请教LC滤波器的设计
请教LC滤波器的设计
我想用lc滤波器将峰值300v的spwm波平滑成正弦波,请问如何设计?
spwm方波的频率为1.6k,
全部回复(8)
let me give u a hand
lc filter's transfer function is a two order system,so u can achieve it's corner frequency which should be 1/7~1/10 of your spwm frequency,
here your spwm frequency equals to switching frequency,but 1.6k is a bit low from my opinion,how to eliminate your switch noise under such a low frenquecy?
letmegiveuahandlcfilter'stransferfunctionisatwoordersystem,soucanachieveit'scornerfrequencywhichshouldbe1/7~1/10ofyourspwmfrequency,hereyourspwmfrequencyequalstoswitchingfrequency,but1.6kisabitlowfrommyopinion,howtoeliminateyourswitchnoiseundersuchalowfrenquecy?
go on
how to achieve your L and C is often up to your experience.u can get L value first,or C first,use this value to get the other varialbe's value,here below is an example:
1) C value
accordding your inverter output current maxsimum value ,caculate the current value flowing the capacitor,then use the formula C=dU/dI,so C can be achieved.
2)L value
if C has been choosed,then u can use the corner frequecy to get your L value,
corner frequecy can be depicted as following:
f=1/[2*pi*sqr(L*C)],
usually f equal to 1/5~1/10 of fs(switching frequency).
now C and f has been calulated,so use the above formula,L can be drawn out.
by the way,much experience determines your choice for this two parameters.
contact me if still any questions
morel
goonhowtoachieveyourLandCisoftenuptoyourexperience.ucangetLvaluefirst,orCfirst,usethisvaluetogettheothervarialbe'svalue,herebelowisanexample:1)Cvalueaccorddingyourinverteroutputcurrentmaxsimumvalue,caculatethecurrentvalueflowingthecapacitor,thenusetheformulaC=dU/dI,soCcanbeachieved.2)LvalueifChasbeenchoosed,thenucanusethecornerfrequecytogetyourLvalue,cornerfrequecycanbedepictedasfollowing:f=1/[2*pi*sqr(L*C)],usuallyfequalto1/5~1/10offs(switchingfrequency).nowCandfhasbeencalulated,sousetheaboveformula,Lcanbedrawnout.bytheway,muchexperiencedeterminesyourchoiceforthistwoparameters.contactmeifstillanyquestions
can u explain about c=DU/DI,for example?
tks
@morel
canuexplainaboutc=DU/DI,forexample?tks
sorry,made a mistake
i=Cdu/dt
u=Um*sin(w*t),
then,
Im=Um*C*w,
so C=Im/Um*w,
if u=Umsin(2*pi*50*t)
so,i=Um*C*2*pi*50*cos(2*pi*50*t)
Im=Um*C*2*pi*50
from the above,
C=Im/Um*2*pi*50
sorry,i can't remember clearly how to determine the value of the Im,maybe it's 1/n of the output current max value.I can tell u more if I find out where my material is
whualei
我用单片机控制
频率升不上去,定时中断受限,请问有什么好办法吗?
whualei
请问至少多大频率可以消除开关噪音
@whualei
我用单片机控制频率升不上去,定时中断受限,请问有什么好办法吗?
oh
80c196 or tms320f240x DSPs.
when I stayed in college,f240DSP was very popular,20k fs was easily acchieved as well as PWM generator.but an obvious demerit was such that the A/D converter was not very good as expected anyway.
a guy realized pure sinusoidal output with one dsp and operation amplifier(even parallel operation was acchieved).the THD is below 0.5% even with diode rectifier load. and attracted much attention ,including lite-on corp. ,and so on
jq1000110
sorry,madeamistakei=Cdu/dtu=Um*sin(w*t),then,Im=Um*C*w,soC=Im/Um*w,ifu=Umsin(2*pi*50*t)so,i=Um*C*2*pi*50*cos(2*pi*50*t)Im=Um*C*2*pi*50fromtheabove,C=Im/Um*2*pi*50sorry,ican'trememberclearlyhowtodeterminethevalueoftheIm,maybeit's1/noftheoutputcurrentmaxvalue.IcantellumoreifIfindoutwheremymaterialis
我看到一本书上取的是1/2,不过我认为可以取到1/4.
The value of the Im is 1/n of the output current max value.The number n may set to 2 to 4.I think.
