1500w变压器设计,快进来看啊...
各位大佬:不知道哪位用非晶的磁心做过高频变压器,现在是有一款230V输入,142V,10A输出.半桥电路,频率为75K,有哪位高手指点一下,该怎么做,非常感谢.或者是能用锰锌材料做也可以,只要高度不超过40mm.
全部回复(22)
@ronald120
我自己顶啊,望高手们出来发句话啊...救急啊...
没做过,用pexprt帮你设计了一个,平面变压器,高度肯定满足:)
输出半波整流
| Version 5.0.09 |
| Design Constructive Results |
Design Library: Magnetics_Design
Core Size: EE46410
Core Material: R
Bobbin: None
| Winding # 1 |
| Wire: Copper_70um_6mm
| Number of Turns: 5
| Number of parallel turns: 2
| Winding # 2 |
| Wire: Copper_70um_2mm
| Number of Turns: 6
| Number of parallel turns: 4
输出半波整流
| Version 5.0.09 |
Core Size: EE46410
Core Material: R
Bobbin: None
| Winding # 1 |
| Number of Turns: 5
| Winding # 2 |
| Number of Turns: 6
没做过,用pexprt帮你设计了一个,平面变压器,高度肯定满足:)输出半波整流+------------------------------------------------------+| Version5.0.09 |+------------------------------------------------------+| DesignConstructiveResults |+------------------------------------------------------+DesignLibrary:Magnetics_DesignCoreSize:EE46410CoreMaterial:RBobbin:None+--------------------------------------+| Winding#1 |+--------------------------------------+|Wire:Copper_70um_6mm| ||NumberofTurns: 5| ||Numberofparallelturns:2+--------------------------------------++--------------------------------------+| Winding#2 |+--------------------------------------+|Wire:Copper_70um_2mm| ||NumberofTurns: 6| ||Numberofparallelturns:4+--------------------------------------+
半桥的好象做不了吧.
