ORCAD10.5仿真时遇到的问题,有原理图和下载,,急急急急急急急急急急
全部回复(15)
@新手在成长
提示的错误如下:ERROR--Convergenceproblemintransientbiaspointcalculation不知道该怎么结果,我是想仿真一个现成的电路的,电路中的功率开关管IRF9Z34S我在ORCAD里面没有找到,我就用其它的元件代替了.不知道是不是这里的原因导致问题的出现的.
![](http://u.dianyuan.com/bbs/u/36/1133841735.jpg?x-oss-process=image/format,webp)
@新手在成长
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133841735.jpg');}"onmousewheel="returnimgzoom(this);">
![](http://u.dianyuan.com/bbs/u/36/1133841906.jpg?x-oss-process=image/format,webp)
@新手在成长
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/36/1133841906.jpg');}"onmousewheel="returnimgzoom(this);">
不知道论坛现在怎么回事,我自己上传上来的东西,测试下载一下也不可以下载说,真是奇了怪了!!!!!!
@zjueexuye
大哥,你MOS管选错了吧电路图上用的是N沟道,你的仿真用的是P沟道,这样驱动和管子之间就不能配合了
换成P沟道的还是出错,
ERROR -- Convergence problem in transient bias point calculation
Last node voltages tried were:
NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE
(N00278) .0453 (N00282) .0453 (N00298) -2.8801 (N00474) .0453
(N00544) .2600 (N00570) .0454 (N00896) .0360 (N01199) 3.0453
(N02046) .0459 (N02570) 3.0453 (N03323) 3.0453 (N03388) 3.0453
(N03911) 3.0453 (N04886) .0454 (N05068) .0454 (N05819) .0454
(N17764) .0454 (X_M1.2) 3.0453 (X_U1.12) .0533
(X_U1.13) 8.0345 (X_U1.14) .3893
(X_U1.15) .4653 (X_U1.16) 1.6434
(X_U1.21) 3.7514 (X_U1.22) 3.2096
(X_U1.24) -.1472 (X_U1.25) .2456
(X_U1.26) .0854 (X_U1.27) .0854
(X_U1.28) .0533 (X_U1.29) .0573
(X_U1.31) 1.0354 (X_U1.32) 1.0453
(X_U1.51) -71.9120 (X_U1.52) 3.0453
(X_U1.53) .2453 (X_U1.54) -2.8329
(X_U1.55) -.8934 (X_U1.56) 3.0453
(X_U1.57) .2453 (X_U1.58) .0077
(X_U1.59)-45.68E+03 (X_U1.61) 4.0297
(X_U1.62) 3.0453 (X_U1.63) .1250
(X_U1.64) .4340 (X_U1.65) -171.5600
(X_U1.66) 3.0453 (X_U1.67) -6.8187
(X_U1.68) 1.0443 (X_U1.69) 1.0443
(X_U1.71) -361.4200 (X_U1.91) .2600
(X_U1.230) .0653 (X_U1.671) 1.0453
(X_U1.672) 1.0453
(X_U1.672) 1.0453
@新手在成长
换成P沟道的还是出错,ERROR--Convergenceproblemintransientbiaspointcalculation Lastnodevoltagestriedwere:NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE NODE VOLTAGE(N00278) .0453(N00282) .0453(N00298) -2.8801(N00474) .0453 (N00544) .2600(N00570) .0454(N00896) .0360(N01199) 3.0453 (N02046) .0459(N02570) 3.0453(N03323) 3.0453(N03388) 3.0453 (N03911) 3.0453(N04886) .0454(N05068) .0454(N05819) .0454 (N17764) .0454(X_M1.2) 3.0453(X_U1.12) .0533 (X_U1.13) 8.0345 (X_U1.14) .3893 (X_U1.15) .4653 (X_U1.16) 1.6434 (X_U1.21) 3.7514 (X_U1.22) 3.2096 (X_U1.24) -.1472 (X_U1.25) .2456 (X_U1.26) .0854 (X_U1.27) .0854 (X_U1.28) .0533 (X_U1.29) .0573 (X_U1.31) 1.0354 (X_U1.32) 1.0453 (X_U1.51) -71.9120 (X_U1.52) 3.0453 (X_U1.53) .2453 (X_U1.54) -2.8329 (X_U1.55) -.8934 (X_U1.56) 3.0453 (X_U1.57) .2453 (X_U1.58) .0077 (X_U1.59)-45.68E+03 (X_U1.61) 4.0297 (X_U1.62) 3.0453 (X_U1.63) .1250 (X_U1.64) .4340 (X_U1.65)-171.5600 (X_U1.66) 3.0453 (X_U1.67) -6.8187 (X_U1.68) 1.0443 (X_U1.69) 1.0443 (X_U1.71)-361.4200 (X_U1.91) .2600 (X_U1.230) .0653 (X_U1.671) 1.0453 (X_U1.672) 1.0453
显示出现了不收俭,说明你的仿真设置有问题!这个是振荡电路,如果你做直流仿真就一定会出现这个问题!应该设置瞬态仿真!我不知你设置的是什么!你可以到群13983864中来讨论
@新手在成长
增加接地符号,运行时间改为30mS,步长设为30nS.运行OK!
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/41/1148294953.gif');}" onmousewheel="return imgzoom(this);">
SG3525有仿真模型吗?有什么元件可以代替?
![](http://u.dianyuan.com/bbs/u/41/1148294953.gif)
@luoxiaoyuan
增加接地符号,运行时间改为30mS,步长设为30nS.运行OK![图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/41/1148294953.gif');}"onmousewheel="returnimgzoom(this);">SG3525有仿真模型吗?有什么元件可以代替?
为什么我用他的仿真显示:ERROR -- Subcircuit TL5001 used by X_U1 is undefined
说明我的库中是没有这个IC的,这个IC是楼主自己建的模型吗?
