  • 论坛首页
  • PDIUSBD12PW,ATMEGA88PA-MU,ATYINY48-AU现货热卖
東陽科技集團主推ATMEL(愛特梅爾),ST-ERICSSON 品牌全系列的晶片應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口全新原裝正品,並贏得行業內外的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡…USB 芯片接口;另經營NXP(PHILIPS) ,INFINEON, ST,IR ,ATMEL等知名品牌半导体
我司一直堅守客戶至上,互惠互利的經營理念,堅持誠實守信的商業原則,竭誠為客戶提供多元服務,並期待與您真誠合作,共謀發展!
強力推薦,優勢庫存:
ATMEL
AVR系列
ATMEGA8L-8AU;  ATMEGA48V-10AU;
ATMEGA88V-10MU ;  ATMEGA169PV-8AU
ATTINY13A-SU ;  ATTINY26-16SU;   ATTINY48-AU,ATMEGA88PA-MU
串列EEPROM系列
AT24C01/01A/02/04/08/16/32/64/128/256/512/1024
ST-ERICSSON
USB  Commercial:
PDIUSBD12PW       ISP1161A1BDTM     ISP1181BBSUM
ISP1568AETUM      ISP1760ETUM        ISP1761BEGE
*NXP(PHILIPS)半導體系列照明驅動晶片
UBA2014T(P): 600 V driver IC for HF fluorescent lamps 螢光燈可調光電子鎮流器
UBA2021T(P): Half-bridge power IC for CFL lamps 節能燈驅動IC
UBA2024P/T : Half-bridge power IC for CFL lamps 內置MOS節能燈驅動IC
UBA2028T 600V dimmable power IC for Compact Fluorescent Lamps內置MOS調光IC
UBA2030T : Full bridge driver IC for HID全橋驅動
UBA2032T(TS): Full bridge driver IC for HID全橋驅動
UBA2033TS : Full bridge driver IC for HID全橋驅動
UBA2035TS : HF Full-bridge control IC for HID lighting 商用全橋驅動
UBA2036TS : Full-bridge control IC for HID automotive lighting 高級車用全橋驅動
UBA2037TTS : Full-bridge control IC for HID automotive lighting 全橋驅動
UBA2070T(P) : 600 V CCFL ballast driver IC for CCFL backlighting LCD 背光驅動
UBA2071TTS : Full bridge control IC for. CCFL backlighting LCD 背光驅動
UBA2072TTS : Full bridge control IC for. CCFL backlighting LCD 背光驅動!
SSL2101SMPS IC for dimmable LED lighting LED可調光開關模式電源控制晶片
SSL2102Mains LED driver IC for dimmable LED lighting LED調光驅動晶片
*NXP(PHILIPS)半導體系列快恢復二極體
BYC8-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220
BYC8X-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220F
BYC10X-600 : Rectifier diode ultrafast, 超快恢復19ns,10A/600V TO220F
BYV29X-600 : Rectifier diode ultrafast, 超快恢復55ns,9A/600V TO220F
BYT79-600: Rectifier diode ultrafast, 超快恢復60ns,16A/600V TO220
BYV34-500Rectifier diode ultrafast, 超快恢復 60ns20A/500V TO220
BYQ28E-200Rectifier diode ultrafast, 超快恢復 25ns10A/200V TO220
BYQ28X-200Rectifier diode ultrafast, 超快恢復 25ns10A/200V TO220F
BYW29E-200: Rectifier diode ultrafast, 超快恢復 25ns8A/200V TO220
BYQ30E-200Rectifier diode ultrafast, 超快恢復 25ns15A/200V TO220
BYV72EW-200Rectifier diode ultrafast, 超快恢復 28ns30A/200V TO247
 *NXP(PHILIPS)半導體MOSFET:
PSMN010-55D : 75A 55V 10.5Mohm 125W TO252 , 電源MOSFET
PSMN015-100B :75A 100V 15Mohm 300W D2PAK(TO263) ,電源 MOSFET
PSMN015-100P :75A 100V 15Mohm 300W TO220 , 電源MOSFET
PSMN015-110P :75A 110V 15Mohm 300W TO220 , 電源MOSFET
PSMN009-100P :75A 100V 9Mohm 300W TO220 ,電源 MOSFET
PHP45NQ10T : 47A 100V 25Mohm 150W TO220 ,電源MOSFET
*NXPPHILIPS)其他主推產品:
TDA1308TClass AB stereo headphone driver  耳機專用功放晶片 SOP8
UDA1330ATSLow-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP16
UDA1341TSLow-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP28
PDIUSBD12DUSB interface device with parallel bus USB介面晶片 SOP28
PDIUSBD12PWUSB interface device with parallel bus USB介面晶片 SSOP28
TDA8920CTH: IC CLASS-D POWER AMP;2X100W /D類功放晶片,2X110W HSOP24
*INFINEON半導體COOLMOS
SPD03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W DPAK(TO252)
SPP03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W TO220
SPD04N60C3COOLMOS 4.5A 600V 0.95ohm 50W DPAK(TO252)
