC)
PKS604YN 23 W/44 W Pk (85-265 VAC) 35 W/56 W Pk (230 VAC)
PKS605FN 30 W/58 W Pk (85-265 VAC) 46 W/79 W Pk (230 VAC)
PKS605PN 21 W/44 W Pk (85-265 VAC) 31 W/60 W Pk (230 VAC)
PKS605YN 30 W/58 W Pk (85-265 VAC) 46 W/79 W Pk (230 VAC)
PKS606FN 45 W/86 W Pk (85-265 VAC) 68 W/117 W Pk (230 VAC)
PKS606PN 25 W/46 W Pk (85-265 VAC) 35 W/66 W Pk (230 VAC)
PKS606YN 45 W/86 W Pk (85-265 VAC) 68 W/117 W Pk (230 VAC)
PKS607FN 50W/93 W Pk (85-265 VAC) 75 W/126 W Pk (230 VAC)
PKS607YN 50W/93 W Pk (85-265 VAC) 75 W/126 W Pk (230 VAC)
* Tape and reel minimum - 1K pcs.
TinySwitch Family (Low Power Off-line Power Supply ICs)
w TNY253PN 2 W (85 - 265 VAC) 4 W (100/115/230 VAC)
w TNY253GN 2 W (85 - 265 VAC) 4 W (100/115/230 VAC)
w TNY253GN-TL 2 W (85 - 265 VAC) 4 W (100/115/230 VAC)
w TNY254PN 4 W (85 - 265 VAC) 5 W (100/115/230 VAC)
w TNY254GN 4 W (85 - 265 VAC) 5 W (100/115/230 VAC)
w TNY254GN-TL 4 W (85 - 265 VAC) 5 W (100/115/230 VAC)
w TNY255PN 6.5 W (85-265 VAC) 10 W (100/115/230 VAC)
w TNY255GN 6.5 W (85-265 VAC) 10 W (100/115/230 VAC)
w TNY255GN-TL 6.5 W (85-265 VAC) 10 W (100/115/230 VAC)
w TNY256PN 10 W (85-265 VAC) 15 W (100/115/230 VAC)
w TNY256GN 10 W (85-265 VAC) 15 W (100/115/230 VAC)
w TNY256GN-TL 10 W (85-265 VAC) 15 W (100/115/230 VAC)
w TNY256YN 10 W (85-265 VAC) 15 W (100/115/230 VAC)
TinySwitch-II Family (Low Power Off-line Power Supply ICs)
w TNY263PN 4.7 W (85-265 VAC) 7.5 W (230 VAC)
w TNY263GN 4.7 W (85-265 VAC) 7.5 W (230 VAC)
w TNY263GN-TL 4.7 W (85-265 VAC) 7.5 W (230 VAC)
w TNY264PN 6 W (85-265 VAC) 9 W (230 VAC)
w TNY264GN 6 W (85-265 VAC) 9 W (230 VAC)
w TNY264GN-TL 6 W (85-265 VAC) 9 W (230 VAC)
w TNY265PN 7.5 W (85-265 VAC) 11 W (230 VAC)
w TNY265GN 7.5 W (85-265 VAC) 11 W (230 VAC)
w TNY265GN-TL 7.5 W (85-265 VAC) 11 W (230 VAC)
w TNY266PN 9.5 W (85-265 VAC) 15 W (230 VAC)
w TNY266GN 9.5 W (85-265 VAC) 15 W (230 VAC)
w TNY266GN-TL 9.5 W (85-265 VAC) 15 W (230 VAC)
w TNY267PN 12 W (85-265 VAC) 19 W (230 VAC)
w TNY267GN 12 W (85-265 VAC) 19 W (230 VAC)
w TNY267GN-TL 12 W (85-265 VAC) 19 W (230 VAC)
w TNY268PN 15 W (85-265 VAC) 23 W (230 VAC)
w TNY268GN 15 W (85-265 VAC) 23 W (230 VAC)
w TNY268GN-TL 15 W (85-265 VAC) 23 W (230 VAC)
TinySwitch-III Family (Low Power Off-line Power Supply ICs)
TNY274PN 8.5 W (85-265 VAC) 11 W (230 VAC)
TNY274GN 8.5 W (85-265 VAC) 11 W (230 VAC)
TNY274GN-TL 8.5 W (85-265 VAC) 11 W (230 VAC)
TNY275PN 11.5 W (85-265 VAC) 15 W (230 VAC)
TNY275GN 11.5 W (85-265 VAC) 15 W (230 VAC)
TNY275GN-TL 11.5 W (85-265 VAC) 15 W (230 VAC)
TNY276PN 15 W (85-265 VAC) 19 W (230 VAC)
TNY276GN 15 W (85-265 VAC) 19 W (230 VAC)
TNY276GN-TL 15 W (85-265 VAC) 19 W (230 VAC)
TNY277PN 18 W (85-265 VAC) 23.5 W (230 VAC)
TNY277GN 18 W (85-265 VAC) 23.5 W (230 VAC)
TNY277GN-TL 18 W (85-265 VAC) 23.5 W (230 VAC)
TNY278PN 21.5 W (85-265 VAC) 28 W (230 VAC)
TNY278GN 21.5 W (85-265 VAC) 28 W (230 VAC)
TNY278GN-TL 21.5 W (85-265 VAC) 28 W (230 VAC)
TNY279PN 25 W (85-265 VAC) 32 W (230 VAC)
TNY279GN 25 W (85-265 VAC) 32 W (230 VAC)
TNY279GN-TL 25 W (85-265 VAC) 32 W (230 VAC)
TNY280PN 28.5 W (85-265 VAC) 36.5 W (230 VAC)
TNY280GN 28.5 W (85-265 VAC) 36.5 W (230 VAC)
TNY280GN-TL 28.5 W (85-265 VAC) 36.5 W (230 VAC)
TinySwitch-PK Family (Very Low Power Off-Line Power Supply ICs)
TNY375PN 12 W (85-265 VAC) 16.5 W (230 VAC)
TNY375GN 12 W (85-265 VAC) 16.5 W (230 VAC)
TNY375GN-TL 12 W (85-265 VAC) 16.5 W (230 VAC)
TNY376PN 17 W (85-265 VAC) 22 W (230 VAC)
