从IRF下的Spice文件怎么加到ORACD中?
似乎格式不对,加入后总是出一堆东西,都不能用:(
全部回复(20)
@乞力马扎罗的雪
把文件传上来,我帮你试试.
象60N06的文件是纯文本格式,但加不进:(
p60N06.lib 用PSpice model editor 编译就不行
我的orcad是9.2版
* MODELLING FOR STP60NE06
.SUBCKT STP60NE06 1 2 3
LG 2 4 7.5n
LS 12 3 0.06n
LD 6 1 60n
RG 4 5 3.334
RS 9 12 0.241779E-03
RD 7 6 0.997720E-02
RJ 8 7 0.193733E-04
CGS 5 9 3.3e-9
CGD 7 10 6.3e-9
CK 11 7 0.26e-9
DGD 11 7 DGD
DBS 12 6 DBS
DBD 9 7 DBD
MOS 13 5 9 9 MOS L=1u W=1u
E1 10 5 101 0 1
E2 11 5 102 0 1
E3 8 13 POLY(2) 6 8 6 12 0 0 0 0 0.233220
G1 0 100 7 5 1u
D1 100 101 DID
D2 102 100 DID
R1 101 0 1MEG
R2 102 0 1MEG
.ENDS STP60NE06
.MODEL MOS NMOS
+ LEVEL = 3
+ Vmax = 437300.
+ VTO = 1.85620
+ PHI = 9.83122
+ IS = 0
+ JS = 0
+ THETA = 0.190484E-03
+ KP = 36.6700
.MODEL DGD D
+ IS =
+ CJO = 0.195319E-09
+ VJ = 2.26173
+ M = 1.13908
.MODEL DBS D
+ IS = 0.1P
+ BV = 101.035
+ N = 1
+ TT = 0.257540E-08
+ RS = 626392.
.MODEL DBD D
+ IS =
+ CJO = 0.171284E-09
+ VJ = 1.40087
+ M = 2.22347
.MODEL DID D
+ IS = 2P
+ RS = 0
+ BV = 178.658
* END OF MODELLING
我的orcad是9.2版
LG 2 4 7.5n
LS 12 3 0.06n
LD 6 1 60n
RG 4 5 3.334
RD 7 6 0.997720E-02
RJ 8 7 0.193733E-04
CGS 5 9 3.3e-9
CGD 7 10 6.3e-9
CK 11 7 0.26e-9
DGD 11 7 DGD
DBS 12 6 DBS
DBD 9 7 DBD
E1 10 5 101 0 1
E2 11 5 102 0 1
G1 0 100 7 5 1u
D1 100 101 DID
D2 102 100 DID
R1 101 0 1MEG
R2 102 0 1MEG
.ENDS STP60NE06
.MODEL MOS NMOS
+ LEVEL = 3
+ Vmax = 437300.
+ VTO = 1.85620
+ PHI = 9.83122
+ IS = 0
+ JS = 0
+ KP = 36.6700
.MODEL DGD D
+ IS =
+ VJ = 2.26173
+ M = 1.13908
.MODEL DBS D
+ IS = 0.1P
+ BV = 101.035
+ N = 1
+ TT = 0.257540E-08
+ RS = 626392.
.MODEL DBD D
+ IS =
+ VJ = 1.40087
+ M = 2.22347
.MODEL DID D
+ IS = 2P
+ RS = 0
+ BV = 178.658
* END OF MODELLING
象60N06的文件是纯文本格式,但加不进:(p60N06.lib用PSpicemodeleditor编译就不行我的orcad是9.2版*MODELLINGFORSTP60NE06.SUBCKTSTP60NE06123LG24 7.5nLS1230.06nLD61 60nRG45 3.334RS9120.241779E-03RD76 0.997720E-02RJ87 0.193733E-04CGS593.3e-9CGD7106.3e-9CK 1170.26e-9DGD117DGDDBS126DBSDBD 97DBDMOS 13599MOSL=1uW=1uE1 10510101E2 11510201E3 813POLY(2)686120000 0.233220G1 0100751uD1 100101 DIDD2 102100 DIDR1 1010 1MEGR2 1020 1MEG.ENDSSTP60NE06.MODELMOSNMOS+LEVEL=3+Vmax =437300.+VTO =1.85620+PHI =9.83122+IS =0+JS =0+THETA=0.190484E-03+KP =36.6700.MODELDGDD+IS =+CJO =0.195319E-09+VJ =2.26173+M =1.13908.MODELDBSD+IS =0.1P+BV =101.035+N =1+TT =0.257540E-08+RS =626392..MODELDBDD+IS =+CJO =0.171284E-09+VJ =1.40087+M =2.22347.MODELDIDD+IS =2P+RS =0+BV =178.658*ENDOFMODELLING
可以用.
