Features (most cost effectively object):
Built-in burst and external LPWM for wide range dimming control
Analog dimming Control
0-3V DC voltage direct dimming without any additional components
High precision reference and frequency control
Support single or multiple CCFLs
Flexible user programmability
-External programmable constant operating frequency
-Programmable striking frequency and voltage control
-Programmable soft on/off timer
-Programmable striking time control
-Programmable internal burst mode frequency control
Comprehensive protection coverage
-IC supply under voltage lockout (UVLO)
-System supply brownout protection
-Output over voltage protection (OVP)
-Over current protection
-Open lamp protection
New Inverter IC Solutions for Market
全部回复(29)
@inverter ic
频率不会漂移,此芯片的一大卖点是高精度.我们用外部电阻设定频率,芯片本身的误差在2%以内,加上外部电阻有1%的误差.假设系统的工作频率设计在50KHz,那么实际量产的频率可保证在48.5~51.5KHz之间.此外电流反馈的参考电压精度也是2%,以保证量产时输出电流项的CPK值.
首先频率产生的原始基准是最重要的,其次才是外围电路参数差异.因为这些最后相乘决定了最终工作频率偏差.
按照你的说法,频率基准与目前其他家的做法都不同,不依耐外部电容振荡产生,是由内部产生的而且批量误差小于2%,是这样吗?这个在芯片上要花很大力气了,好像很难,要不然O2早就实现了,用不着外加电阻、电容了.
贵公司的IC 频率是如何产生的,电阻、电容、晶振,量产频率则麽能保证到48.5——51.5,
@push-pull
这个方案看起来不错,可提供样片和演示板吗?另外效率可做到多少?
这是我们的Demo Board,效率在85%以上
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/38/1140169321.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/38/1140169321.jpg?x-oss-process=image/format,webp)
@inverter ic
Pushpullsolution1139909738.pdf
OB3318 Demo Board,效率88%
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/39/1141875811.gif');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/39/1141875811.gif)