TNY376GN 17 W (85-265 VAC) 22 W (230 VAC)
TNY376GN-TL 17 W (85-265 VAC) 22 W (230 VAC)
TNY377PN 23 W (85-265 VAC) 28 W (230 VAC)
TNY377GN 23 W (85-265 VAC) 28 W (230 VAC)
TNY377GN-TL 23 W (85-265 VAC) 28 W (230 VAC)
TNY378PN 27 W (85-265 VAC) 34 W (230 VAC)
TNY378GN 27 W (85-265 VAC) 34 W (230 VAC)
TNY378GN-TL 27 W (85-265 VAC) 34 W (230 VAC)
n TNY379PN 31 W (85-265 VAC) 39 W (230 VAC)
n TNY379GN 31 W (85-265 VAC) 39 W (230 VAC)
n TNY379GN-TL 31 W (85-265 VAC) 39 W (230 VAC)
TNY380PN 35 W (85-265 VAC) 45 W (230 VAC)
TNY380GN 35 W (85-265 VAC) 45 W (230 VAC)
TNY380GN-TL 35 W (85-265 VAC) 45 W (230 VAC)
TOPSwitch Family (Off-line Power Supply ICs)
t TOP100YN 0-20 W (100/110 VAC)
t TOP101YN 15-35 W (100/110 VAC)
t TOP102YN 20-45 W (100/110 VAC)
t TOP103YN 25-55 W (100/110 VAC)
t TOP104YN 30-60 W (100/110 VAC)
t TOP200YN 5-12 W (85-265 VAC) 10-25 W (100/115/230 VAC)
t TOP201YN 0-22 W (85-265 VAC) 20-45 W (100/115/230 VAC)
t TOP202YN 15-30 W (85-265 VAC) 30-60 W (100/115/230 VAC)
t TOP203YN 20-35 W (85-265 VAC) 40-70 W (100-115/230 VAC)
t TOP204YN 30-50 W (85-265 VAC) 60-100 W (100/115/230 VAC)
t TOP209PN 2 W (85-265 VAC) 4 W (100/115/230 VAC)
t TOP209GN 2 W (85-265 VAC) 4 W (100/115/230 VAC)
t TOP209GN-TL 2 W (85-265 VAC) 4 W (100/115/230 VAC)
t TOP210PN 5 W (85-265 VAC) 8 W (100/115/230 VAC)
t TOP210GN 5 W (85-265 VAC) 8 W (100/115/230 VAC)
t TOP210GN-TL 5 W (85-265 VAC) 8 W (100/115/230 VAC)
t TOP214YN 25-42 W (85-265 VAC) 50-85 W (100/115/230 VAC)
TOPSwitch-II Family (Off-line Power Supply ICs)
t TOP221PN 6 W (85-265 VAC) 9 W (100/115/230 VAC)
t TOP221GN 6 W (85-265 VAC) 9 W (100/115/230 VAC)
t TOP221GN-TL 6 W (85-265 VAC) 9 W (100/115/230 VAC)
t TOP221YN 7 W (85-265 VAC) 12 W (100/115/230 VAC)
t TOP222PN 10 W (85-265 VAC) 15 W (100/115/230 VAC)
t TOP222GN 10 W (85-265 VAC) 15 W (100/115/230 VAC)
t TOP222GN-TL 10 W (85-265 VAC) 15 W (100/115/230 VAC)
t TOP222YN 15 W (85-265 VAC) 25 W (100/115/230 VAC)
t TOP223PN 15 W (85-265 VAC) 25 W (100/115/230 VAC)
t TOP223GN 15 W (85-265 VAC) 25 W (100/115/230 VAC)
t TOP223GN-TL 15 W (85-265 VAC) 25 W (100/115/230 VAC)
t TOP223YN 30 W (85-265 VAC) 50 W (100/115/230 VAC)
t TOP224PN 20 W (85-265 VAC) 30 W (100/115/230 VAC)
t TOP224GN 20 W (85-265 VAC) 30 W (100/115/230 VAC)
t TOP224GN-TL 20 W (85-265 VAC) 30 W (100/115/230 VAC)
t TOP224YN 45 W (85-265 VAC) 75 W (100/115/230 VAC)
t TOP225YN 60 W (85-265 VAC) 100 W (100/115/230 VAC)
t TOP226YN 75 W (85-265 VAC) 125 W (100/115/230 VAC)
t TOP227YN 90 W (85-265 VAC) 150 W (100/115/230 VAC)
TOPSwitch-FX Family (Off-line Power Supply ICs)
t TOP232PN 10 W (85-265 VAC) 15W (230 VAC)
t TOP232GN 10 W (85-265 VAC) 15W (230 VAC)
t TOP232GN-TL 10 W (85-265 VAC) 15W (230 VAC)
t TOP232YN 15 W (85-265 VAC) 25 W (230 VAC)
t TOP233PN 15 W (85-265 VAC) 25W (230 VAC)
t TOP233GN 15 W (85-265 VAC) 25W (230 VAC)
t TOP233GN-TL 15 W (85-265 VAC) 25W (230 VAC)
t TOP233YN 30 W (85-265 VAC) 50 W (230 VAC)
t TOP234PN 20 W (85-265 VAC) 30 W (230 VAC)
t TOP234GN 20 W (85-265 VAC) 30 W (230 VAC)
t TOP234GN-TL 20 W (85-265 VAC) 30 W (230 VAC)
t TOP234YN 45 W (85-265 VAC) 75 W (230 VAC)
TOPSwitch-GX Family (Off-line Power Supply ICs)
TOP242FN 10 W (85-265 VAC) 15 W (230 VAC)
TOP242PN 10 W (85-265 VAC) 15 W (230 VAC)
TOP242GN 10 W (85-265 VAC) 15 W (230 VAC)
TOP242GN-TL 10 W (85-265 VAC) 15 W (230 VAC)
TOP242R-TL 14 W (85-265 VAC) 22 W (230 VAC)
TOP242YN 14 W (85-265 VAC) 22 W (230 VAC)
