技术指标明细
Output Operating Frequency>=120Hz(不包括调光)
Transient Protection shall comply with IEEE C.62.41-1991,
Class A operation. The line transient shall consist of seven
strikes of a 100kHz ring wave, 2.5kV level, for both common
mode and differential mode.
Refer to IEEE C.62.41-1991 Recommended Practice for Surge Voltages in Low-
voltage AC Power Circuits (obsolete)
C.62.41.1.2, C.62.41.2 (new standard)
Power supply noise to in Class A sound rating (not exceed 24 dB)
Off-state power – luminaires shall not draw power in the off-state
输入电压:85-264V(220-240V必须达到,希望达到85-264V)交
流(Transient Protection C.62.41.1.2, C.62.41.2)
正常工作时的输出电流 :
a) 恒流
b) 输出电流0.4 A±5% (六串或七串1W)
输出过压保护:具有输出过压保护
工作温度:-10℃~+65℃ (散热器温度<65C)
效率:>90% PF>0.9 (ANSI C82.77)
调光100%-20% (采用市场上兼容的前波段后波段)
EMI (FCC 47 CFR)
外形尺寸:(见图纸附件一)
产品主要出口澳洲 和英国,符合CE要求.
如能提供请联系:13801899083 张先生
Email:wonder.zhang@163.com
29361206088709.doc
