目前我司在使用Fairchild FDS6679 物料時,出現了兩種不同包裝的物料,其中有一款物料不良,影響功耗,
1.有款的Marking點為蝕刻的點
2.另外一款的Marking點為印刷的,而且不清楚,
請大家幫忙確認下,哪個是真的產品,500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/61/685561200293130.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
如何判定真假Fairchild物料
全部回复(9)
In general, Power Diss. can be impacted by Gate-Source Voltage, have you noted 6679Z and 6679, The value of "Z" is -25/+20V, but the value of "6679" and "AZ" is -25/+25V, It's hard to check out if you only review thru. the picture, because actually, Fairchild has many many suppliers and that will be different if the packing location is different;
One more, you'd better to check the requirement of your project and according it to select AZ or Z or 6679 only.
@iflove00
Ingeneral,PowerDiss.canbeimpactedbyGate-SourceVoltage,haveyounoted6679Zand6679,Thevalueof"Z"is-25/+20V,butthevalueof"6679"and"AZ"is-25/+25V,It'shardtocheckoutifyouonlyreviewthru.thepicture,becauseactually,Fairchildhasmanymanysuppliersandthatwillbedifferentifthepackinglocationisdifferent;Onemore,you'dbettertochecktherequirementofyourprojectandaccordingittoselectAZorZor6679only.
Thanks