TOP243FN 30 W (85-265 VAC) 45 W (230 VAC)
TOP243PN 15 W (85-265 VAC) 25W (230 VAC)
TOP243GN 15 W (85-265 VAC) 25W (230 VAC)
TOP243GN-TL 15 W (85-265 VAC) 25W (230 VAC)
TOP243R-TL 23 W (85-265 VAC) 45 W (230 VAC)
TOP243YN 30 W (85-265 VAC) 45 W (230 VAC)
TOP244FN 45 W (85-265 VAC) 65 W (230 VAC)
TOP244PN 20 W (85-265 VAC) 28 W (230 VAC)
TOP244GN 20 W (85-265 VAC) 28 W (230 VAC)
TOP244GN-TL 20 W (85-265 VAC) 28 W (230 VAC)
TOP244R-TL 28 W (85-265 VAC) 50 W (230 VAC)
TOP244YN 45 W (85-265 VAC) 65 W (230 VAC)
TOP245FN 60W (85-265 VAC) 85 W (230 VAC)
TOP245PN 22W (85-265 VAC) 30 W (230 VAC)
TOP245GN 22W (85-265 VAC) 30 W (230 VAC)
TOP245GN-TL 22W (85-265 VAC) 30 W (230 VAC)
TOP245R-TL 33W (85-265 VAC) 57 W (230 VAC)
TOP245YN 60W (85-265 VAC) 85 W (230 VAC)
TOP246FN 90 W (85-265 VAC) 125 W (230 VAC)
TOP246PN 26 W (85-265 VAC) 34 W (230 VAC)
TOP246GN 26 W (85-265 VAC) 34 W (230 VAC)
TOP246GN-TL 26 W (85-265 VAC) 34 W (230 VAC)
TOP246R-TL 38 W (85-265 VAC) 64 W (230 VAC)
TOP246YN 90 W (85-265 VAC) 125 W (230 VAC)
TOP247FN 125 W (85-265 VAC) 165 W (230 VAC)
TOP247R-TL 43 W (85-265 VAC) 70 W (230 VAC)
TOP247YN 125 W (85-265 VAC) 165 W (230 VAC)
TOP248FN 155 W (85-265 VAC) 205 W (230 VAC)
TOP248R-TL 48 W (85-265 VAC) 75 W (230 VAC)
TOP248YN 155 W (85-265 VAC) 205 W (230 VAC)
TOP249FN 180 W (85-265 VAC) 250 W (230 VAC)
TOP249R-TL 53 W (85-265 VAC) 79 W (230 VAC)
TOP249YN 180 W (85-265 VAC) 250 W (230 VAC)
TOP250FN 210 W (85-265 VAC) 290 W (230 VAC)
TOP250R-TL 55 W (85-265 VAC) 82 W (230 VAC)
TOP250YN 210 W (85-265 VAC) 290 W (230 VAC)
TOPSwitch-HX Family (Off-Line Power Supply ICs)
TOP252PN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC)
TOP252GN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC)
TOP252GN-TL 10W/13W PK (85-264V AC) 15W/21W PK (230V AC)
TOP252MN 10W/13W PK (85-264V AC) 15W/21W PK (230V AC)
TOP252EN 13W (85-264V AC) 21W (230V AC)
TOP253PN 15W/25W PK (85-264V AC) 25W/38W PK (230V AC)
TOP253GN 15W/25W PK (85-264V AC) 25W/38W PK (230V AC)
TOP253GN-TL 15W/25W PK (85-264V AC) 25W/38W PK (230V AC)
TOP253MN 15W/29W PK (85-264V AC) 25W/43W PK (230V AC)
TOP253EN 29W (85-264V AC) 43W (230V AC)
TOP254PN 20W/30W PK (85-264V AC) 28W/47W PK (230V AC)
TOP254GN 20W/30W PK (85-264V AC) 28W/47W PK (230V AC)
TOP254GN-TL 20W/30W PK (85-264V AC) 28W/47W PK (230V AC)
TOP254MN 20W/40W PK (85-264V AC) 28W/62W PK (230V AC)
TOP254YN 43W (85-264V AC) 62W (230V AC)
TOP254EN 43W (85-264V AC) 62W (230V AC)
TOP255PN 22W/35W PK (85-264V AC) 30W/54W PK (230V AC)
TOP255GN 22W/35W PK (85-264V AC) 30W/54W PK (230V AC)
TOP255GN-TL 22W/35W PK (85-264V AC) 30W/54W PK (230V AC)
TOP255MN 22W/52W PK (85-264V AC) 30W/81W PK (230V AC)
TOP255YN 57W (85-264V AC) 81W (230V AC)
TOP255EN 57W (85-264V AC) 81W (230V AC)
TOP256PN 26W/40W PK (85-264V AC) 34W/63W PK (230V AC)
TOP256GN 26W/40W PK (85-264V AC) 34W/63W PK (230V AC)
TOP256GN-TL 26W/40W PK (85-264V AC) 34W/63W PK (230V AC)
TOP256MN 26W/64W PK (85-264V AC) 34W/98W PK (230V AC)
TOP256YN 86W (85-264V AC) 119W (230V AC)
TOP256EN 86W (85-264V AC) 119W (230V AC)
TOP257PN 30W/45W PK (85-264V AC) 41W/70W PK (230V AC)
TOP257GN 30W/45W PK (85-264V AC) 41W/70W PK (230V AC)
TOP257GN-TL 30W/45W PK (85-264V AC) 41W/70W PK (230V AC)
TOP257MN 30W/78W PK (85-264V AC) 41W/119W PK (230V AC)
TOP257YN 119W (85-264V AC) 157W (230V AC)
TOP257EN 119W (85-264V AC) 157W (230V AC)
TOP258PN 35W/50W PK (85-264V AC) 48W/77W PK (230V AC)
