每500伏特的安全距离为1MM左右呢?
平常打高压,是否可以这么理解,每500伏特的安全距离为1MM左右呢?初级对地爬电距离3MM,空间距离1.5MM呢?是否正确。
全部回复(38)
@隐形专家
[图片]
一、安全间距
1.  LN之间3mm以上,空间距离1.8mm以上,不足时开1mm以上的槽增加沿面距离。
2. 初次级间6.4mm以上,空间距离5mm以上,不足时开1mm以上的槽增加沿面距离。
3. 初级与外壳地4.5mm以上,空间距离3mm以上,不足时开1mm以上的槽增加沿面距离
4高压与地之间铜箔距离1mm以上,其它无要求铜箔间距离0.5mm以上。
@wuzhonggui
一、安全间距1. LN之间3mm以上,空间距离1.8mm以上,不足时开1mm以上的槽增加沿面距离。2.初次级间6.4mm以上,空间距离5mm以上,不足时开1mm以上的槽增加沿面距离。3.初级与外壳地4.5mm以上,空间距离3mm以上,不足时开1mm以上的槽增加沿面距离。4.高压与地之间铜箔距离1mm以上,其它无要求铜箔间距离0.5mm以上。
这是IEC-60950的空间和爬电距离要求:
附表2J – AC交流电源瞬间电压(摘录标准表2J)
AC main supply voltage up to and including a Mains transient voltage Vpeak b
Overvoltage category
Vr.m.s I II
50 330 550
100 500 800
150 c 800 1500
300 d 1500 2500
600 e 2500 4000
a    For equipment designed to be connected to a three-phase, three-wire supply, where there is no neutral conductor, the AC MAINS SUPPLY voltage is the line-to-line voltage. In all other cases, where there is a neutral conductor, it is the line-to-neutral voltage.
b   The MAINS TRANSIENT VOLTAGE is always one of the values in the table. Interpolation is not permitted.
c   Including 120/208 V and 120/240 V.
d   Including 230/400 V and 277/480 V.
e   Including 400/690 V.
In general,CLEARANCES in equipment intended to be connected to the AC MAINS SUPPLY shall be designed for Overvoltage Category II.
如果所测的工作电压峰值超过下表规格时,上述空间距离的值需增加下表所列的对应值
附表2K – 一次电路以及一次电路与二次电路之间的最小电气绝缘(摘录标准表2K)
                          Unit:mm
Peaking working voltage
 up to and including,
V
1500 2500 4000
Pollution degree
1 and 2 3 1 and 2 3 1, 2 and 3
F B/S R F B/S R F B/S R F B/S R F B/S R
71 0.4 1 2 0.8 1.3 2.6 1 2 4 1.3 2 4 2 3.2 6.4
210 0.5 1 2 0.8 1.3 2.6 1.4 2 4 1.5 2 4 2 3.2 6.4
420 F 1.5  B/S 2.0  R 4.0 2.5 3.2 6.4
840 F 3.0  B/S 3.2  R 6.4
The values in the table are applicable to FUNCTIONAL INSULATION (F) if required by 5.3.4 a) (see 2.10.1.3), BASIC
INSULATION (B), SUPPLEMENTARY INSULATION (S) and REINFORCED INSULATION (R).
If the peak working voltages exceeds the peak voltage of the AC main supply voltage, linear interpolation is permitted between the nearest two points, the calculated minimum clearance being rounded up to the next higher 0.1 mm increment.
附表2L– 次电路中的附加间隙(摘录标准表2L)
                          Unit:mm
1500V 2500V
Pollution degree 1 and 2 Pollution 3 Functional basic or supplementary insulation Reinforced insulation Pollution degree 1, 2 and 3 Functional basic or supplementary insulation Reinforced insulation
Peak working voltage up to and including,
 V
Peak working voltage up to and including V
210 210 0 0 420 0 0
298 294 0.1 0.2 493 0.1 0.2
386 379 0.2 0.4 567 0.2 0.4
474 463 0.3 0.6 640 0.3 0.6
562 547 0.4 0.8 713 0.4 0.8
For voltages above the peak working voltage values given in the table, liner extrapolation is permitted.
