  • 论坛首页
  • 美国Ametek Airscrew航空级风机及其他产品
1974 年 豪顿收购英国 Airscrew 公司。
豪顿是多个国家国防工业的认可供应商,主要为海军舰艇供应风机和压缩机,但也为其它应用供应这些设备。
我们的风机用于许多美国军舰的通风作业,经专门设计和制造,可以满足对这类设备额外提出的严格要求。压缩机用于潜水艇和水面舰船的各种工作,其细节属机密资料。
用于航空、海军和消防设备的移动呼吸系统结合了我们的隔膜压缩机。它们使气体可以在极高的压力条件下储存,从而增加给定容积的容量,并有助于保持气体与环境完全隔离,从而保护操作人员。
我们还为喷气发动机起动供应压缩机。
以前为航空航天业供应小型风机的 Airscrew Howden Ltd 不再存在,这些风机现在由 Ametek Corporation 旗下的 Airscrew 供应。
Airscrew
AS37mm Axial Flow Fans
High performance 37mm Axial Flow Fan designed to satisfy the cooling requirements of aerospace and defence electronic cooling applications. The motor housing and impeller are moulded in a reinforced polyethersulphone material to minimise weight. Fan drive is provided by a continuously rated totally enclosed induction motor which is bonded into the motor housing. The unit is cam clip mounted, at its inlet or outlet. Panel fixing clamps are supplied for use.
AS48mm Axial Flow Fans
High Performance 48mm Axial Flow Fan designed to satisfy the cooling requiremetns of the aerospace and defence electronic cooling applications. This Fan is availanble for 200V / 3 ph/ 400 Hz and 28 Volts DC power supplies.
AS50mm Axial Flow Fans
50mm Axial Flow Fan impeller mounted on the shaft of a brushless 28 Volt DC motor which is integral within the fan case duct and downstream guide vanes. The impeller and fan case are cast in high strength aluminium alloy.
AS68mm to 90mm Axial Flow Fans
AMETEK Airscrew offer a range of medium sized Axial Flow Fans from 68m to 90mm, suitable for 115 and 200 Volt / 3 Phase / 400Hz and 28 Volt DC power supplies and with various performance and features.
Applications of these fans include Gun Smoke extraction and equipment cooling in military vehciles and Avionics Cooling in Aircraft.
Fan Heaters/Military Vehicle
To provide a simple solution suitable for retrofit or incorporation into the original environmental control system, AMETEK Airscrew offers a range of fan heaters suitable for military vehicles. These fan heaters are capable of a wide range of heat outputs and supply sufficient air velocity and pressure to feed duct work and discharge louvres. Their high-pressure capability also makes them suitable for spot heating in addition to conventional ducted systems.
 Additional applications include demistting of windows and sighting systems. Options and alternatives include special noise attenuation, solid state relay controls, inlet guards and EMC protection.
70-98mm AC Axial Flow Fans
AS200mm+ Axial Flow Fans
AS105-170mm Axial Flow Fans
TMX 90mm Axial Flow Fans
Centurion 40-180mm  Axial Flow Fans
Centurion 400+mm Axial Flow Fans
Centurion 200-385mm Axial Flow Fans
AMETEK Airscrew offer a range of medium sized Axial Flow Fans from  90mm, suitable for 115 and 200 Volt / 3 Phase / 400Hz and 28 Volt DC power supplies and with various performance and features.
Airmax 65-75 Mixed Flow Fans
Airmax 95 Mixed Flow Fans
Airmax 105-108 Mixed Flow Fans
Hydraulic and Direct Drive Mixed Flow Fans
联系我们
办公地址:北京市海淀区永丰中路58
电话: +86-10-89655255
传真: +86-10-51601221/52781449
Email: info@sumasemi.com
邮编100094
门市地址:北京市海淀区中关村大街28-1号中海园电子市场BB-035
电话: +86-10-51601221
Email: hp.ma@sumasemi.com
邮编: 100086
全部回复(0)