TOP258GN 35W/50W PK (85-264V AC) 48W/77W PK (230V AC)
TOP258GN-TL 35W/50W PK (85-264V AC) 48W/77W PK (230V AC)
TOP258MN 35W/92W PK (85-264V AC) 48W/140W PK (230V AC)
TOP258YN 148W (85-264V AC) 195W (230V AC)
TOP258EN 148W (85-264V AC) 195W (230V AC)
TOP259YN 171W (85-264V AC) 238W (230V AC)
TOP259EN 171W (85-264V AC) 238W (230V AC)
TOP260YN 200W (85-264V AC) 275W (230V AC)
TOP260EN 200W (85-264V AC) 275W (230V AC)
TOP261YN 254W (85-264V AC) 333W (230V AC)
TOP261EN 254W (85-264V AC) 333W (230V AC)
TOPSwitch 41x Family (Low Power, 48 VDC Input, Power Supply ICs)
d TOP412GN 9 W (48 VDC)
d TOP412GN-TL 9 W (48 VDC)
d TOP414GN 12 W (48 VDC)
d TOP414GN-TL 12 W (48 VDC)
@xinsiweixin
d电源IC联系方式:13480936839  xinsiweixin@163.comProductDescription电话:13480936839  xinsiweixin@163.comDAK-16AAC-DCadapterOutput:5.5V@2.75WLinkSwitch电话:13480936839  xinsiweixin@163.comSamplesandCompleteDocumentationDAK-21ADC-DCconverterOutput:5V@30WDPA-SwitchSamplesandCompleteDocumentationDAK-34AC-DCpowersupplyOutput:12V@30WTOPSwitch-GXSamplesandCompleteDocumentationDAK-54AC-DCadapterOutput:5.5V@2.75WLinkSwitchSamplesandCompleteDocumentationDAK-68APoEDC-DCConverter-Class0Output:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationDAK-71ADC-DCConverterOutput:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationDAK-85AC-DCLinearChargerReplacementOutput:6V@2WLinkSwitch-LPSamplesandCompleteDocumentationDAK-89AC-DCAdapterOutput:6.2V@2WLinkSwitch-XTSamplesandCompleteDocumentationRDK-91AC-DCAdapterOutput:12V@12WTinySwitch-IIISamplesandCompleteDocumentationDAK-93AC-DCpeakmodepowersupplyOutput:30V@32Wcontinuous,89Wpeak(50ms)PeakSwitchSamplesandCompleteDocumentationDAK-86PoEDC-DCConverter-ClassselectableOutput:3.3V@6.6WDPA-SwitchSamplesandCompleteDocumentationRDK-831.75WCVCordlessPhoneAdapter85-265VACInput,  7.3V,  240mAOutputLinkSwitch-LPSamplesandCompleteDocumentationRDK-131LEDHalogenBulbRetrofitKit85-265VACInput,  3WOutputLinkSwitch-TNSamplesandCompleteDocumentationRDK-115MultipleOutputDVD,Set-topboxPowerSupplyUniversalInputVoltage,85-265VACInput,  7.5WOutput  (13WPeak)TinySwitch-PKSamplesandCompleteDocumentationRDK-128VariableSpeedMotorDrive90-265VACInput,  36WOutput  (72WPeaK)PeakSwitchSamplesandCompleteDocumentationRDK-142LCDMonitorPowerSupply90-265VACInput,12V,2Aand5V,2.2AOutputs  TOPSwitch-HXSamplesandCompleteDocumentationRDK-138Non-Isolated,DualOutputBuck/Buck-DerivedPowerSupplyOutput:5V,12V@1.2WLinkSwitch-TNSamplesandCompleteDocumentationRDK-160ThreeLowPowerChargers5V,1A/5V,700mA/6V,300mALinkSwitch-IISamplesandCompleteDocumentation电话:13480936839  xinsiweixin@163.comDPA-SwitchFamilyDC-DCConverterICsPartNumberDescriptionDPA422PN10W(36-75VDCinput)DPA422GN10W(36-75VDCinput)DPA422GN-TL10W(36-75VDCinput)DPA423PN13W(36-75VDCinput)DPA423GN13W(36-75VDCinput)DPA423GN-TL13W(36-75VDCinput)DPA423R18W(36-75VDCinput)DPA423R-TL18W(36-75VDCinput)DPA423SN18W(36-75VDCinput)DPA423SN-TL18W(36-75VDCinput)DPA424PN24W(36-75VDCinput)DPA424GN24W(36-75VDCinput)DPA424GN-TL24W(36-75VDCinput)DPA424R35W(36-75VDCinput)DPA424R-TL35W(36-75VDCinput)DPA424SN35W(36-75VDCinput)DPA424SN-TL35W(36-75VDCinput)DPA425PN25.5W(36-75VDCinput)DPA425GN25.5W(36-75VDCinput)DPA425GN-TL25.5W(36-75VDCinput)DPA425R70W(36-75VDCinput)DPA425R-TL70W(36-75VDCinput)DPA425SN70W(36-75VDCinput)DPA425SN-TL70W(36-75VDCinput)DPA426R100W(36-75VDCinput)DPA426R-TL100W(36-75VDCinput)DPA426SN100W(36-75VDCinput)DPA426SN-TL100W(36-75VDCinput)*SMD-8&S-PAKTapeandreelminimum/multiple-1000pcs.