附表2N – 最小爬电距离(摘录标准表2N)
                          Unit:mm
RMS working voltage up to and including ,
V
Pollution degree
1 2 1 2 3
Material group
Printed boards Other materials
I, II, IIIa, IIIb I, II, IIIa I, II, IIIa, IIIb I II IIIa, IIIb I II IIIa, IIIb
10 0.025 0.04 0.08 0.4 0.4 0.4 1 1 1
12.5 0.025 0.04 0.09 0.42 0.42 0.42 1.05 1.05 1.05
16 0.025 0.04 0.1 0.45 0.45 0.45 1.1 1.1 1.1
20 0.025 0.04 0.11 0.48 0.48 0.48 1.2 1.2 1.2
25 0.025 0.04 0.125 0.5 0.5 0.5 1.25 1.25 1.25
32 0.025 0.04 0.14 0.53 0.53 0.53 1.3 1.3 1.3
40 0.025 0.04 0.16 0.56 0.8 1.1 1.4 1.6 1.8
50 0.025 0.04 0.18 0.6 0.85 1.2 1.5 1.7 1.9
63 0.04 0.063 0.2 0.63 0.9 1.25 1.6 1.8 2
80 0.063 0.1 0.22 0.67 0.9 1.3 1.7 1.9 2.1
100 0.1 0.16 0.25 0.71 1 1.4 1.8 2 2.2
125 0.16 0.25 0.28 0.75 1.05 1.5 1.9 2.1 2.4
160 0.25 0.4 0.32 0.8 1.1 1.6 2 2.2 2.5
200 0.4 0.63 0.42 1 1.4 2 2.5 2.8 3.2
250 0.56 1 0.56 1.25 1.8 2.5 3.2 3.6 4
320 0.75 1.6 0.75 1.6 2.2 3.2 4 4.5 5
400 1 2 1 2 2.8 4 5 5.6 6.3
500 1.3 2.5 1.3 2.5 3.6 5 6.3 7.1 8
Linear interpolation is permitted between the nearest two points, the calculated spacing being rounded to the next higher 0.1 mm increment. For reinforced insulation, the calculated value for basic insulation shall be doubled first before applying the rounding off.
我司产品一般使用“污染等级2,材料组别:IIIa或IIIb”
如果从表2N查得的爬电距离小于从表2K或2L或表2M(适用时)查的相应的电气间隙,则应采用所查得的该电气间隙值作为最小爬电距离的数值
ppfc_ctr
@wuzhonggui
 这是IEC-60950的空间和爬电距离要求:附表2J–AC交流电源瞬间电压(摘录标准表2J)ACmainsupplyvoltageuptoandincludingaMainstransientvoltageVpeakbOvervoltagecategoryVr.m.sIII50330550100500800150c8001500300d15002500600e25004000a   Forequipmentdesignedtobeconnectedtoathree-phase,three-wiresupply,wherethereisnoneutralconductor,theACMAINSSUPPLYvoltageistheline-to-linevoltage.Inallothercases,wherethereisaneutralconductor,itistheline-to-neutralvoltage.b  TheMAINSTRANSIENTVOLTAGEisalwaysoneofthevaluesinthetable.Interpolationisnotpermitted.c  Including120/208Vand120/240V.d  Including230/400Vand277/480V.e  Including400/690V.Ingeneral,CLEARANCESinequipmentintendedtobeconnectedtotheACMAINSSUPPLYshallbedesignedforOvervoltageCategoryII.如果所测的工作电压峰值超过下表规格时,上述空间距离的值需增加下表所列的对应值附表2K–一次电路以及一次电路与二次电路之间的最小电气绝缘(摘录标准表2K)             Unit:mmPeakingworkingvoltage uptoandincluding,VMainstransientvoltage150025004000Pollutiondegree1and231and231,2and3FB/SRFB/SRFB/SRFB/SRFB/SR710.4120.81.32.61241.32423.26.42100.5120.81.32.61.4241.52423.26.4420F1.5 B/S2.0 R4.02.53.26.4840F3.0 B/S3.2 R6.4 ThevaluesinthetableareapplicabletoFUNCTIONALINSULATION(F)ifrequiredby5.3.4a)(see2.10.1.3),BASICINSULATION(B),SUPPLEMENTARYINSULATION(S)andREINFORCEDINSULATION(R).IfthepeakworkingvoltagesexceedsthepeakvoltageoftheACmainsupplyvoltage,linearinterpolationispermittedbetweenthenearesttwopoints,thecalculatedminimumclearancebeingroundeduptothenexthigher0.1mmincrement.