昨晚闲来无事 做机
EE70主变 0.7*15*3+3  次级0.7*2*65+15 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/2228951261633972.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
全部回复(57)
dqjdwx
EE55 0.3铜皮*32*3  次级0.7*2*65+15 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/2228951261634117.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/2228951261634126.jpg');}" onmousewheel="return imgzoom(this);">
dqjdwx
@dqjdwx
EE550.3铜皮*32*3  次级0.7*2*65+15[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/84/2228951261634117.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/84/2228951261634126.jpg');}"onmousewheel="returnimgzoom(this);">
驱动板3525 一块 494一块 带9.5V欠压和过流保护一块 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/2228951261634229.jpg');}" onmousewheel="return imgzoom(this);">
dqjdwx
@dqjdwx
驱动板3525一块494一块带9.5V欠压和过流保护一块[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/84/2228951261634229.jpg');}"onmousewheel="returnimgzoom(this);">
EC42主变一个 500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/84/2228951261634301.jpg');}" onmousewheel="return imgzoom(this);"> 0.7*8*4+4 次级0.7*85+110
dqjdwx
@dqjdwx
EC42主变一个[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/84/2228951261634301.jpg');}"onmousewheel="returnimgzoom(this);">0.7*8*4+4次级0.7*85+110
全经过测试 3525驱动板32KHZ 494驱动板25.6KHZ EE70空载电流120MA EE55 98MA EC42 85MA 全手工制作 效率还行吧 哈哈
dqjdwx
@dqjdwx
全经过测试3525驱动板32KHZ494驱动板25.6KHZEE70空载电流120MAEE5598MAEC4285MA全手工制作效率还行吧哈哈
BANXINJIA
搬新家了 差点儿找不到门口
dqjdwx
@dqjdwx
BANXINJIA                搬新家了差点儿找不到门口[图片] [图片]
dqjdwx
@dqjdwx
dqjdwx
@dqjdwx
EE55想做到900W 频率32.25KHZ大家看看有什么缺点和好建议吗
dqjdwx
@dqjdwx
EE55想做到900W频率32.25KHZ大家看看有什么缺点和好建议吗
怎么没有朋友说话呢
panqi
@dqjdwx
怎么没有朋友说话呢
驱动板离管子远了点和变压器是不是太亲密了O(∩_∩)O~
@panqi
我的小机都是摆得很近的,可能有干扰
dqjdwx
@panqi
谢谢提醒 已经改进了 前极带1000灯泡35分钟基本没有温升 现在调试风扇温控 后级还没想好 可能做双硅 因为它脉宽可调 那位朋友有好后级别 推荐一个
hbzjcjw
@dqjdwx
一般是磁芯定了,功率定了,频率越低越好,估计17KHZ就够了
mrshao
@hbzjcjw
干净整洁,用心了,顶。
@mrshao
干净整洁,用心了,顶。
   专程来学习!
dqjdwx
@森禾工业电子
  专程来学习!
谢谢老师的顶帖
yezhiyuan
EE70主变 0.7*15*3+3  次级0.7*2*65+15        0.7*15=5.76MM平方  初级按10A电流极限你也只能过57A*12V=684W      0.7*2=0.76MM平方次级按5A*.076=*320V=1216W     已经有点前后级不平衡了,如果说得不对的地方请多包涵················EE55的9.6MM平方还没问题
yezhiyuan
@yezhiyuan
EE70主变0.7*15*3+3  次级0.7*2*65+15       0.7*15=5.76MM平方 初级按10A电流极限你也只能过57A*12V=684W     0.7*2=0.76MM平方次级按5A*.076=*320V=1216W    已经有点前后级不平衡了,如果说得不对的地方请多包涵················EE55的9.6MM平方还没问题
2009-12-24 14:05:18
   dqjdwx 称号:排长 电源币:140
磁芯频率工作在15-20K比较好   况且场效应管开关的次数越高发热就越大  我做EE55  3+3频率都做到16K了空载才250MA
dqjdwx
@yezhiyuan
初级你忘了是0.7*15*2的  看好了吗
dqjdwx
@dqjdwx
磁芯15——20千赫是哪里的数据我的机器全是30多千赫的 很稳定啊 整流管8120*4个 没问题
dqjdwx
@dqjdwx
磁芯15——20千赫是哪里的数据我的机器全是30多千赫的很稳定啊整流管8120*4个没问题
我用过53千赫  你信吗
yezhiyuan
@dqjdwx
我用过53千赫 你信吗
初级你忘了是0.7*15*2的  看好了吗           你看好了吗以下是你原文的照片
yezhiyuan
@dqjdwx
我用过53千赫 你信吗
80K的我都做过只是整流管很快完蛋了,而且前级管子很热
dqjdwx
@yezhiyuan
完蛋你那是技术问题   原文是3+3 没看见吗
yezhiyuan
@yezhiyuan
绕的圈数更少,只有实际把圈数减少了才能提高功率.如果在同样材料的一个大磁芯和一个小磁芯上,用
一样的导线绕同样的圈数,对同样的输入电压输出功率是基本相同的.同样,如果一个做好的变压器,仅
仅靠改变工作频率,也是不会使输出功率提高的.
yezhiyuan
@yezhiyuan
绕的圈数更少,只有实际把圈数减少了才能提高功率.如果在同样材料的一个大磁芯和一个小磁芯上,用 一样的导线绕同样的圈数,对同样的输入电压输出功率是基本相同的.同样,如果一个做好的变压器,仅 仅靠改变工作频率,也是不会使输出功率提高的.
yezhiyuan
@yezhiyuan
 0.7*15=5.76MM平方 初级按10A电流极限你也只能过57A*12V=684W     0.7*2=0.76MM平方次级按5A*.076=*320V=1216W    已经有点前后级不平衡了[图片]
EE70主变 0.7*15*3+3  次级0.7*2*65+15              这个明明是楼主你写的现在又改成 0.7*15*2  ?????
dqjdwx
@yezhiyuan
3+3看见了吗
dqjdwx
2010-01-07 11:04
@dqjdwx
[图片]3+3看见了吗
请问一个工频50W变压器工作在200赫兹时也是出50W吗 那个老师教的
yezhiyuan
2010-01-07 11:05
@dqjdwx
[图片]3+3看见了吗
那你的到底是0.7*15还是多少??、3+3是圈数我当然知道     但是你要知道0.7*15才是导线的面积