**  TO-263Tapeandreelminimum/multiple-750pcs.LinkSwitch-TNFamily(VeryLowPowerOff-linePowerSupplyICs)PartNumberDescriptionLNK302PN63mA(MDCM)80mA(CCM)LNK302GN63mA(MDCM)80mA(CCM)LNK302GN-TL63mA(MDCM)80mA(CCM)LNK302DN63mA(MDCM)80mA(CCM)LNK302DN-TL63mA(MDCM)80mA(CCM)LNK304PN120mA(MDCM)170mA(CCM)LNK304GN120mA(MDCM)170mA(CCM)LNK304GN-TL120mA(MDCM)170mA(CCM)LNK304DN120mA(MDCM)170mA(CCM)LNK304DN-TL120mA(MDCM)170mA(CCM)LNK305PN175mA(MDCM)280mA(CCM)LNK305GN175mA(MDCM)280mA(CCM)LNK305GN-TL175mA(MDCM)280mA(CCM)LNK305DN175mA(MDCM)280mA(CCM)LNK305DN-TL175mA(MDCM)280mA(CCM)LNK306PN225mA(MDCM)360mA(CCM)LNK306GN225mA(MDCM)360mA(CCM)LNK306GN-TL225mA(MDCM)360mA(CCM)LNK306DN225mA(MDCM)360mA(CCM)LNK306DN-TL225mA(MDCM)360mA(CCM)*SMD-8Tapeandreelminimum/multiple-1000pcs.***SO-8Tapeandreelminimum/multiple-2500pcs.LinkSwitch-HFFamily(VeryLowPowerOff-linePowerSupplyICs)PartNumberDescriptionxLNK353PN3W(85-265VAC)4W(230VAC)xLNK353GN3W(85-265VAC)4W(230VAC)xLNK353GN-TL3W(85-265VAC)4W(230VAC)xLNK354PN4.5W(85-265VAC)5W(230VAC)xLNK354GN4.5W(85-265VAC)5W(230VAC)xLNK354GN-TL4.5W(85-265VAC)5W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.LinkSwitch-XTFamily(VeryLowPowerOff-LinePowerSupplyICs)PartNumberDescriptionLNK362PN2.6W(85-265VAC)2.8W(230VAC)LNK362GN2.6W(85-265VAC)2.8W(230VAC)LNK362GN-TL2.6W(85-265VAC)2.8W(230VAC)LNK362DN2.6W(85-265VAC)2.8W(230VAC)LNK362DN-TL2.6W(85-265VAC)2.8W(230VAC)LNK363PN4.7W(85-265VAC)7.5W(230VAC)LNK363GN4.7W(85-265VAC)7.5W(230VAC)LNK363GN-TL4.7W(85-265VAC)7.5W(230VAC)LNK363DN4.7W(85-265VAC)7.5W(230VAC)LNK363DN-TL4.7W(85-265VAC)7.5W(230VAC)LNK364PN6W(85-265VAC)9W(230VAC)LNK364GN6W(85-265VAC)9W(230VAC)LNK364GN-TL6W(85-265VAC)9W(230VAC)LNK364DN6W(85-265VAC)9W(230VAC)LNK364DN-TL6W(85-265VAC)9W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.***SO-8Tapeandreelminimum/multiple-2500pcs.LinkSwitchFamily(VeryLowPowerOff-linePowerSupplyICs)PartNumberDescriptionyLNK500PN3W(85-265VAC)4W(230VAC)yLNK500GN3W(85-265VAC)4W(230VAC)yLNK500GN-TL3W(85-265VAC)4W(230VAC)yLNK501PN3W(85-265VAC)4W(230VAC)yLNK501GN3W(85-265VAC)4W(230VAC)yLNK501GN-TL3W(85-265VAC)4W(230VAC)yLNK520PN3W(85-265VAC)4W(230VAC)yLNK520GN3W(85-265VAC)4W(230VAC)yLNK520GN-TL3W(85-265VAC)4W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.LinkSwitch-LPFamily(VeryLowPowerOff-LinePowerSupplyICs)PartNumberDescriptionLNK562PN1.9W(85-265VAC)1.9W(230VAC)LNK562GN1.9W(85-265VAC)1.9W(230VAC)LNK562GN-TL1.9W(85-265VAC)1.9W(230VAC)LNK562DN1.9W(85-265VAC)1.9W(230VAC)LNK562DN-TL1.9W(85-265VAC)1.9W(230VAC)LNK563PN2.5W(85-265VAC)2.5W(230VAC)LNK563GN2.5W(85-265VAC)2.5W(230VAC)LNK563GN-TL2.5W(85-265VAC)2.5W(230VAC)LNK563DN2.5W(85-265VAC)2.5W(230VAC)LNK563DN-TL2.5W(85-265VAC)2.5W(230VAC)LNK564PN3W(85-265VAC)3W(230VAC)LNK564GN3W(85-265VAC)3W(230VAC)LNK564GN-TL3W(85-265VAC)3W(230VAC)LNK564DN3W(85-265VAC)3W(230VAC)LNK564DN-TL3W(85-265VAC)3W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.***SO-8Tapeandreelminimum/multiple-2500pcs.LinkSwitch-IIFamily(VeryLowPowerOff-LinePowerSupplyICs)PartNumberDescriptionnLNK603PG2.5W(85-265VAC)nLNK603DG2.5W(85-265VAC)nLNK603DG-TL2.5W(85-265VAC)nLNK613PG2.5W(85-265VAC)nLNK613DG2.5W(85-265VAC)nLNK613DG-TL2.5W(85-265VAC)nLNK604PG3.5W(85-265VAC)nLNK604DG3.5W(85-265VAC)nLNK604DG-TL3.5W(85-265VAC)nLNK614PG3.5W(85-265VAC)nLNK614DG3.5W(85-265VAC)nLNK614DG-TL3.5W(85-265VAC)nLNK605PG4.5W(85-265VAC)nLNK605DG4.5W(85-265VAC)nLNK605DG-TL4.5W(85-265VAC)nLNK615PG4.5W(85-265VAC)nLNK615DG4.5W(85-265VAC)nLNK615DG-TL4.5W(85-265VAC)nLNK606PG5.5W(85-265VAC)nLNK606GG5.5W(85-265VAC)nLNK606GG-TL5.5W(85-265VAC)nLNK616PG5.5W(85-265VAC)nLNK616GG5.5W(85-265VAC)nLNK616GG-TL5.5W(85-265VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.