请教高手指点翻译两句英文!!!
A resistive divider is connected between the output regulated voltage and this point,to provide voltage feedback.
A resistive divider connects to this pin the rectified mains. A voltage signal, proportional to the rectified mains, appears on this pin.
全部回复(5)
sst1151
你是否只对第二行前一句有疑问?核对一下没?
valiant
@sst1151
对两句都不是很明白,已经仔细核对几次了,烦请帮忙!谢谢
austen
在输出校准电压和这点之间联接一个电阻分配器,提供电压反馈,将电阻分配器联接到整流电源,得到一个电压信号,与整流电源成比例.
valiant
@austen
谢谢了,还望以后多多指教!!!
austen
@valiant
谢谢了,还望以后多多指教!!!
resistive divider 电阻分压器
