(watt H/S) 是什么参数?
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/38/1139531878.gif');}" onmousewheel="return imgzoom(this);">
KA5M0265芯片的一个参数
功耗35w吗?那也太可怕了`
全部回复(16)
I think maybe it means heatsink.
A cooling heatsink is necessary.
是不是每小时?
@b.r.g.j.wallace航天电源
是不是每小时?
Please make you understand what means power dissipation first.That meas power loss 35J per second.
shdoqi
@superpowersupply
Pleasemakeyouunderstandwhatmeanspowerdissipationfirst.Thatmeaspowerloss35Jpersecond.
What's the meaning of "meam" in your sentense?汉语不方便?
What'sthemeaningof"meam"inyoursentense?汉语不方便?
Sorry,Sir.this is a written mistake,the right written is "mean".
I think it will be helpful for me to upgrade my English Level.At least,I will not feel strange for common used english words.Do you think so?
@superpowersupply
Sorry,Sir.thisisawrittenmistake,therightwrittenis"mean".IthinkitwillbehelpfulformetoupgrademyEnglishLevel.Atleast,Iwillnotfeelstrangeforcommonusedenglishwords.Doyouthinkso?
Not every engineer is familiar with English,but they are experienced and elitists.
NoteveryengineerisfamiliarwithEnglish,buttheyareexperiencedandelitists.
What you said is right.But I think it is none of my business.
    I think I just want to do some english practise.It is not because of I have a good english level,but I have poor english level.I know it will bother someone.But I think I can only say sorry.
在带散热片的情况下,可以耗散的功率为35W,决定了它在最理想的散热条件下的最大输出功率.
并不是该芯片在任何条件下都会有35W功率损耗.
@superpowersupply
在带散热片的情况下,可以耗散的功率为35W,决定了它在最理想的散热条件下的最大输出功率.并不是该芯片在任何条件下都会有35W功率损耗.
这样说应该是对的.H/S的H,S两个分别代表什么?
H means Heat;
S means Sink;
So H/S means heatsink,---散热片
shdoqi
@superpowersupply
HmeansHeat;SmeansSink;SoH/Smeansheatsink,---散热片
MAYBE H/S=HEAT/SECOND
@shdoqi
MAYBEH/S=HEAT/SECOND
But please notice the UNIT is Watts;
Please upload the whole specification.For study carefully.
Thank you!
@superpowersupply
Pleaseuploadthewholespecification.Forstudycarefully.Thankyou!
1139561795.pdf
全文在这~~~
@好吃的鱼
1139561795.pdf全文在这~~~
Thanks,I think what I said is right.