***SO-8Tapeandreelminimum/multiple-2500pcs.PeakSwitchFamily(Enhanced,EnergyEfficient,PeakPowerOff-LinePowerSupplyICs)PartNumberDescriptionPKS603PN9W/25WPk(85-265VAC)13W/32WPk(230VAC)PKS604FN23W/44WPk(85-265VAC)35W/56WPk(230VAC)PKS604PN16W/44WPk(85-265VAC)23W/56WPk(230VAC)PKS604YN23W/44WPk(85-265VAC)35W/56WPk(230VAC)PKS605FN30W/58WPk(85-265VAC)46W/79WPk(230VAC)PKS605PN21W/44WPk(85-265VAC)31W/60WPk(230VAC)PKS605YN30W/58WPk(85-265VAC)46W/79WPk(230VAC)PKS606FN45W/86WPk(85-265VAC)68W/117WPk(230VAC)PKS606PN25W/46WPk(85-265VAC)35W/66WPk(230VAC)PKS606YN45W/86WPk(85-265VAC)68W/117WPk(230VAC)PKS607FN50W/93WPk(85-265VAC)75W/126WPk(230VAC)PKS607YN50W/93WPk(85-265VAC)75W/126WPk(230VAC)*Tapeandreelminimum-1Kpcs.TinySwitchFamily(LowPowerOff-linePowerSupplyICs)PartNumberDescriptionwTNY253PN2W(85-265VAC)4W(100/115/230VAC)wTNY253GN2W(85-265VAC)4W(100/115/230VAC)wTNY253GN-TL2W(85-265VAC)4W(100/115/230VAC)wTNY254PN4W(85-265VAC)5W(100/115/230VAC)wTNY254GN4W(85-265VAC)5W(100/115/230VAC)wTNY254GN-TL4W(85-265VAC)5W(100/115/230VAC)wTNY255PN6.5W(85-265VAC)10W(100/115/230VAC)wTNY255GN6.5W(85-265VAC)10W(100/115/230VAC)wTNY255GN-TL6.5W(85-265VAC)10W(100/115/230VAC)wTNY256PN10W(85-265VAC)15W(100/115/230VAC)wTNY256GN10W(85-265VAC)15W(100/115/230VAC)wTNY256GN-TL10W(85-265VAC)15W(100/115/230VAC)wTNY256YN10W(85-265VAC)15W(100/115/230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TinySwitch-IIFamily(LowPowerOff-linePowerSupplyICs)PartNumberDescriptionwTNY263PN4.7W(85-265VAC)7.5W(230VAC)wTNY263GN4.7W(85-265VAC)7.5W(230VAC)wTNY263GN-TL4.7W(85-265VAC)7.5W(230VAC)wTNY264PN6W(85-265VAC)9W(230VAC)wTNY264GN6W(85-265VAC)9W(230VAC)wTNY264GN-TL6W(85-265VAC)9W(230VAC)wTNY265PN7.5W(85-265VAC)11W(230VAC)wTNY265GN7.5W(85-265VAC)11W(230VAC)wTNY265GN-TL7.5W(85-265VAC)11W(230VAC)wTNY266PN9.5W(85-265VAC)15W(230VAC)wTNY266GN9.5W(85-265VAC)15W(230VAC)wTNY266GN-TL9.5W(85-265VAC)15W(230VAC)wTNY267PN12W(85-265VAC)19W(230VAC)wTNY267GN12W(85-265VAC)19W(230VAC)wTNY267GN-TL12W(85-265VAC)19W(230VAC)wTNY268PN15W(85-265VAC)23W(230VAC)wTNY268GN15W(85-265VAC)23W(230VAC)wTNY268GN-TL15W(85-265VAC)23W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TinySwitch-IIIFamily(LowPowerOff-linePowerSupplyICs)PartNumberDescriptionTNY274PN8.5W(85-265VAC)11W(230VAC)TNY274GN8.5W(85-265VAC)11W(230VAC)TNY274GN-TL8.5W(85-265VAC)11W(230VAC)TNY275PN11.5W(85-265VAC)15W(230VAC)TNY275GN11.5W(85-265VAC)15W(230VAC)TNY275GN-TL11.5W(85-265VAC)15W(230VAC)TNY276PN15W(85-265VAC)19W(230VAC)TNY276GN15W(85-265VAC)19W(230VAC)TNY276GN-TL15W(85-265VAC)19W(230VAC)TNY277PN18W(85-265VAC)23.5W(230VAC)TNY277GN18W(85-265VAC)23.5W(230VAC)TNY277GN-TL18W(85-265VAC)23.5W(230VAC)TNY278PN21.5W(85-265VAC)28W(230VAC)TNY278GN21.5W(85-265VAC)28W(230VAC)TNY278GN-TL21.5W(85-265VAC)28W(230VAC)TNY279PN25W(85-265VAC)32W(230VAC)TNY279GN25W(85-265VAC)32W(230VAC)TNY279GN-TL25W(85-265VAC)32W(230VAC)TNY280PN28.5W(85-265VAC)36.5W(230VAC)TNY280GN28.5W(85-265VAC)36.5W(230VAC)TNY280GN-TL28.5W(85-265VAC)36.5W(230VAC)*Tapeandreelminimum-1Kpcs.TinySwitch-PKFamily(VeryLowPowerOff-LinePowerSupplyICs)PartNumberDescriptionTNY375PN12W(85-265VAC)16.5W(230VAC)TNY375GN12W(85-265VAC)16.5W(230VAC)TNY375GN-TL12W(85-265