1,打开MODEL EDITOR,打开一个已经存在的ORCADCAPTURELIBRARYPSPICE*.LIB文件(请先备份)
2,选择MODEL->COPY FROM,从你下载的文本文件中把每一项COPY过去.存盘.
3,选择FILE->CREAT PARTS.这时会生成新的OLB文件. OK了.
问题:
1,不同的ORCAD版本中,LIB文件和OLB文件的位置可能有改变.我的版本是9.1.
2,重新生成OLB文件后的每个元件的外形发生了变化,需要重新编辑,否则很不直观.若不重新编辑,也可以用.
3,通过仿真,这个管子的模型中,1是D,2是G,3是S.
问题:
可以用.
1,用MODEL EDITOR打开一个已经存在的LIB文件.(最好先做个备份)
2,用MODEL->COPY FROM将文本文件中的每个部分COPY过去.
3,用FILE->CREATE PARTS重新生成OLB文件.OK了.
但存在以下的问题:
1,不同的版本,LIB和OLB文件的位置可能有变化.我的版本是9.1.
2,重新生成的OLB文件中的元件的外形被改变了,虽然能用但不直观.
3,通过仿真测试,这个MOS模型的脚位是1为D,2为G,3为S.
我的这个办法虽然可用,但使用价值不高,希望有更好的办法.
但存在以下的问题:
@乞力马扎罗的雪
可以用.1,用MODELEDITOR打开一个已经存在的LIB文件.(最好先做个备份)2,用MODEL->COPYFROM将文本文件中的每个部分COPY过去.3,用FILE->CREATEPARTS重新生成OLB文件.OK了.但存在以下的问题:1,不同的版本,LIB和OLB文件的位置可能有变化.我的版本是9.1.2,重新生成的OLB文件中的元件的外形被改变了,虽然能用但不直观.3,通过仿真测试,这个MOS模型的脚位是1为D,2为G,3为S.我的这个办法虽然可用,但使用价值不高,希望有更好的办法.
以下是我的做法
偶首先用记事本将模型的文本描述保存为*.lib文件,如stp60ne06.lib.
然后打开orcad的capture,File/New/Library,在library.olb上右击,选new part在弹出的对话框中:name 与spice模型的描述名相同(即.SUBCKT STP60NE06 1 2 3 这行中的STP60NE06).右边有一 attach implementation按钮,点击,在implementation type 中选Pspice model.在下面的implementation中填入STP60NE06,点击ok,回到上一级,点击ok,会转到元件外形编辑窗口,编辑外形及放置PIN.然后在Options选part properties.在弹出的对话框中,点击NEW.在NAME中填入PspiceTemplate , 在VAL中填入形如 X^@REFDES %1 %2 %3 @MODEL ,的字符串,视情况而定.然后保存,即可.
@tinyhe
以下是我的做法偶首先用记事本将模型的文本描述保存为*.lib文件,如stp60ne06.lib.然后打开orcad的capture,File/New/Library,在library.olb上右击,选newpart在弹出的对话框中:name与spice模型的描述名相同(即.SUBCKTSTP60NE06123这行中的STP60NE06).右边有一attachimplementation按钮,点击,在implementationtype中选Pspicemodel.在下面的implementation中填入STP60NE06,点击ok,回到上一级,点击ok,会转到元件外形编辑窗口,编辑外形及放置PIN.然后在Options选partproperties.在弹出的对话框中,点击NEW.在NAME中填入PspiceTemplate,在VAL中填入形如X^@REFDES%1%2%3@MODEL,的字符串,视情况而定.然后保存,即可.
这样做出来的不能仿真 :(
@tinyhe
在老古的FTP上有ftp.laogu.comus:laogu.compw:laogu.com是9.23版的从官方网站得知OrCAD10将在本月发布,据说做了重大改进
tiny,ftp.laogu.com我怎么老是登陆不了????
出现如下情况
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/0/1057714719.jpg');}" onmousewheel="return imgzoom(this);">
出现如下情况
![](http://u.dianyuan.com/bbs/u/0/1057714719.jpg?x-oss-process=image/format,webp)
@ridgewang
tiny,ftp.laogu.com我怎么老是登陆不了????出现如下情况[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/0/1057714719.jpg');}"onmousewheel="returnimgzoom(this);">
用cuteftp上,我就是用这个上去的,不过没有找到:(
@ridgewang
需要username and password
@ridgewang
推荐用FTP专用软件
如FTPFXP,CUTEFTP等.
在IE中也可以,这样输入: ftp://laogu.com:laogu.com@ftp.laogu.com.
如FTPFXP,CUTEFTP等.
