自己组装的MIG250焊机
这是第一台样机,还有些地方工艺需要改进完善.下一步计划,滤波电解换做无感电容,主回路电抗器改成螺旋棒状的,改善散热性能.主变铁心规格用ONL100-50-25纳米晶铁心(315A所用铁心),目前所用规格ONL80-50-25(佳士所用规格),电流可上到300A,但是功率余量太小.初级三相整流用模块,目前所用为2只爱赛斯36A/1600V小三相整流桥.
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975455.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975534.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975653.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975709.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975763.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/3268701260975814.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(35)
fcyg
徐工,走线还需要在规矩一些.
焊机oem
@fcyg
徐工,走线还需要在规矩一些.
是的
@fcyg
徐工,走线还需要在规矩一些.
哥们谢谢,欢迎多提宝贵意见.这是第一台样机,还没来得及把一些细节处理,后面出来的就会规矩得多了.
lyjy
@秋雨_225
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/488191261038210.jpg');}" onmousewheel="return imgzoom(this);">
若将这三部合在一起则装修方便了!
@lyjy
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/84/488191261038210.jpg');}"onmousewheel="returnimgzoom(this);">若将这三部合在一起则装修方便了!
我正打算这样搞一个小的160A机型,体积比KR的送丝几稍微大点
@秋雨_225
原来,秋雨兄 自己生产了啊
@幽默太极
原来,秋雨兄自己生产了啊
谈不上什么生产,没事也来DIY一下
lyjy
@秋雨_225
单相co2-160a是非常有竞争优势的产品.160a够用.祝早日成功.
@秋雨_225
谈不上什么生产,没事也来DIY一下
我也在耘量一款单相160二保焊,估计很快也可以DIY了
焊机oem
@lyjy
160A是电流是够用的,但是最后还是虚标为200A才好卖,呵呵 市场就是这个样子.
lyjy
@焊机oem
160A是电流是够用的,但是最后还是虚标为200A才好卖,呵呵市场就是这个样子.
小巧.单相nbc-200.特色产品.适宜铁艺等行业!
看看
楼主高手,这种机子的磁环在那才能购到!
churnsun
徐工你好!TLD84CN哪儿能搞到?这个机效果怎样,我觉得送丝电路光反馈没有保护还是比较危险的,容易炸9540,有待改进
igbt焊机
@churnsun
请问这款机是仿佳士的,还是瑞凌的,多谢!
秋雨_225
@igbt焊机
仿佳士的,其实佳士也是仿的奥太的,只是把电路简化了.这机器的电流/电压调节匹配范围宽,参数好调节.瑞凌的200A MIG200的电流/电压调节范围窄,不太好匹配,是点状的,每个电压参数,电流必须要调到所对应的点才好焊.
秋雨_225
@churnsun
买电子元件的地方都有
igbt焊机
@秋雨_225
买电子元件的地方都有
秋雨兄,请问这主变的匝比是多少?多谢!
@秋雨_225
是用CO2还是用氩气。使用多少电压
秋雨_225
@igbt焊机
秋雨兄,请问这主变的匝比是多少?多谢!
42:4
igbt焊机
@秋雨_225
42:4
秋雨兄,多谢了!你那MIG-160的机器出来了吗?能把图片贴出来让大家分享一下吗?愿好人有好报!
@igbt焊机
是用CO2还是用氩气。使用多少电压
@70938
是用CO2还是用氩气。使用多少电压
多少钱一套 可以站内短信留言
@70938
多少钱一套可以站内短信留言
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}">
gz.daheng
稍加工艺改良和注意走线布局,可成铭器.
(单就电路构成,可见细微之处,想来也参照了不少名机)不错!
@gz.daheng
稍加工艺改良和注意走线布局,可成铭器.(单就电路构成,可见细微之处,想来也参照了不少名机)不错!
我怀疑滤波电容是不是用错了。
wo351719064
@秋雨_225
秋哥。你有电话不?可以留 一个不?我现在店铺也在做佳士的机。可我不怎么会么修。有问题也可以找找你嘛。也可以加我qq.531719064
秋雨_225
@wo351719064
秋哥。你有电话不?可以留一个不?我现在店铺也在做佳士的机。可我不怎么会么修。有问题也可以找找你嘛。也可以加我qq.531719064
13568223082
2011-02-26 14:19
哥们谢谢,请问成本价值多少?
晓逆变
2011-02-26 21:34
想法不错,换原件后价格是不是提高,换原件后效果会更好