附表2L–次电路中的附加间隙(摘录标准表2L)             Unit:mmMainstransientvoltage1500V2500VPollutiondegree1and2Pollution3FunctionalbasicorsupplementaryinsulationReinforcedinsulationPollutiondegree1,2and3FunctionalbasicorsupplementaryinsulationReinforcedinsulationPeakworkingvoltageuptoandincluding, VPeakworkingvoltageuptoandincludingV21021000420002982940.10.24930.10.23863790.20.45670.20.44744630.30.66400.30.65625470.40.87130.40.8Forvoltagesabovethepeakworkingvoltagevaluesgiveninthetable,linerextrapolationispermitted.附表2N–最小爬电距离(摘录标准表2N)             Unit:mmRMSworkingvoltageuptoandincluding,VPollutiondegree12123MaterialgroupPrintedboardsOthermaterialsI,II,IIIa,IIIbI,II,IIIaI,II,IIIa,IIIbIIIIIIa,IIIbIIIIIIa,IIIb100.0250.040.080.40.40.411112.50.0250.040.090.420.420.421.051.051.05160.0250.040.10.450.450.451.11.11.1200.0250.040.110.480.480.481.21.21.2250.0250.040.1250.50.50.51.251.251.25320.0250.040.140.530.530.531.31.31.3400.0250.040.160.560.81.11.41.61.8500.0250.040.180.60.851.21.51.71.9630.040.0630.20.630.91.251.61.82800.0630.10.220.670.91.31.71.92.11000.10.160.250.7111.41.822.21250.160.250.280.751.051.51.92.12.41600.250.40.320.81.11.622.22.52000.40.630.4211.422.52.83.22500.5610.561.251.82.53.23.643200.751.60.751.62.23.244.5540012122.8455.66.35001.32.51.32.53.656.37.18Linearinterpolationispermittedbetweenthenearesttwopoints,thecalculatedspacingbeingroundedtothenexthigher0.1mmincrement.Forreinforcedinsulation,thecalculatedvalueforbasicinsulationshallbedoubledfirstbeforeapplyingtheroundingoff.我司产品一般使用“污染等级2,材料组别:IIIa或IIIb”如果从表2N查得的爬电距离小于从表2K或2L或表2M(适用时)查的相应的电气间隙,则应采用所查得的该电气间隙值作为最小爬电距离的数值
IEC-60950的空间和爬电距离要求,资料很详细,收了谢谢
cheng111
LV.11
@wuzhonggui
专业....手下了
yong168
@隐形专家
[图片]
学习了~~~~
wzx123
@wuzhonggui
学习一下,呵呵
@wuzhonggui
我们就是按照这张表来的
P200818
@yong168
学习了~~~~
今天又遇到这个问题,裸板测试老化没问题 ,等灌封(防水电源)后,高温老化后,出现声音,并且输出电压掉了2V左右,拆开电源剪掉地线(原本地线接外壳并且跟PCB板子的Y电容连接的),只接外壳后就没问题了 ,大家能否给个解释。
wuzhonggui
@P200818
今天又遇到这个问题,裸板测试老化没问题,等灌封(防水电源)后,高温老化后,出现声音,并且输出电压掉了2V左右,拆开电源剪掉地线(原本地线接外壳并且跟PCB板子的Y电容连接的),只接外壳后就没问题了,大家能否给个解释。
外壳是接输入还是输出的地!
最好是两边都接地!
安全方面的考虑!
cheng111
LV.11
@powercheng
我们就是按照这张表来的
有一点不理解:
“附注:决定是否符合要求前,内部器件应先施与10N力,外壳应施与30N力,以减小其距离.....”
zero3210
@wuzhonggui
很专业 资料很好 收下了谢谢
@隐形专家
[图片]
**此帖已被管理员删除**
cheng111
LV.11
@cheng111
有一点不理解:“附注:决定是否符合要求前,内部器件应先施与10N力,外壳应施与30N力,以减小其距离.....”
怎么没有人跟帖呢
自己顶一下
flyahead
@wuzhonggui
学习了
holyfaith
@wuzhonggui
很详细的,呵呵
不过好像是有几级要求的是吧,在不同的场合要求是不一样的吧
holyfaith
@cheng111
说的是不是强度呢?就是有的说要求从多少米摔下去不摔坏,有没有类似的地方
cheng111
LV.11
@holyfaith
谢谢,不知道这个文档从哪里下载呢。我准备开始研究AC-DC模块,想多学习一些
yc99826067
@海优小波
**此帖已被管理员删除**
受教啦
bode
@wuzhonggui
这些安全距离,是怎么得出来的?
我的理解是在空间上加一定的电压,然后看漏电流,但这个漏电流是多大才符合标准呢?
cheng111
LV.11
@bode
这些安全距离,是怎么得出来的?我的理解是在空间上加一定的电压,然后看漏电流,但这个漏电流是多大才符合标准呢?
会不会和空气放电有关呢?
@yc99826067
受教啦[图片]
perterlong
@照明世界
[图片]
UL60950+UL8750
隐形专家
@P200818
灌封后材料的介电常数变了,你在暗室内观察那里有电晕,适当补救。
bobery
@perterlong
UL60950+UL8750
收藏了
jepsun
@cheng111
60950对应的国标是4943.给你传一个。GB4943-2001
jepsun
@cheng111
我是这样理解的:压迫板子,可以缩小爬电距离;压迫外壳,可以缩小电气间隙。一个是平面上的一个是空间的。对应不同的措施,以人为因素,来模拟最坏的情况下:爬电距离和电气间隙是否能够满足安规需求。
jepsun
@cheng111
会不会和空气放电有关呢?
不认同bode的看法。这个和空气电击穿有关。
理论上,空气是绝缘的,但是在一定距离、强电压下,这个位置的空气,有可能发生击穿,也就不再绝缘了。至于机理,设计到物理化学、空气组分等方面的知识。其实这个在高压电的传输方面体会的更深。
个人理解!
jepsun
2011-01-05 21:42
@bode
再看一遍,你的理解也有些道理。但我保留。
jepsun
2011-01-05 21:44
@海优小波
**此帖已被管理员删除**