VAC)16.5W(230VAC)TNY376PN17W(85-265VAC)22W(230VAC)TNY376GN17W(85-265VAC)22W(230VAC)TNY376GN-TL17W(85-265VAC)22W(230VAC)TNY377PN23W(85-265VAC)28W(230VAC)TNY377GN23W(85-265VAC)28W(230VAC)TNY377GN-TL23W(85-265VAC)28W(230VAC)TNY378PN27W(85-265VAC)34W(230VAC)TNY378GN27W(85-265VAC)34W(230VAC)TNY378GN-TL27W(85-265VAC)34W(230VAC)nTNY379PN31W(85-265VAC)39W(230VAC)nTNY379GN31W(85-265VAC)39W(230VAC)nTNY379GN-TL31W(85-265VAC)39W(230VAC)TNY380PN35W(85-265VAC)45W(230VAC)TNY380GN35W(85-265VAC)45W(230VAC)TNY380GN-TL35W(85-265VAC)45W(230VAC)*Tapeandreelminimum-1Kpcs.TOPSwitchFamily(Off-linePowerSupplyICs)PartNumberDescriptiontTOP100YN0-20W(100/110VAC)tTOP101YN15-35W(100/110VAC)tTOP102YN20-45W(100/110VAC)tTOP103YN25-55W(100/110VAC)tTOP104YN30-60W(100/110VAC)tTOP200YN5-12W(85-265VAC)10-25W(100/115/230VAC)tTOP201YN0-22W(85-265VAC)20-45W(100/115/230VAC)tTOP202YN15-30W(85-265VAC)30-60W(100/115/230VAC)tTOP203YN20-35W(85-265VAC)40-70W(100-115/230VAC)tTOP204YN30-50W(85-265VAC)60-100W(100/115/230VAC)tTOP209PN2W(85-265VAC)4W(100/115/230VAC)tTOP209GN2W(85-265VAC)4W(100/115/230VAC)tTOP209GN-TL2W(85-265VAC)4W(100/115/230VAC)tTOP210PN5W(85-265VAC)8W(100/115/230VAC)tTOP210GN5W(85-265VAC)8W(100/115/230VAC)tTOP210GN-TL5W(85-265VAC)8W(100/115/230VAC)tTOP214YN25-42W(85-265VAC)50-85W(100/115/230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TOPSwitch-IIFamily(Off-linePowerSupplyICs)PartNumberDescriptiontTOP221PN6W(85-265VAC)9W(100/115/230VAC)tTOP221GN6W(85-265VAC)9W(100/115/230VAC)tTOP221GN-TL6W(85-265VAC)9W(100/115/230VAC)tTOP221YN7W(85-265VAC)12W(100/115/230VAC)tTOP222PN10W(85-265VAC)15W(100/115/230VAC)tTOP222GN10W(85-265VAC)15W(100/115/230VAC)tTOP222GN-TL10W(85-265VAC)15W(100/115/230VAC)tTOP222YN15W(85-265VAC)25W(100/115/230VAC)tTOP223PN15W(85-265VAC)25W(100/115/230VAC)tTOP223GN15W(85-265VAC)25W(100/115/230VAC)tTOP223GN-TL15W(85-265VAC)25W(100/115/230VAC)tTOP223YN30W(85-265VAC)50W(100/115/230VAC)tTOP224PN20W(85-265VAC)30W(100/115/230VAC)tTOP224GN20W(85-265VAC)30W(100/115/230VAC)tTOP224GN-TL20W(85-265VAC)30W(100/115/230VAC)tTOP224YN45W(85-265VAC)75W(100/115/230VAC)tTOP225YN60W(85-265VAC)100W(100/115/230VAC)tTOP226YN75W(85-265VAC)125W(100/115/230VAC)tTOP227YN90W(85-265VAC)150W(100/115/230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TOPSwitch-FXFamily(Off-linePowerSupplyICs)PartNumberDescriptiontTOP232PN10W(85-265VAC)15W(230VAC)tTOP232GN10W(85-265VAC)15W(230VAC)tTOP232GN-TL10W(85-265VAC)15W(230VAC)tTOP232YN15W(85-265VAC)25W(230VAC)tTOP233PN15W(85-265VAC)25W(230VAC)tTOP233GN15W(85-265VAC)25W(230VAC)tTOP233GN-TL15W(85-265VAC)25W(230VAC)tTOP233YN30W(85-265VAC)50W(230VAC)tTOP234PN20W(85-265VAC)30W(230VAC)tTOP234GN20W(85-265VAC)30W(230VAC)tTOP234GN-TL20W(85-265VAC)30W(230VAC)tTOP234YN45W(85-265VAC)75W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TOPSwitch-GXFamily(Off-linePowerSupplyICs)PartNumberDescriptionTOP242FN10W(85-265VAC)15W(230VAC)TOP242PN10W(85-265VAC)15W(230VAC)TOP242GN10W(85-265VAC)15W(230VAC)TOP242GN-TL10W(85-265VAC)15W(230VAC)TOP242R-TL14W(85-265VAC)22W(230VAC)TOP242YN14W(85-265VAC)22W(230VAC)TOP243FN30W(85-265VAC)45W(230VAC)TOP243PN15W(85-265VAC)25W(230VAC)TOP243GN15W(85-265VAC)25W(230VAC)TOP243GN-TL15W(85-265VAC)25W(230VAC)TOP243R-TL23W(85-265VAC)45W(230VAC)TOP243YN30W(85-265VAC)45W(230VAC)TOP244FN45W(85-265VAC)65W(230VAC)TOP244PN20W(85-265VAC)28W(230VAC)TOP244GN20W(85-265VAC)28W(230VAC)TOP244GN-TL20W(85-265VAC)28W(230VAC)TOP244R-TL28W(85-265VAC)50W(230