我在运行multisim时出现下面的提示:谁能帮小弟解决,感激不尽。
Error: C:\DOCUME~1\3AK/G~1\LOCALS~1\TEMP\02.CIR: No such file or directory
Instrument operation performed   (2005, October 02, Sunday, 16:39:06)
|   Instrument Analysis: Transient Analysis #0
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions: Automatically generate initial conditions
|   |   |   Starting time (TSTART): 0
|   |   |   Stop time (TSTOP): 1e+030
|   |   |   Plotting increment (TSTEP): 1e-005
|   |   |   Maximum time step (TMAX): 1e-005
|   |   Perform consistency check
|   |   Variables from analysis
|   |   Representation as SPICE commands
|   |   |   begin-scope page
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set convlimit
|   |   |   set rshunt = 1e+012
|   |   |   -param hrange 0 1e+030
|   |   |   save
|   |   |   tran  -env-options 1e-005 1e+030 0 1e-005 auto_ic
|   |   |   if-error end-scope audit-log-show
|   |   |   end-scope
|   |   Analysis Options
|   |   |   Truncation error overestimation factor: 7
|   |   |   Upper transient iteration limit: 100
|   |   |   Enable convergence assistance on code models
|   |   |   Shunt resistance from analog nodes to ground: 1e+012
|   Output from instrument analysis
|   |   Simulation parameter "reset-options" can't be set until
|   |   a circuit has been loaded.
全部回复(2)
是不是电脑的用户名要用英文啊!我以前也遇到过!
danran
经过验证,确实如naughtyboy所说的那样,进入windows的用户名必须是英文名,否则仿真就会出错的。