SPP04N80C3: COOLMOS 4A 800V 1.3ohm 63W TO220
SPP06N80C3COOLMOS 6A 800V 0.9ohm 83W TO220
SPA06N80C3: COOLMOS 6A 800V 0.9ohm 39W TO220F
SPD07N60C3COOLMOS 7.3A 600V 0.6ohm 83W DPAK(TO252)
SPP07N60C3COOLMOS 7.3A 600V 0.6ohm 83W TO220
SPA07N60C3COOLMOS 7.3A 600V 0.6ohm 32W TO220F
SPA08N80C3: COOLMOS 8A 800V 0.65ohm 40W TO220F
SPP11N60C3COOLMOS 11A 600V 0.38ohm 120W TO220
SPA11N60C3COOLMOS 11A 600V 0.38ohm 33W TO220
SPP11N80C3: COOLMOS 11A 800V 0.45ohm 156W TO220
SPW11N80C3: COOLMOS 11A 800V 0.45ohm 156W TO247
SPP17N80C3: COOLMOS 17A 800V 0.29ohm 208W TO220
SPW17N80C3: COOLMOS 17A 800V 0.29ohm 208W TO247
SPP20N60C3COOLMOS 20.7A 600V 0.19ohm 208W TO220
SPA20N60C3COOLMOS 20.7A 600V 0.19ohm 34.5W TO220F
SPP21N50C3COOLMOS 21A 500V 0.19ohm 208W TO220
SPW20N60C3COOLMOS 20.7A 600V 0.19ohm 208W TO247
SPW24N60C3COOLMOS 24.3A 600V 0.16ohm 240W TO247
SPW35N60C3COOLMOS 34.6A 600V 0.1ohm 313W TO247
SPW47N60C3COOLMOS 47A 600V 0.07ohm 415W TO247
英飛淩半導體其他主推產品:
ICB1FL02/03G :
螢光燈,高性能電子鎮流器控制晶片 SOP18
ICB2FL01/02G :可調光智慧螢光燈控制器 SOP19
TDA4863-2/2G :PFC 功率因數校正積體電路 DIP8/SOP8
ICE2PCS01/02G PFC功率因數校正積體電路 DIP/SOP8
ICE3B0565/JCOOLSET;小功率充電器,LEDDVB電源應用 12W-25W DIP8
ICE3B0365/JCOOLSET;小功率充電器,LEDDVB電源應用 10W-22W DIP8
TDK5110(F):汽車胎壓檢測項目,發射積體電路TSSOP10/TSSOP16
*STM意法半導體:
L6561/D : PFC 功率因數校正積體電路 DIP8/ SOP8
L6562/D: PFC 功率因數校正積體電路 DIP8/SOP8
L6574/D : 電子鎮流器控制驅動積體電路 DIP16/SOP16
TDA7297SA:10W+10W DUAL BRIDGE AMPLIFIER 音頻功率放大器
*ADI模擬器件公司:
 ADXRS401ABG :
角速度轉感器 航模產品專用
 ADXRS610BBGZ:
角速度轉感器 航模產品專用
其他產品:
6N139: 高倍率達靈頓光藕合IC DIP8  FSC
ATMEGA88V-10MU:單片機 MFL-32   ATMEL
ATTINY13A-SU:AVRLED手電筒;智慧電池充電管理晶片;SOP8ATMEL
TEL+86-755-83013511FAX+86-755-82716500
QQ: 1771322832, MSN: estghq@hotmail.com
E-mail:estghq@hotmail.com
Http://www.estg.hqew.com
全部回复(10)
estghq110
estghq110
@estghq110
[图片]
estghq110
@estghq110
[图片]
東陽科技集團主推ATMEI(艾特梅爾),ST-Erisson品牌全系列的晶品應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口原裝正品。並贏得行業的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡...USB芯片接口;我司一直堅守客戶至上,互惠互利的經營理念,堅持誠實守信的商業原則竭誠為客戶提供多元服務,並期待與您真誠合作,共謀發展!
強力推薦,優勢庫存
ATMEL
AVR系列
ATMEGA8L-8AU;ATMEGA48V-10AU;ATMEGA88V-10MU;ATMEGA169PV-8AU;ATTINY13A-SU;ATTINY26-16SU;ATTINY48-AU
串列EEPROM系列
ST-Erisson
USB Commercial:
PDIUSBD12PW ISP1161A1BDTM ISP1181BBSUM ISP1568AETUM ISP1760ETUM ISP1761BEGE
estghq110
@estghq110
東陽科技集團主推ATMEI(艾特梅爾),ST-Erisson品牌全系列的晶品應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口原裝正品。並贏得行業的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡...USB芯片接口;我司一直堅守客戶至上,互惠互利的經營理念,堅持誠實守信的商業原則竭誠為客戶提供多元服務,並期待與您真誠合作,共謀發展!強力推薦,優勢庫存ATMELAVR系列ATMEGA8L-8AU;ATMEGA48V-10AU;ATMEGA88V-10MU;ATMEGA169PV-8AU;ATTINY13A-SU;ATTINY26-16SU;ATTINY48-AU串列EEPROM系列AT24C01/01A/02/04/08/16/32/64/128/256/512/1024ST-ErissonUSBCommercial:PDIUSBD12PWISP1161A1BDTMISP1181BBSUMISP1568AETUMISP1760ETUMISP1761BEGE
原装进口优势现货供应!有需要随时联系我。
estghq110
@estghq110
東陽科技集團主推ATMEL(愛特梅爾),ST-ERICSSON 品牌全系列的晶片應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口全新原裝正品,並贏得行業內外的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡…USB 芯片接口;另經營NXP(PHILIPS) ,INFINEON, ST,IR ,ATMEL等知名品牌半导体 。
szsth1
**此帖已被管理员删除**
estghq110
@szsth1
**此帖已被管理员删除**
estghq110
@estghq110
[图片]
強力推薦,優勢庫存
ATMEL
AVR系列
串列EEPROM系列
ST-Erisson
USB Commercial:
estghq110
@estghq110
原装进口现货供应,有需要随时联系我。
estghq110
@estghq110
原装进口现货供应,有需要随时联系我。
強力推薦,優勢庫存
ATMEL
AVR系列
串列EEPROM系列
ST-Erisson
USB Commercial:
