![](http://u.dianyuan.com/bbs/u/82/3642571256367311.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
zx5-630电流不能调小
全部回复(18)
@xj7394
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/3642571256386644.jpg');}"onmousewheel="returnimgzoom(this);">
魏工,你好.按你的分析,我总结了一下.1.调运放2脚的负压值.2.调W3和W4.3.W5和W6为电流微调.4.W10调节推力电流.另外,分流器发个图给你看一下,谢谢你.我看过惠工和其他网友对你的评价,蛮高的
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/82/3642571256390577.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/82/3642571256390756.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/82/3642571256390807.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/82/3642571256390577.jpg?x-oss-process=image/format,webp)
![](http://u.dianyuan.com/bbs/u/82/3642571256390756.jpg?x-oss-process=image/format,webp)
![](http://u.dianyuan.com/bbs/u/82/3642571256390807.jpg?x-oss-process=image/format,webp)
@xj7394
魏工,你好.按你的分析,我总结了一下.1.调运放2脚的负压值.2.调W3和W4.3.W5和W6为电流微调.4.W10调节推力电流.另外,分流器发个图给你看一下,谢谢你.我看过惠工和其他网友对你的评价,蛮高的[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/3642571256390577.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/3642571256390756.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/3642571256390807.jpg');}"onmousewheel="returnimgzoom(this);">
这板不好调试,w1234是控制可控硅的触发和平衡的,没有调好很容易使个别可控硅过载损坏,分流器烧成这样,只是影响输出电流
@xj7394
魏工,我的传真号是0833-2116455,图纸就传这个号码,谢谢.
@xj7394
有道理,谢谢.
这焊机板前几年修的多,现在我都改板了.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/82/437981256395891.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/82/437981256395891.jpg?x-oss-process=image/format,webp)
@xu319
这焊机板前几年修的多,现在我都改板了.[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/437981256395891.jpg');}"onmousewheel="returnimgzoom(this);">
现在(焊研)的新板也差不多这样,基本原理一样,运放不同.这个板子厂方技术部说LM308H坏了,现在无货.我在汕头通过快递买了新品换上依然不行.厂方叫我换这种新板,但新板不调好,故障依旧.
@xj7394
好的,我今天到文轩书店去看一下.
![](http://u.dianyuan.com/bbs/u/82/3642571256555816.jpg?x-oss-process=image/format,webp)
@xj7394
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/82/3642571256555816.jpg');}"onmousewheel="returnimgzoom(this);">
魏工,谢谢你给的资料.书没有买到,要不在网上买.这几天我们这儿都下雨,现场要把机器推到外面耷电源,因而未去,明天再去.
@xj7394
魏工.XU319,你们好,谢谢你们的帮助,焊机已修好,过程如下.1*运放管还原2*分流器还原3*运放2.6脚间的300K电阻更换(同样的电阻,同样加点外热,原电阻阻值变化太大)
现场维修,通电发现焊接电压42-65可调,原来的电压为24V,但电流依然很大(焊机上的电流表当时不知为何不显示,用直流钳表测).停机断开电流表接线,开机焊电流居然降到了40A.想到电流表不显示可能是反转电流,于是停机,将电流表接线及分流器两条反馈线同时对调,再开机一切正常,用2.5的焊条小电流焊接都可以,大焊条大电流也正常.
@xj7394
魏工.XU319,你们好,谢谢你们的帮助,焊机已修好,过程如下.1*运放管还原2*分流器还原3*运放2.6脚间的300K电阻更换(同样的电阻,同样加点外热,原电阻阻值变化太大) 现场维修,通电发现焊接电压42-65可调,原来的电压为24V,但电流依然很大(焊机上的电流表当时不知为何不显示,用直流钳表测).停机断开电流表接线,开机焊电流居然降到了40A.想到电流表不显示可能是反转电流,于是停机,将电流表接线及分流器两条反馈线同时对调,再开机一切正常,用2.5的焊条小电流焊接都可以,大焊条大电流也正常.
我的手机是13618181616