VAC)TOP244YN45W(85-265VAC)65W(230VAC)TOP245FN60W(85-265VAC)85W(230VAC)TOP245PN22W(85-265VAC)30W(230VAC)TOP245GN22W(85-265VAC)30W(230VAC)TOP245GN-TL22W(85-265VAC)30W(230VAC)TOP245R-TL33W(85-265VAC)57W(230VAC)TOP245YN60W(85-265VAC)85W(230VAC)TOP246FN90W(85-265VAC)125W(230VAC)TOP246PN26W(85-265VAC)34W(230VAC)TOP246GN26W(85-265VAC)34W(230VAC)TOP246GN-TL26W(85-265VAC)34W(230VAC)TOP246R-TL38W(85-265VAC)64W(230VAC)TOP246YN90W(85-265VAC)125W(230VAC)TOP247FN125W(85-265VAC)165W(230VAC)TOP247R-TL43W(85-265VAC)70W(230VAC)TOP247YN125W(85-265VAC)165W(230VAC)TOP248FN155W(85-265VAC)205W(230VAC)TOP248R-TL48W(85-265VAC)75W(230VAC)TOP248YN155W(85-265VAC)205W(230VAC)TOP249FN180W(85-265VAC)250W(230VAC)TOP249R-TL53W(85-265VAC)79W(230VAC)TOP249YN180W(85-265VAC)250W(230VAC)TOP250FN210W(85-265VAC)290W(230VAC)TOP250R-TL55W(85-265VAC)82W(230VAC)TOP250YN210W(85-265VAC)290W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.**  TO-263Tapeandreelminimum/multiple-750pcs.TOPSwitch-HXFamily(Off-LinePowerSupplyICs)PartNumberDescriptionTOP252PN10W/13WPK(85-264VAC)15W/21WPK(230VAC)TOP252GN10W/13WPK(85-264VAC)15W/21WPK(230VAC)TOP252GN-TL10W/13WPK(85-264VAC)15W/21WPK(230VAC)TOP252MN10W/13WPK(85-264VAC)15W/21WPK(230VAC)TOP252EN13W(85-264VAC)21W(230VAC)TOP253PN15W/25WPK(85-264VAC)25W/38WPK(230VAC)TOP253GN15W/25WPK(85-264VAC)25W/38WPK(230VAC)TOP253GN-TL15W/25WPK(85-264VAC)25W/38WPK(230VAC)TOP253MN15W/29WPK(85-264VAC)25W/43WPK(230VAC)TOP253EN29W(85-264VAC)43W(230VAC)TOP254PN20W/30WPK(85-264VAC)28W/47WPK(230VAC)TOP254GN20W/30WPK(85-264VAC)28W/47WPK(230VAC)TOP254GN-TL20W/30WPK(85-264VAC)28W/47WPK(230VAC)TOP254MN20W/40WPK(85-264VAC)28W/62WPK(230VAC)TOP254YN43W(85-264VAC)62W(230VAC)TOP254EN43W(85-264VAC)62W(230VAC)TOP255PN22W/35WPK(85-264VAC)30W/54WPK(230VAC)TOP255GN22W/35WPK(85-264VAC)30W/54WPK(230VAC)TOP255GN-TL22W/35WPK(85-264VAC)30W/54WPK(230VAC)TOP255MN22W/52WPK(85-264VAC)30W/81WPK(230VAC)TOP255YN57W(85-264VAC)81W(230VAC)TOP255EN57W(85-264VAC)81W(230VAC)TOP256PN26W/40WPK(85-264VAC)34W/63WPK(230VAC)TOP256GN26W/40WPK(85-264VAC)34W/63WPK(230VAC)TOP256GN-TL26W/40WPK(85-264VAC)34W/63WPK(230VAC)TOP256MN26W/64WPK(85-264VAC)34W/98WPK(230VAC)TOP256YN86W(85-264VAC)119W(230VAC)TOP256EN86W(85-264VAC)119W(230VAC)TOP257PN30W/45WPK(85-264VAC)41W/70WPK(230VAC)TOP257GN30W/45WPK(85-264VAC)41W/70WPK(230VAC)TOP257GN-TL30W/45WPK(85-264VAC)41W/70WPK(230VAC)TOP257MN30W/78WPK(85-264VAC)41W/119WPK(230VAC)TOP257YN119W(85-264VAC)157W(230VAC)TOP257EN119W(85-264VAC)157W(230VAC)TOP258PN35W/50WPK(85-264VAC)48W/77WPK(230VAC)TOP258GN35W/50WPK(85-264VAC)48W/77WPK(230VAC)TOP258GN-TL35W/50WPK(85-264VAC)48W/77WPK(230VAC)TOP258MN35W/92WPK(85-264VAC)48W/140WPK(230VAC)TOP258YN148W(85-264VAC)195W(230VAC)TOP258EN148W(85-264VAC)195W(230VAC)TOP259YN171W(85-264VAC)238W(230VAC)TOP259EN171W(85-264VAC)238W(230VAC)TOP260YN200W(85-264VAC)275W(230VAC)TOP260EN200W(85-264VAC)275W(230VAC)TOP261YN254W(85-264VAC)333W(230VAC)TOP261EN254W(85-264VAC)333W(230VAC)*SMD-8Tapeandreelminimum/multiple-1000pcs.TOPSwitch41xFamily(LowPower,48VDCInput,PowerSupplyICs)PartNumberDescriptiondTOP412GN9W(48VDC)dTOP412GN-TL9W(48VDC)dTOP414GN12W(48VDC)dTOP414GN-TL12W(48VDC)
深圳市嘉之创科技有限公司是ZARLINK, LEGERITY, IR, PI.MIC的一级代理商,供应VOIP网络电话控制芯片和配套芯片LE88111 LE88221 .全新原装,供货稳定产品优惠,欢迎大家咨询与订购,提供全方位的技术支持及解决方案.ZARLINK, LEGERITY研发的VoIP芯片,它适用于SOHO的VOIP电话及VOIP网关.我司能提供完整解决方案,包括硬件电路设计与应用软件,使研发人员在最短的周期内开发出相应的VOIP产品.真正做到“低成本,全功能、完整性”的VOIP网络电话解决方案.
  0755-27909184     13480936839
